Sanding Sealer question - Telecaster Guitar Forum
Old September 20th, 2009, 02:18 AM   #1 (permalink)
I've got my first body roughly shaped and tomorrow I'll probably route the standard pick-up cavities, etc.....
This will be some sort of paint over a soft maple so I'll be wanting to lay on some sanding sealer soon until I decide about the paint.
Lowes/Home depot has quarts of Minwax sanding sealer (Yellow Can) and Lacquer Sanding Sealer (Black Can). I'd rather spray than brush but neither has instructions for spraying. I didn't see any rattle-can sealer of any type or brand.
I went to the local Sherwin-Williams store and asked about nitro-cellulose. The sales folks didn't have the slightest idea what I was asking for and could not find it in their database but they did find a lacquer sanding sealer that I could order....in a 5 gallon bucket. Not much help..........
mcgeorgerl is offline   Reply With Quote
Old September 20th, 2009, 09:09 AM   #2 (permalink)
Rob52's Avatar
I can't recommend you any specific sanding sealers as the brands we have available here probably wont be available in the states. Having said that, I'm sure someone will point you in the right direction. If you mean the same thing when you say sanding sealer as I understand it, you will probably have to consider some type of grain filler too if you're going to paint over ash, it has a fairly open grain. A filler will save you a lot of paint and cutting back to get a level surface.
Rob52 is offline   Reply With Quote
Old September 20th, 2009, 10:27 AM   #3 (permalink)
jimd's Avatar
Mcgeorgerl,
The Minwax stuff is not that great. It takes a long time to dry and is hard to sand. Lowes usually has Deft sanding sealer (look closely there is usually only a few cans). That is the stuff to get. It comes in both spray can and brush on. I like the brush on. It doesn't have to go on pretty since you are going to sand it all off anyway, and you can get good coverage quickly with a brush. If you can't find it at Lowes, check a specialty woodworking store like Rockler or Woodcraft.
jimd is offline   Reply With Quote
Sponsored Links   #
Old September 20th, 2009, 11:45 AM   #4 (permalink)
Mik
Mik's Avatar
Luthiers Mercantile International, everything you need for a nitro finish including sanding sealer. (solvent based vinyl sealer is among the nastiest haz mats I've ever handled make sure there's ventilation, wear a pro/OSHA spec'd respirator and of course NO FLAMES!).
Been some years since I ordered from LMI but my experiences were excellent, you don't need to go on hardware store hunts except maybe for acetone, thinner and Preval spray units...
LMI has it all from tack cloths to alcohol soluble anilin dyes.
McFadden Lacquer products including sealer
a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence
Mik is offline   Reply With Quote
Old September 20th, 2009, 12:52 PM   #5 (permalink)
I've had great results with a few coats of brushed-on Deft SS, followed by a few coats of sprayed-on Deft SS. The schedule is: brush on two coats with at least 30 min in between, wait 24-48 hrs, sand lightly, repeat, spray on 2-3 coats with at least 30 min in between, wait 48 hrs, sand lightly, repeat. Remove all glossy spots on the final sanding.
Deft dries very quickly. Make sure you wear a respirator or have plenty of air circulation!
Ciao,
Rick
blackbelt308 is offline   Reply With Quote
Old September 20th, 2009, 03:55 PM   #6 (permalink)
jwj4856's Avatar
Both the Lowe's and Home Depot in my area carry spray cans of Deft sanding sealer which works well for me.
Have Twang, Cant Sang.
jwj4856 is offline   Reply With Quote
Old September 20th, 2009, 06:51 PM   #7 (permalink)
Danocaster's Avatar
dont use the word nitro w/ them
just go back to Sherwin Williams and ask for their "LOVOC" Lacquer Sand n Sealer ( item T60 F64 )
it's what I use and it works great
Louder isnt better - it's just louder ( and better )
www.Danocaster.com
PLEASE FRIEND ME :
http://www.facebook.com/DanocasterVintageReplicas
Danocaster is offline   Reply With Quote
Old September 20th, 2009, 07:13 PM   #8 (permalink)
Ahhh.....that's what I'm looking for.....product codes!! I tried looking on the S-W site before but wasn't having any luck. If LOVOC means (and I'm guessing here) "Low Volatile Organic Compounds" is it really a Lacquer product?
