| Thread Tools |
#41 (permalink) | |
^^Thank you Dr.Ow!
I have a bit of machining experience from secondary school, but i don't use woodworking tools on a daily basis. I do know to take precaution though, and I appreciate your reminder. :) Quote:
And can I seriously shape that entire neck with a hand plane? Thanks! |
#42 (permalink) |
[quote=Customisbetter;2116987I actually need to get a rasp and spokeshave at some point as well. Im getting the beltsander for flush sanding bodies.
And can I seriously shape that entire neck with a hand plane? Thanks![/QUOTE] Yes, although it is easier with a spoke shave. Keep in mind I'm talking about a small block plane, not one of the full sized jobs. A block plane and/or a spoke shave, some cheap rasps and a sanding block with very course up through fine grits are all you'll need; and it doesn't take very long. I finish shaped my first neck last weekend. It only took a little over an hour using those tools, and keep in mind it was hard maple, not soft pine.
Oderint Dum Metuant - Nero Caesar Last edited by Ironwolf; November 4th, 2009 at 01:52 PM. |
#44 (permalink) | |
It's a funny ole world... whatever we get interested in seems to soon become a life lesson in patience and discipline. When I was 19? heh, I didn't have either... and I'm still working on it. templates? jigs? who had time for those? It was all "git r done!" I'll also echo the safety concerns. "I thought I was bulletproof." - chalk outline |
#45 (permalink) | |
Thanks all for such a great and vibrant forum, and the kind replies given to all here, a great forum it is. |
#46 (permalink) |
I would love for someone to explain to me in real terms with real results or examples why Pine would not work perfectly fine for a electric guitar neck. This is gonna be good.....
In the mean time, I have seen many one piece Pine neck Telecasters that stayed perfectly straight without even a truss rod or re-inforcement. The wood type itself has very little to do with whether or not it will work as a neck. Grain orientation will overcome a lot. Spruce (basically a type of pine) has extremely high tencil strength per weight and is why its used in air craft, accoustic guitar bracings etc. Its light, it resonant and readily available at local shops. So please..someone explain to me why pine won't work. J Joe |
#47 (permalink) |
Great build thread. Wish I had the guts to give things a go more, I might have to try something like this myself.
Looking forward to seeing more progress. Looks like it will be a cool, unique guitar when you get it finished. |
#48 (permalink) | |
He is not making a solid pine neck, he is using 4 2x4's of the shelf from home depot without drying or giving them time to breath or warp. I applaud his goal but only wish he had given it more thought and preparation
Yeah but you should of heard what I was trying to play-Thelonius Monk EnJoY ThE MuSiC GrooVey RecOrds |
#50 (permalink) |
Sorry for the rant... A 3 piece laminate pine neck can be very strong and last forever. The main thing when choosing a softer piece of wood is to ensure the grain is running the "best" direction. Luckily when you buy pine, 99% of it is flat sawn. While flat sawn is not the greatest for strength, when you turn it on its side to glue up a neck, you now have quartersawn which is very strong and stable. I would not hesitate to use a laminate pine neck on a bolt on guitar. Pine is not my choice mostly for tone reasons, but it is an excellent tone wood too.
I recentely was asked to make a mahogany neck for someone. I found a really light weight piece of Luan Mahogany. Luan is somewhere between pine and honduras mahogany in hardness. It has turned out to be a wonderfull neck. I have no doubts it will be around a long time too.
#53 (permalink) |
UPDATE
i got my bandsaw and beltsander today. First off, operating a bandsaw is MUCH harder than i expected. here are the results... ![]() My glue seams are almost nonexistant. So there is one victory at least... ![]()
#58 (permalink) |
^im not sure if its actually MDF, but there was a fiberboard looking material i saw at homedepot that i think would be cool to use as a fretboard. its was way smooth on one side... ill try to get a picture when i get it.
#61 (permalink) |
oh, i thought i saw a fretboard back there somewhere.
hmmmm fibre board would prob be a bit crap seeing as it is really just glue and sawdust. Imagine when your fingers work thru that outer layer of glue.... puff! your fret board becomes powder! I would definetly use some actual wood. Im not familiar with home depot ( i dont think it exists in oz) is it just a hardware shop? what will you do for things like pickups, tuners etc? |
#63 (permalink) |
Home Depot is a large country-wide chain of hardware and lumber stores.
I think i can do that fiberboard and size it, cut the fret slots and then Lacquer it. I think that way i should last for a while. |
#64 (permalink) |
Did a tad bit of work today... I have come to the conclusion that this is my practice neck. There are too many mistakes so far to sontinue using it. Luckily the post i used is big enough for two necks, so ill start on that this weekend. Anyways, i practice routing the outside shape of the neck using my new template bit. it went well.
![]() Here is the board i used at a straight line template... ![]() looks pretty straight... ![]() Mr. Mophead playing on doomed lumber....
#65 (permalink) |
How about heading over to the Flooring Department? My HD has some hard maple.
I'm not sure if this would work but HD also sells HPL (Formica) in sheets. They have some stuff that sort of reminds me of turn-of-the-century (uh, that would be the 1900 one and not the 2000) instruments that had Mother of Pearl/Toilet Seat fretboards and headstock overlays. Check out 250527925372 on eBay. |
#70 (permalink) |
your up to your neck in problems Literally
Its a quote from a song "Knee Deep in the big muddy"
#71 (permalink) |
at top of the home depot forum is a sub forum titled: 2009 $100 Tele Challenge
you might want to take an hour or two and read through those builds. I believe ScatterLee made his own radius block by setting up the router to cut semi-circles in mdf and then gluing them together... that's before he put together the neck radiusing jig. |
#73 (permalink) |
ok i got a 6 1/2" block plane....
its really all i could find at HD... also picked up a needle file set for slotting the nut and this rasp thingy... i sanded the test neck a ton and i think i can fix all the mistakes, so im keeping it. ALSO the fretboard is Oak. Deal with it. ![]() ![]() as you can prolly see, im recessing the heel a lot. the neck nees a lot more shaping too. ![]()
#76 (permalink) |
I wish people would stop using the word, "Pine" and actually refer to the species.
"Pine" is not a type of wood. It is a genus with over 100 species - all of which are different!
#77 (permalink) | |
| help identifing an airline | Joe Chaney | Bad Dog Cafe | 7 | July 8th, 2008 01:35 PM |
| airline amp | popthree | Amp Central Station | 12 | June 4th, 2008 03:25 PM |
| Any other airline employees on here? | retsacelet | Bad Dog Cafe | 2 | January 17th, 2008 02:40 AM |
| Homemade amp? Homemade TUBES!!! | tiktok | Amp Central Station | 8 | January 12th, 2008 01:18 AM |
| Airline | IsThereLoveInSpace | Bad Dog Cafe | 0 | November 21st, 2004 01:32 PM |
