#81 (permalink) | |
Would just a standard straight bit work? |
#91 (permalink) |
There is some stress on the pucks and the joints were the pucks-guides meet the base. The 1/2 MDF might be OK for the base, but you would want to reinforce things. The pucks should be plywood - I used 3/4" ACX (the cheap stuff) for mine and it's done well.
#93 (permalink) |
I use 3/4" pine for the whole jig. Works fine. I need to make more pucks. I love the original and it makes my necks very consistance. But now guys are asking for a more V or U shape. So I need to rethink a bit of this. Those asking about the U necks want them a bit thicker. So I assume I need to make the small puck a bit taller. (yes?)
Thanks again for a great jig. BTW: The bowl or plate bit works excellent for this jig. It has rounded corners so you don't get the grooved lines like in the pics above. Joe |
#94 (permalink) | |
I just finished up the transitions on my first few Maple necks and I never really had to focus on sanding out the grooves - they just came out when I gave the whole back of the neck a good once-over with 80gt on a sanding block. I left myself an extra .01" on the thickness and only used a fraction of that with sanding. When I started making pucks I found out that you can make a pretty good U just by using the original pucks and not raising the router bit the last .08-.1". I posted above what I had ended up doing to 'tune' pucks - starting with the Warmoth picks of back contours is very doable. You just have to do the math and size the front/back pucks based on the angle of the heal and nut width as well as the thickness at the 1st/12th frets respectively. |
#95 (permalink) |
Ok I got the jig completed and tested. I'm practicing on a 2x4. So far I've planed it down to 1.25" templated it and cut it out and did the radius which has got me fooled into thinking I can actually build a neck!!
I just need a truss jigg, fret spacing jigg, and diameter jigg. Anyone care to share plans for those on pdf if they have them. I'm also looking for technique advice on skinnying down the head stock. My band saw didn't have the clearance to pass that little tele head through all the way. Besides the blade wonders too much. So I filed it down with a belt sander which looked pretty good but still the surface is too wavey. The more I fine toon the more it messes something else up. I'll post pictures tomorrow. I also modified the jig a bit by adding a bar handle across the length of the jigg which is pretty comfortable from any postion along the neck.
If only my taste for guitars equaled my ability to play them!! |
#96 (permalink) | |
You know the jig that got me - and I don't really have a great solution except to use A LOT of clamps is the truss rod access hole from the headstock - that one really takes some practice. The way I look at it is in all these build threads where things go well, you do see a lot of Stu Mac stuff, so I now know that everyone else must have figured out the balance between the wallet and frustration - I'm going to follow their lead. I'm as careful as can be and things are going well. I've been working on making a good neck for about 4 months (generally one day on the weekends...). I cut out a few necks using lumber, then I cut out 2 maple neck blanks and got them slotted, made a truss rod out of 3/16" bar, and got that all glued up with a skunk stripe. Then I build Bill's jig and I think 6-8 more practice necks out of lumber - I finally got the pucks right after 6 or 7 tries. I just finished the transitions and I'm really excited about the result - this pair of necks could potentially be as good as my Warmoth necks - it all comes down to the fretting. So far, I have also made a neck out of every 2x4 I had in my garage - and I started on the 2x6's as well - I must have made 10 of those lumber necks all together, but they help a lot. Every time I don't feel confident in what I'm doing I do it on one of those practice necks and figure it out. I made some really hideous mistakes too... It's a lot of practice and patience (and money) but I love what I've learned so far - when I get it all right and finish these first necks I'll be so psyched for the next set. |
#97 (permalink) | |
JD |
#98 (permalink) |
First picture I'm just showing off what I got under the tree. It's always nice to learn with the proper tools!
2nd picture shows my completed neck radius jig. Worked like a charm. Held the neck on with double sided tape for the test but now I've got Ubolts. The double sided tape did work really well though. Notice the cross bar handle across the top. 3rd picture shows the rough result after the jig test. Not bad for a Home Depot 2x4! 4th picture shows the butt end with a fret board 7.25" radius. and sanded down with 100grit. I used the rocking jig that we've seen in several posts. That worked well with some lessons learned. I need a better way to secure my work. 2 really bad router strokes that would make a good neck intonfirewood. I've got an idea I will work on next time to solve that.
#99 (permalink) |
And finally, some more shots of the half sanded neck with transitions. The transitions are pretty half-a$$ but I don't plan on wasting anymore time on this scrap. Besides I took too much off of each end when I did the radius to do it properly.
Next time I will build a truss jig and put some thought into how I can get a consistant 5/8" headstock. Still need a good template for fret slots too. Unless I'm missing something that should be all I need to make an actual attempt.
