Old November 1st, 2009, 10:48 PM   #41 (permalink)
Good progress.
What radius did you use?
Are you going to have to sweeten up the fret slots after radiusing?
Did you have to fiddle with that Stanley Spokeshave to get it to work? Mine took a while....maybe I got a lemon.
And I love the repurposed cast iron sewing machine cabinet legs as a work table frame!
mcgeorgerl is offline   Reply With Quote
Old November 2nd, 2009, 12:31 AM   #42 (permalink)
Ironwolf's Avatar
The radius is 7 1/4 inches.
The fret slots will have to be "sweetened up when I start the freting process but for now they'll do while I start the finishing.
The spoke shave didn't give me any problems; it was just a matter of finding the proper cutting depth and angle on the blade.
I've spent the last couple of hours fine sanding up through 320 grit. Tomorrow I'll mix up some amber dye and give it a little color.
Oderint Dum Metuant - Nero Caesar
Ironwolf is offline   Reply With Quote
Old November 2nd, 2009, 11:13 PM   #43 (permalink)
Mojotron's Avatar
Looks great - really inspiring!
Old November 2nd, 2009, 11:46 PM   #44 (permalink)
Ironwolf's Avatar
Thanks for the complements. I've put off dyeing the neck until tomorrow night, it seems I'm out of alcohol, and will have to buy a can tomorrow.
Just for general accounting purposes, for people put off by making necks, I figure that the actual time I've spent on this, not counting the time to make templates, jigs and fixtures or waiting for glue to dry (skunk stripe, marker dots), is no more than 6 to 8 hrs from cutting the wood out of the big blank to the ready to finish state it's in now. So grab some tools and go to it gents!
Old November 6th, 2009, 10:37 PM   #45 (permalink)
Ironwolf's Avatar
I have the decals on and a couple of coats of wipe on Oil and Urethane. A couple of more coats on the head stock and I'll be ready to try my hand at fretting it.
Today I picked up a nice piece of birdseye maple for the telecaster neck. Here's a close up of one end of the board. The photograph only picks up about half of the birdseyeing that's there. I haven't tried laying a pattern on it yet, but it might be possible to get two neck blanks out of it.
Old November 7th, 2009, 07:31 PM   #46 (permalink)
Ironwolf's Avatar
I put another coat of poly on the Strat neck's headstock, and decided to start the process of making a neck for my "Super Tele" design. That's what the birdseye maple is for. The question will be, "What kind of wood to us for a fret board?". If I can find some that is straight enough at the local WoodCraft, I may use some Honduran or Bolivian rose wood. There are a lot of choices there, so we will see.
I cut a piece of MDF and using a couple of rulers, a StewMac neck pocket template and a tracing of a Tele headstock from a set of plans I have, I drew the outline for the Tele neck template.
Tomorrow, I should be able to cut and ready the template, and maybe the neck blank as well.
Old November 7th, 2009, 10:31 PM   #47 (permalink)
Ironwolf's Avatar
I took the template blank out to the garage and set up the bandsaw.
Rough cut the head stock:
Cut the sides and heel to finish.
Tomorrow morning I'll route the sides and sand the heel and headstock.
Old November 8th, 2009, 10:47 PM   #48 (permalink)
Ironwolf's Avatar
This morning I finished the template using the router table with a straight edge to do the sides, and the oscillating spindle sander and a hand block on the heel and headstock.
Old November 8th, 2009, 10:59 PM   #49 (permalink)
Ironwolf's Avatar
I then used the template to trace the neck on the birdseye maple blank.
Lots of birdseyes.
The bandsaw was used to cut the blank close to the line, and the oscillating spindle sander smoothed it out esentialy to the line.
The template was attached with double sided tape, all that was required for the router to take off was about the width of a pencil line, maybe 1/32nd of an inch all the way around.
Old November 8th, 2009, 11:00 PM   #50 (permalink)
hackworth1's Avatar
Is that one of the Chinese $100 oscillating spindle sanders? How do you like it?
Old November 8th, 2009, 11:14 PM   #51 (permalink)
Ironwolf's Avatar
Next, I set up the drill press and using StewMac's tuner jig,
I drilled the headstock for the tuners.