Thanks...too late to go to S-W today (Sunday) and it's raining anyway. I'll stop in tomorrow and since they're between Home Depot and Lowes, I should be able to find something.
I'm at a standstill right now anyway until I figure out my template issue....right now I've got more questions than I can find answers to..........
Old September 20th, 2009, 07:25 PM   #9 (permalink)
Colt W. Knight's Avatar
brush on sanding sealer is easier for me than those expensive spray cans of sanding sealer. Just follow the instructions on the can. however, asothers havepointed out. deft SS comes in a can as well. Also, shellac makes good sandingsealer aswell.
the now mandatory =====>
Old September 20th, 2009, 07:31 PM   #10 (permalink)
Danocaster's Avatar
the LOVOC is sold in gallon cans - not spray cans - just FYI
and it says Nitrocellulose Lacquer Sanding Sealer on the can
www.Danocaster.com
PLEASE FRIEND ME :
Old September 20th, 2009, 07:36 PM   #11 (permalink)
Nick JD's Avatar
Does maple need sanding sealer?
Old September 20th, 2009, 07:54 PM   #12 (permalink)
I think I could get away with not sealing the front and rear faces. But it looks like the end grain could. Plus, I've got a poplar body blank that's up next.
Old September 20th, 2009, 08:51 PM   #13 (permalink)
maple doesn't need a sanding sealer, but I think finish goes on easier after two coats of sanding. just my opinion of course.
Old September 20th, 2009, 09:08 PM   #14 (permalink)
Marc Rutters's Avatar
I've started to use 1-2 coats sanding sealer on hard maple necks before frets and it's cut my finish time in half. All of those tiny scratches and voids like the edges of fret markers get filled so the lacquer can can lay down smooth and thin, less surprises. Home Depot carry's Zinsser brand pint/gallon and rattle can sanding sealer here but I'm thinking about trying some others to see how they compare because it comes out pretty orange peal even with a sprayer.
Marc Rutters is offline   Reply With Quote
Old September 21st, 2009, 08:03 AM   #15 (permalink)
I use Zinsser SealCoat™ Universal Sanding Sealer with great results. Claims to be compatible with ALL clear wood finishes. Its wax free and brushes on nicely, producing a flat finish. It was £17.50 (about $25) for a quart tin, and im 3 guitars in and it doesnt appear to have gone down by much, so i can see im going to get many more out of it, so I see it as a bit of a bargain.
Simon
smilbourne is offline   Reply With Quote
Old September 21st, 2009, 08:37 PM   #16 (permalink)
Stopped by S-W today and with the correct product code (Thanks again) the clerk was able to get me a gallon (smallest quantity) on order. Cost for a gallon is just under 40 bucks.
Found out that not all S-W stores are the same in our area. Most are home DIY but a few are commercial suppliers. That's where they have the sealer so they'll transfer it and save me the 40+ mile drive.
Old September 21st, 2009, 08:49 PM   #17 (permalink)
In my opinion, sanding sealer is a worthy investment. A gallon should last you a long time.
Old September 24th, 2009, 12:43 AM   #18 (permalink)
mwaym's Avatar
If I wanna stain a pine body, when do I use sanding sealer ??? After stain and before Tru-Oil ???
mwaym is offline   Reply With Quote
Old September 24th, 2009, 06:32 AM   #19 (permalink)
olaftheholy's Avatar
stain goes on bare wood...
meneerdebaas
olaftheholy is offline   Reply With Quote
Old September 24th, 2009, 07:53 AM   #20 (permalink)
I don't think you can use nitro sanding sealer under tru oil,
since nitro sanding sealer is lacquer.
The rule is:
You can put lacquer over tru oil but not tru oil over lacquer.
soulfixinman is offline   Reply With Quote
» Random Photo for Guests
Crook Custom Tele
» Recent ThreadsGuests
Fender Logan Custom Guitars
