Not first tele, but first thinline tele!
Here's my new project, a thinline telecaster!
It will have an ash body with a 6mm maple top, 2 humbuckers (no pickguard), strat hardtail bridge, an F hole, binding, custom inlay and maybe even some body inlay. The neck will be maple with rosewood. Here's wood I'll use: ![]()
Awaiting progress!
While this is still in somewhat ideal stages, may I submit this for consideration? ![]() Oh, and I think an abalone-bound f-hole would be SEXY...
... Please do not insinuate anything sexual from that. |
Finish is great!
But as I said, it will be a standard tele shape with those elements listed in my first post here! But I could make this finish, it very good! And I forgot to say in my first post, it'll have 3W switch, but I'm not sure if I'm going to put standard tele 3W switch or LP 3W switch like on this one.. |
#4 (permalink) | |
Lord, please give me compassion for the innocent that I see and help me protect and serve those that depend on me. |
One big chamber is routed! I still need to route about 1/2mm deeper to remove burning marks. This was made without any templates so the edge is not evenly thick, but it's ok.
![]() And here's how the top should look:
Do you think you've left enough wood in the areas where the strap buttons and jack socket will go?
I didn't and luckily someone here noticed. I had to glue in some blocks. That drop-top looks very nice. |
#16 (permalink) |
I had some abs at home, it was 2mm thick and 22mm wide.
I made a simple jig: ![]() With just enough space to put that piece of abs (on this pic you can see just one little piece, the real one was about 1,5m long) ![]() And I got 2 stripes of abs, one 8mm thick, for the body: ![]() And the other one about 5,5mm wide, I will probably put this one on the fingerboard:
#17 (permalink) |
How about posting larger pictures instead of the thumbnails? Since you're using PhotoBucket, all you have to do is copy the IMG Code line below the thumbnail and paste that into your post.
#19 (permalink) |
I realize that. That's not the point. It easier for the reader to view larger pictures in the post and not have to go back and forth from the TDPRI page to your PhotoBucket pictures.
#24 (permalink) |
Thanks.
I'm going to stop for a while with this build (I don't have any hardware, no pups, and I have to buy a dremel tool to make some inlay in the fretboard) so what I'm doing now is a telecaster (alder) for a friend. ![]() ![]() ![]()
#35 (permalink) |
routing
hey can you tell me how you did the interconnecting routes from the control cavity to the pickup cavities?
did you drill from the control cavity or from the pickup cavities? and is it comfortable/accurate to drill within such small spaces? appreciate the feedback. |
#36 (permalink) |
first I drilled a hole from the neck pocket through pup cavities
![]() And I drilled a hole from bridge pickup cavity to control cavity (I have no pic of that) I used long drill bit (about 20cm) and I didn't have any problems drilling it. ;) |
| Squier Standard Tele vs. VM Thinline Tele | Crying Minotaur | Tele-Tech | 11 | January 18th, 2009 02:29 AM |
| My Farida Thinline Tele& Fender '60s tele | myfloatingshoes | Telecaster Discussion Forum | 11 | February 15th, 2008 08:32 AM |
| Tone differences between a Tele and a Tele Thinline? | marcb | Telecaster Discussion Forum | 11 | June 13th, 2006 10:31 AM |
| 72 Tele Deluxe vs. 72 Tele Thinline... your thoughts? | blackkeysfan | Telecaster Discussion Forum | 7 | May 24th, 2005 11:26 PM |
| '69 Tele Thinline Add Middle Pickup = Nashville Thinline | zetoz | Telecaster Discussion Forum | 5 | May 4th, 2005 01:22 PM |
