Nope.
I've seen what happens to a piece of Home Depot whitewood, tossed on the ground here for a couple days. Even in November. Wood is doomed. You gotta slow its disintegration if you can.
When i listen |
...it is a very powerfully sounding guitar ...
...it makes me play with more dynamics as a result cos the dynamic range is huge ...it sounds more like a strat than a tele on the neck pu but more tele than a strat on the bridge pickup...and the extra two inbetween sounds are suitably stratty ...there is a lot of 'treble' on this guitar heh... i like it a lot |
VENDOR
No finish?? Why.. the only viable reasons I know of are Laziness, or some one hopelessly lost in the realm of Finish mythology.
Ron Kirn
www.ronkirn.com |
#13 (permalink) | |
#14 (permalink) | |
...it should be easily available and far cheaper for you i imagine cos the cost of sending heavy wood like this across a few oceans by air is as much as the wood itself@! ...get a sample first to see if you are sensitised to working it ...espc sanding ...if not ...i highly recommend using it as it polishes up to a very fine sheen using only sandpaper ...it is also super oily and basically WATER PROOF :D ...if u are sensitised to this cocobolo ...i would recommend the other types of rosewoods available tht are less 'toxic' ...they all polish up to high sheen/chatoyance without the 'aid' of an artificial finish ...which can itself be 'toxic' to perform... here a pic of the fingerboard surface of the guitar sanded/polished to 1200 grit only...
#15 (permalink) | |
So is the bridge (either ebony or rosewood) and the fretboard. I've seen 100 year old acoustics in which the wood is anything but disintegrated. I've handled a Stradivarius violin, 300 years old, worth $2 million and unfinished inside. It's handling the instrument that makes it deteriorate. That said, I don't see any reason *not* to finish an instrument, at least with a light sealer coat. |
#16 (permalink) |
To be fair, there is a basic difference between oily woods like ebony or rosewood (cocobolo is a type of rosewood) and non-oily wood, right? I remember reading about non-oily woods absorbing sweat -- I think Warmoth has some disclaimer saying there are not responsible if a raw maple neck warps.
Transient are all component things, strive on with diligence. |
#18 (permalink) |
*shrug* Match your finish to your wood and intended use.
Hard exotics like cocobolo, I sand to as high a grit as possible, hit it with polishing compound and then a layer of hard wax (both via finishing wheel). Everything else gets shellac or lacquer (poly if its furniture or something thats gonna get beat on |
#19 (permalink) |
I sort of want to do it sometime, just for fun, because I'd like to see how it looks as it "weathers" over time.
I do wonder if not at least sealing it might allow the wood to slightly change with variations in humidity or other factors that I don't even know about, certainly it wouldn't be much, but it might not take much to mess with the neck joint. I'm not much of a wood expert though, or guitar building expert either. Anyone? |
#20 (permalink) |
Harrison and Lennon got two Epiphone Casinos in sunburst finish then promptly stripped them to "improve" the sound. Not sure what Epiphone was using then to finish (Nitro?) or if they had another finish applied. Bowie's guitarist Ronson stripped the finish off the top of his Black Les Paul Custom to improve the sound.
How much finish is left on a heavy relic? I dunno but it looks like a lot of bare wood to me. Some acoustic instruments do have inside finishes. Bogdanovich shellacs the inside top and sides but only the braces of the back. It's an ongoing debate with acoustic luthiers. Most say no but some swear by it. |
#21 (permalink) |
here's a few shots of my partscaster. taken last time it was on the bench. it's an unfinished Mighty Mite body that some body totally HACKED to cram some humbuckers and gibson hardware in there. the red stains in the bridge PU rout is sombodys blood! serves him right whoever did that! you can see the oak plugs that i put in there just so's a tele bridge would work.
anyhoo the only finish on there is sweat, beer, and cig smoke! ok...maybe a little drool in there too! so you can see by the pickguard shadow line how an ash tele will age with frequent use!
toadman the plank spanker www.slugnickel.com www.zydecohogs.com "The ultimate result of protecting man from folly is to fill the world with fools" Herbert Spencer
#22 (permalink) | |
#27 (permalink) |
Raw Wood with just hand rubbed oil on both these custom handmade guitars made by Stuart Spector
Yeah but you should of heard what I was trying to play-Thelonius Monk EnJoY ThE MuSiC GrooVey RecOrds |
#29 (permalink) |
I have a pine LP Jr body on a guitar with no finish. I don't play it a ton, but the areas that come in contact with skin absorb the sweat oil and that picks up the dirt. That area feels gummy compared to the non-contact area of wood. The rest of the body just gets darker from UV. It's not a particularly good look in my opinion.
#30 (permalink) |
Oil actually IS a wood finish, and therefor does not qualify as "unfinished raw wood" For rosewood or other "oily" woods it would work, but I would not advise it for pine, alder, etc...... |
#31 (permalink) |
Many violins and acoustic guitars are in fact finished on the interior.
Not all but many. On fiddles it was done to make bug and worm infestation less likely. Strads are finished on the interior , a sort of sizing that is the same as the base finish. Many classical guitar builders also do wash coat of spirt varnish on the interior. Its not very easy to see. It slows wood movement as well as keeps the interior clean. My fiddle guy calls it a "wood treatment". When he buys fiddles at auction the presence or absence of the "treatment" as he calls it is one indication that an un-labeled instrument is of a quality that warrants restoring. I've always put "something" on raw wood. At least wax. Its hard for me to resist finishing.
Livin' in the Past ,Present and Future is takin' up all my time..........
| Absolutely Tele-Clueless, Help! | Libertine | Telecaster Discussion Forum | 21 | April 22nd, 2008 12:59 AM |
| Absolutely hilarious | Caper | Bad Dog Cafe | 35 | April 2nd, 2007 07:51 AM |
| My new Strat is absolutely incredible. | TheGoodTexan | Stratocaster Discussion Forum | 18 | October 23rd, 2006 04:14 PM |
| Team built, master built, line built... | Joe M | Telecaster Discussion Forum | 1 | April 5th, 2004 06:35 PM |
