| Home | Forum | Resources | T-Shirts & Etc | Music | Photos | Reviews | Classifieds | Register | FAQ | Search | Today's Posts | Mark Forums Read |
Noobie attempts a Grizzly kit-the birth of the Suncaster
Hi Everybody,
First off I would like to start by saying thank you to all of you for your amazing build threads. They have been a great inspiration/tutorial for my future builds. Second, I know that kits can be unpopular amongst these crowds, but I wanted to get one for my first because I'm no wood-wiz, and I want to be able to take plenty of measurements for future builds. Let's get down to business! I am going to be dyeing it yellow with a water based dye from McFadden's that I got at Grizzly, then I am going to put on a gloss nitrocellulose finish with my brand new spray gun. I just bought the kit, and hopefully all of the neccesary accessories, so here's the pics! ![]() ![]() ![]() Look Familiar?
The Products
![]() The bridge, complete with chinese newspaper for that authentic telecaster feel. ![]() Now the two imperfections I noticed This would be a drip of something presumably sealer that I will have to sand off ![]() Same deal here I think, might be glue though. Either way, it goes under the control plate, so I don't care
I am actually quite impressed, the neck seems very nice, the body needs quite a bit of sanding, but that's the fun part! Actually I did notice a few minor dings around the edges, but not a big deal. I have a feeling that the pups and tuners won't be very good, but I can't say quite yet. One of the things that surprised me was the controls, they are better than I was expecting. They aren't the typical tele knobs, they have lateral grooves, and I really like them. One thing I did notice is that the neck is just barely too big to fit into the pocket, but I thought maybe they do that so you sand the pocket down to a snug fit, I dunno. One last thing worth noting is that I think that the headstock is a bit too short for a traditional fender t-style head (I think and saw other people say). It can be adjusted easily though, and I'm not planning to make the traditional anyhow. Anywho long story too late to be short I love it so far! Didn't like the strat style one in the store though, looked like a bad copy. The curly top PRS style that they had instore was VERY cool looking. Transparent orange dye, light clear coat, beautiful curl, TOO stinkin' cool!
#7 (permalink) | |
His mind is preparing for that inevitability. . |
If the neck seems to big for the pocket you might be better off sanding the heel of the neck, rather than the pocket on the body, to make it fit right. I found it was easier this way, plus its easier to fix any potential 'mess ups'. Also , any lacquer, or sealing coats on the body/neck will obviously make the fit even tighter. Just be sure to keep the neck in line with the bridge.
good luck! |
#9 (permalink) | |
I'm not sure I would put a transparent finish on a 4-board body, but I can imagine it coming out well; after you stain it, if the board lines are too accentuated by the stain, you can change your mind if you want. |
#10 (permalink) | |
Thanks for the neck advice, thankfully the neck pocket has holes, but the neck doesn't. Hopefully that will help. |
I got one of these kits a while back and loved it. the only problem was that the pickguard looked like it was meant for a tele twice the size of the guitar (it covered the whole cutaway arm). I did buy a different pickguard from warmoth and it fit perfectly.
#14 (permalink) |
Wow, looks good! I have a 72 thinline tele reissue, and it's head stock has a different tuner spacing, so I can't exactly copy it, but I will most definetly try to modify it a bit.
Joe,
The tuner spacing on this neck is different than the Squier I took the pattern off of as well. I just made a pattern out of cardboard and marked the hole for the high E tuner. I lined up the hole in the pattern with the one in the new neck and traced it on with a sharpie. It only needed small amount of adjustment near the nut to make it look right. It's not exactly the same as the original headstock it was patterned after, but it's real close. |
#16 (permalink) |
Okay, so I finally got the sand paper yesterday, and here's what I did!
Here is the body as it was when I started, as you can see the body came with a sealer on it, I wore a respirator and glasses for most of it, I don't want to risk breathing too much of whatever passes for sealer in China. ![]() This is it after I finished with the first round of 150 grit sand paper. ![]() This is after I finished with the 220, then wiped it down with a damp cloth to raise the grain, then sanded it back down, then wiped it down again. ![]() The things we do for love! |
#17 (permalink) | |
#18 (permalink) |
I don't know what it is...probably the half a bottle of Port I've just drunk......but I don't half get excited looking at a new build with all this wood and tools and ideas......this is great stuff....Phil Bennett...brilliant ...oh that's brilliant.....JPR.Williams....Pullin....great dummy............can someone tell me what planet I'm on tonight..?
#19 (permalink) |
You are making me want to buy a grizzly kit! I'm going to do my best to resist. I was thinking that these kits were string through but I guess they're not.
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia |
#21 (permalink) | |
#22 (permalink) |
Well, I haven't been very good about updating this. I stained the guitar yellow, and got the neck to fit into the neck pocket. Here comes the problem. I just tried the bridge on the body, and I'm ticked! When it's lined up right there appears to not be anywhere that you can move it to where the routed pickup hoke doesn't stick out. There's a sweet spot that you can hit where it is less visible, but it still sticks out on both sides a little bit. Is there anything that I can do? I assume no, but who knows, you guys might have some kind of unholy worksmanship that my simple mind has not grasped.
#23 (permalink) | |
![]() If so, that's considered normal for a vintage spec Telecaster. The bridge cover used to cover the gap. There are some aftermarket bridges that do a better job covering it up, or an ashtray cover might fit your Grizzly bridge. If this is the gap you're talking about, I wouldn't worry about it too much. Good luck with your project.
Every now and then I know it's kind of hard to tell, but I'm still alive and well. |
#25 (permalink) |
Oklie doklie, today is the day the sealer goes on, I have quite a few pics on my camera to put up, but I'm lazy. :D One more note, I have decided to tru-oil the neck (if I can find some). When I went to mask off the fretboard little slivers of walnut were coming up with the tape, and if it does that right when I put it on I don't even want to see what it would be after spraying and a week of curing!
#26 (permalink) |
Designing the neck template with construction paper and my 72 tele thinline reissue
![]() Ready for the bandsaw ![]() Dyeing the back to make sure that it will look good ![]() Body shot with the rough neck
#30 (permalink) |
Looks great so far...I also did a Grizzly kit and I love it so much it is now my only tele. I've kept only it and my les paul...it's that good. The neck on mine was not very good at all. Had quite a twist in it that I couldn't live with. I got an SX STL50 neck, which is the fattest neck I've ever played and with jumbo frets too...it's nearly a perfect tele, for me anyway...
Here's my build thread The kit for me was a way to get my feet wet and hopefully have a playable guitar, then build a body from scratch for my second build. I'm working on my templates right now and hopefully over the winter I can get the body ready for finishing this spring. This looks really good, can't wait to see how it finishes up. Great job so far!!! |
