Old September 26th, 2009, 02:25 PM   #1 (permalink)
HSH or HH
TDPRI members im looking for your opinion on the guitar im building. I am planning on putting the Golden age pickups in it. You know the ones Stew Mac sells. Are these pickups any good? I am also debating whether or not i should put a single coil in there too and rewire it.
All opinions are welcome!
Nicktarnow is offline   Reply With Quote
Old September 26th, 2009, 03:03 PM   #2 (permalink)
Strat62's Avatar
You can get some really sweet tones by splitting the buckers and mixing them up with a center single coil, like a Vai JEM with a 5-position switch. Throw in some push-pull pots and you can get series parallel/reverse phase as well. Once I figured it out, I've split the coils on all my humbucker guitars. I haven't tried any of StewMac's pups, but I'll bet they're a nice economical alternative to the classic stuff.
Strat62 is offline   Reply With Quote
Old September 26th, 2009, 03:45 PM   #3 (permalink)
guitarbuilder's Avatar
I thought I had an article about stew mac pickups, but I don't. They were highly rated in a shoot out a few years ago in VG magazine.
guitarbuilder is online now   Reply With Quote
Old September 26th, 2009, 04:09 PM   #4 (permalink)
Mojotron's Avatar
I have found that the coil splitting sounds best when you combine a split/parallel neck pickup with a humbucking bridge pickup - or the other way around; or, 2 split/parallel humbuckers together. Combining with a center pickup just never really sounded right to me - it's not really a good strat sound. The exception I have found is the Dimarzio HS-2 - but that's a stacked pickup so the magnetic field is more like a single coil anyways...
Old September 26th, 2009, 10:55 PM   #5 (permalink)
Ironwolf's Avatar
I like the HSH combination; I've built two of them so far. I don't split the humbuckers, however. What I do is use a Strat 5 way switch wired normally and a push/pull pot to turn the bridge pup on and give me a neck/bridge combo, or all three pups on.
Oderint Dum Metuant - Caligula Caesar
"of those men who have overturned the liberties of republics, the greatest number have begun their career by paying an obsequious court to the people; commencing demagogues, and ending tyrants." - Alexander Hamilton
Ironwolf is offline   Reply With Quote
Old September 26th, 2009, 11:11 PM   #6 (permalink)
fishtownmike's Avatar
I do remember reading good reviews on them.
fishtownmike is offline   Reply With Quote
Old September 26th, 2009, 11:17 PM   #7 (permalink)
Nick JD's Avatar
+1. Split the HBs and use the rear bridge coil and the middle for the Strat position 2 sound ... and the front neck coil with middle gives position 4 Strat sound. Still humbucking too.
Just having a middle single coil pickup between two HBs - the middle position will sound dead and lifeless after the neck and bridge.
Old September 27th, 2009, 04:17 AM   #8 (permalink)
Strat62's Avatar
The Jem-style may not be a true Strat sound, but it sure sounds sweet to me!
Old September 27th, 2009, 11:27 AM   #9 (permalink)
my strat that i modded has HSH with a push-pull pot that splits both humbuckers and the normal strat 5 pos switch, works great and i get my stratish sounds and les paulish sounds:)
StratSvante is offline   Reply With Quote