That will probably be all on this neck untill next weekend; I'll have to get a truss rod and finger board before I can continue, and there isn't enough light to work by, when I get home in the evening.
Old November 9th, 2009, 12:57 AM   #52 (permalink)
Ironwolf's Avatar
I don't know. It's probably Chinese, seeing as how we don't make anything but hamburgers here anymore. I got it when I started my first guitar build, about a year and a half ago, at HarborFrieght. It only cost $89 then, and it's done what I asked it to.
Old November 9th, 2009, 01:20 AM   #53 (permalink)
tdowns's Avatar
You are doing some awesome work. Work to a level I would never attempt. Thanks for sharing.
Best regards,
Old November 14th, 2009, 07:32 PM   #54 (permalink)
Ironwolf's Avatar
The weather here is quite frigid today, in the low 30's. In fact, it was still in the 20's when I started this morning.
I set up the slide jig and cut the truss rod channel in the Tele neck.
Then, I thinned the headstock down to 9/16" to fit a set of Fender locking tuners.
Old November 14th, 2009, 07:41 PM   #55 (permalink)
Ironwolf's Avatar
I picked up a piece of Blood wood for the finger board. I think it will look very nice.
I cut the board almost to size, and glued it up with Tightbond.
This neck has a quarter inch overhang for 22 frets.
Old November 15th, 2009, 12:01 AM   #56 (permalink)
tdowns's Avatar
I guess it would push your limits for PG-13 if I told you the Wylie Texas area weather today was 77°F high and 63°F low.
Don't you think you could have got a few more clamps on the fretboard??
Again, nice work. I can't wait to see it finished.
Best regards,
Old November 15th, 2009, 02:49 AM   #57 (permalink)
Ironwolf's Avatar
Those are the kind of temperatures we were having here 3 or 4 weeks ago. Idaho only has two seasons Summer and winter. Think Sahara and Antarctica.
I started fretting the Strat neck using StewMac's fret press mounted in my drill press.
I tapped the ends into the slots with a hammer, then, using the press, squeezed the bejeez out of them.
Old November 15th, 2009, 02:55 AM   #58 (permalink)
Ironwolf's Avatar
Once I had them all in place,
I used the nippers to flush cut the ends.
I have a bit more finish work to do on it, and a couple of more tools to aquire, then I'll dress the fret ends and attempt to level and crown them.
Old November 15th, 2009, 04:54 AM   #59 (permalink)
barkley's Avatar
Hey iron wolf, looking good!!
maybe you mentioned this earlier, but are these your first neck builds?
If so, holy cow thats some careful work!!
Also, any glue or anything in the fret slots? Or just lots of pressure pushing them in?
barkley is offline   Reply With Quote
Old November 15th, 2009, 10:26 AM   #60 (permalink)
Very impressive work!
Ricky D. is offline   Reply With Quote
Old November 15th, 2009, 12:47 PM   #61 (permalink)
Ironwolf's Avatar
Thanks for the compliments, and yes these are the first necks I've made.
Old November 15th, 2009, 09:00 PM   #62 (permalink)
Mark-00255's Avatar
Nice work, man! The blood wood fingerboard ought to look really cool!
Mark-00255 is offline   Reply With Quote
Old November 15th, 2009, 11:07 PM   #63 (permalink)
Ironwolf's Avatar
I flush trimmed the fret board with the router table. I had a chip out near the nut, but fortunately, once the fret board is thinned to a quarter inch (it's currently 3/8'') and radiused, it will be completely gone.
Old November 16th, 2009, 12:19 AM   #64 (permalink)
Ironwolf's Avatar
I rebored the tuner holes on the Strat neck to fit a set of vintage style tuners.
That will probably be it till next weekend.
Old November 20th, 2009, 11:44 AM   #65 (permalink)
Ironwolf, I like that jig you built. what are the dimensions on it?
gsoutherland is online now   Reply With Quote
Old November 20th, 2009, 03:43 PM   #66 (permalink)
Ironwolf's Avatar
It is made of 3/4 ply (voidless birch) It's about 30 inches long. and about 6'' wide (inside dimensions; width to accommodate a Strat style headstock). The sides are 1 1/2 inches high as currently configured. There is a removable 3/4 thick bed in the bottom that can be removed for working on a set neck.
