Control Cavity Help Needed
Kinda newbie, this is my second build.
I have an ash body with no control cavity. The pickguard is custom. The placement and layout of the controls are custom as well, this is why we went with no cavity. I'm routing the cavity myself, please let me know if this sounds correct: 1) Locate the pickguard on the body. Trace pickguard, mark pots and switches. 2) Draw the shape of the cavity in Illustrator. Print the path on paper and cut it out. Then ensure the cavity shape looks right and fits appropriately on the body, within the trace of the pickguard. 3) Export the path to my CNC router. Cut template from 9mm acrylic. 4) Screw, tape, spray glue, clamp or use some other means to affix the template to the body. Use a trim bit to follow the template. Questions: What dia. of trim bit would you recommend? I have a 1/4" router. How deep of a bit should I use? After following the 9mm template, what should be my depth of cut on the subsequent passes? Please recommend an industrial quality brand of tool. I'm not cutting the body on the CNC because I've not yet developed my skills enough on this machine. Learning as I go, I can do cutouts and multiple layer work right now, but do not have the confidence to throw a body up on the table yet. Thanks!! |
my only suggestion would be to either cut the template on 3/4 mdf or use the acrylic on mdf to get a deeper template edge to ride the bearing on when routing the body.
shallower cuts are better... and you'll want at least a 1" long bit other than that, all sounds reasonable. |
| Control Cavity Differences?? | mcgeorgerl | Tele Home Depot | 14 | September 25th, 2009 11:57 PM |
| Help I cut the Control cavity too deep. | Guitartom_ca | Tele Home Depot | 30 | February 25th, 2009 10:42 PM |
| CV Control Plate Cavity Depth??? | rob5755 | Tele-Tech | 6 | January 19th, 2009 12:08 PM |
| Trying to get into control cavity of LP | GuitarJunkie84 | Tele-Tech | 7 | January 1st, 2009 06:28 PM |
| Whats that 'lump' in control cavity? | MulliganChebichev | Telecaster Discussion Forum | 2 | November 13th, 2007 02:42 AM |
