Old November 4th, 2009, 01:34 AM   #1 (permalink)
jms2009's Avatar
how do i remove residue from steel wool?
I was rounding the fret ends on my one piece maple neck and after using the steel wool on a few, I noticed some grey residue left from the 0000 steel wool I used. What is that residue & how do I remove it?
jms2009 is offline   Reply With Quote
Old November 4th, 2009, 02:01 AM   #2 (permalink)
Big Mike Simpson's Avatar
Roll some masking tape up sticky side out and touch it to the steel wool pieces or use a strong magnet.
Big Mike Simpson is offline   Reply With Quote
Old November 4th, 2009, 10:20 AM   #3 (permalink)
I saw this in a woodworking magazine. Using a strong magnet, as Mike said, put the magnet in a ziplock bag, go over the project to capture the micro steel particles then hold the baggie in a garbage bag & remove the magnet, discarding the baggie with the particles. Works great & the magnet stays clean.
bubba105 is offline   Reply With Quote
Old November 4th, 2009, 12:00 PM   #4 (permalink)
boneyguy's Avatar
I'm not sure what you mean by 'residue'. If you mean small bits of steel wool strands then I usually just vacum them up and it works just fine. I also like the magnet in a bag trick mentioned above. I'll try that one some day.
If residue means the wool has left an actual stain (rather than small strands) then I would try using naptha to wipe it off because it's likely a fine oil type residue that was on the wool from manufacturing. If it is a 'stain' then I would consider finding better quality steel wool. All wools are not of equal quality.
"Science doesn't prove, it probes."
Gregory Bateson
boneyguy is offline   Reply With Quote
Old November 4th, 2009, 02:42 PM   #5 (permalink)
I 1st use magnet
then maskng tape
"Cowboys to Girls"
Doug 54 is offline   Reply With Quote
Old November 4th, 2009, 03:16 PM   #6 (permalink)
Magnet
tonyw is offline   Reply With Quote
Old November 4th, 2009, 05:16 PM   #7 (permalink)
jms2009's Avatar
The residue is sort of like a powdery substance sort of like graphite, and it's certainly not the individual tiny metal strands from the wool since I've huffed and puffed them off the neck. Maybe naptha is the answer if the magnet trick doesn't fix it. The other suggestion about getting better wool makes sense so I'll get some. How do I know if some wool is better than other wool?
Keep on plankin'
Old November 4th, 2009, 05:26 PM   #8 (permalink)
VENDOR
Southern Ill Electrics's Avatar
Use magnet as suggested......it'll suck up those hairs.......Your also probally getting some funk off the frets.......Use Naptha, keep on truckin.
Jeffro' at Southern Ill Electrics
618-643-2406/618-308-0223
God Bless Les and Leo.
Southern Ill Electrics is offline   Reply With Quote
Old November 4th, 2009, 06:47 PM   #9 (permalink)
Telesavalis's Avatar
why not just get another piece of steel wool? a bag of 0000 is pretty cheap....
If musicians ran the world there would be no wars...just an occasional battle of the bands.
Telesavalis is offline   Reply With Quote
safe solvent to remove masking tape residue from nitro and Tru-oil? scubadoo Tele Home Depot 11 September 20th, 2009 09:43 AM
wet sanding or steel wool tweeet Telecaster Discussion Forum 10 October 8th, 2008 03:25 PM
Sandpaper or Steel Wool ?? lacquerbreath Tele-Tech 6 March 4th, 2008 02:22 PM
How to remove pickguard plastic residue? smccrory Stratocaster Discussion Forum 13 April 15th, 2007 07:33 PM
0000 steel wool shakedancer Stratocaster Discussion Forum 8 April 28th, 2004 02:56 PM