Old November 21st, 2009, 10:34 PM   #67 (permalink)
Ironwolf's Avatar
Today I built a radiusing router slide for the jig box. Tomorrow morning I'll try thinning and then radiusing the fret board of the Tele neck. Stay tuned.
Old November 21st, 2009, 10:57 PM   #68 (permalink)
thinline4fatty's Avatar
Impressive.
thinline4fatty is offline   Reply With Quote
Old November 21st, 2009, 11:33 PM   #69 (permalink)
Thanks, Ironwolf, I got my pieces cut today! Hopefully I'll get to assemble it tomorrow.
Old November 22nd, 2009, 11:33 PM   #70 (permalink)
Ironwolf's Avatar
I thinned the fret board to 1/4".
I was planning to radius the fret board, but then I realized, fortunately, that I would be getting way ahead of myself. For those who might be curious, however, here is a shot of the radiusing sled I made yesterday.
Old November 22nd, 2009, 11:41 PM   #71 (permalink)
Ironwolf's Avatar
I set up the jig box as a miter box and cut the fret slots.
Then a little basic geometry, a few minutes with the drill press, and a dowel let me do the marker dots.
Well, that's it for today.
Old November 23rd, 2009, 04:34 AM   #72 (permalink)
truly nice work! By the time you've finished those 3 necks you would've taught me enough to build some myself :D
Zatar is offline   Reply With Quote
Old November 24th, 2009, 08:31 AM   #73 (permalink)
Ironwolf's Avatar
After the glue dried the dots and fret board were sanded flat.
Old November 28th, 2009, 09:56 PM   #74 (permalink)
Ironwolf's Avatar
Today, I carve the neck (carved the turkey the other day, so I'm ready).
Here are the tools laid out, ready to go.
After about an hours work, its ready for hand sanding with a block.
15 or 20 minutes with a hand block loaded with 100 grit paper has it ready for the next step.
Old November 28th, 2009, 10:04 PM   #75 (permalink)
Ironwolf's Avatar
I have a number of things to do today, including my niece's 16th birthday party, s this is probably as far as I'll get today.
Using the radiusing router sled, I put a 71/4 inch radius in the fret board, then gave it a quick rub down with 100 grit paper in StewMac's radius block. It took longer to set up the routing jig than to cut and sand the radius; less than 15 minutes to cut and sand.
Old November 29th, 2009, 02:23 PM   #76 (permalink)
Ironwolf's Avatar
Last night I fretted this one while watching the discovery channel. Now I need to clean up and bevel the fret ends.
Old November 29th, 2009, 02:52 PM   #77 (permalink)
Ironwolf's Avatar
Done, and done.
Next is a little fine grit polish sanding, and finishing decisions.
Old January 9th, 2010, 04:59 PM   #78 (permalink)
Ironwolf's Avatar
Both necks were dyed with an alcohol based amber and finished with wipe on oil based gloss poly urethane. they just need a level and crown, and the nut mounted.
The Strat neck will be used on the mahogany Strat body running in another thread.
Old January 9th, 2010, 08:02 PM   #79 (permalink)
Leigh's Avatar
Wish I had seen this before starting my neck.
Amazing work, and this is your first necks?
I don't think I'm enjoying my neck build!
Leigh is offline   Reply With Quote
Does Fender make any necks like an SX STL50? (And Howdy!) GiddyHitch Telecaster Discussion Forum 6 April 25th, 2009 02:00 PM
7 and 8 (mild spoiler alert!) surfoverb Bad Dog Cafe 6 July 13th, 2008 01:33 AM
My Squier (mild strat porn) Axis29 Stratocaster Discussion Forum 26 April 18th, 2007 04:38 PM
Profanity on Fender neck heels? eryque Telecaster Discussion Forum 21 April 27th, 2006 10:00 PM
Fessing Up (Variax 700) Mild tele content. Lance Telecaster Discussion Forum 2 February 21st, 2004 11:49 PM
