Old November 6th, 2009, 03:49 AM   #41 (permalink)
maumari's Avatar
The return of the day #XX + N
Again, I went with the body routing.
Started with controls cavity, continued with bridge pickup, then neck pickup
I'm completing an MDF template, it's tricky without it!
Then I started drilling the strings through body holes, installed the bridge and signed the holes.
Unluckily my drill press has not enough space to drill the holes with it, so I used the Dremel with a simple jig to drill vertical holes (where vertical is just an opinion...), and as you can see the holes are "perfectly" misaligned!
So I turned the body to drill the other half of the holes, to make them encounter on the half way.
I measured the things and fixed the bridge to sign the holes, then I drilled again and surprisingly 4 of the holes match almost perfectly, the other 2 holes are still wandering to meet each other...
to be continued
Mauro
maumari is offline   Reply With Quote
Old November 8th, 2009, 12:40 PM   #42 (permalink)
maumari's Avatar
...continuing
Finally I've got too the "swine flu" (like the rest of my family) but I tried the same to recover the misaligned situation. Sorry for the phone shots.
First tried to re-align by counterclock routing the top of the holes with a drill bit for metal with the correct ferrules width.
Then begun to drill the holes
Just the last one got a little out of the signs
For today it's enough, gotta go back to bed (cough cough) with my fever...
My new Tele build from scratch dandhr61 Tele-Tech 37 December 25th, 2008 06:14 PM
How do Tweed Twins compare with BF Twins? dangelico603 Amp Central Station 13 February 24th, 2008 06:44 PM
Building a Tele from scratch wonderhorse Telecaster Discussion Forum 24 June 5th, 2006 10:12 AM
Making a Tele from scratch... jimmiboots Telecaster Discussion Forum 3 December 20th, 2003 10:46 AM
Tele from scratch; needs list deadrunner Tele-Tech 1 November 9th, 2003 07:17 PM
