Old May 20th, 2009, 05:41 AM   #1 (permalink)
scubadoo's Avatar
Drill bit size for Kluson tuner bushings?
Morning all,
I'm getting stuck into my neck build and have come to drill the tuner holes.
I've done some tests with a 9mm and 10mm bit. Now the bushing that comes with the Kluson tuners is too tight with the 9 and too loose with the ten. Should it be a 9.5mm hole?
For the life of me I cannot find a 9.5mm brad point bit. I know i could just ream out the 9m hole but I'd like it to be right from the start.
Any thoughts?
Cheers
Dave
scubadoo is offline   Reply With Quote
Old May 20th, 2009, 07:55 AM   #2 (permalink)
Fortsbest's Avatar
Originally Posted by scubadoo View Post
Morning all,
Any thoughts?
Cheers
Dave
I bought a 9.5 mm bit from a local industrial supply place for about 8 dollars U.S.
Lord, please give me compassion for the innocent that I see and help me protect and serve those that depend on me.
Fortsbest is offline   Reply With Quote
Old May 20th, 2009, 09:12 AM   #3 (permalink)
Hmmm....9.5 is .3745...close to our 3/8 bit. I use an 11/32 for the vintage Kluson tuner inserts. 9.5 seem way to big. At least that's what my memory serves me...I think...!! I think 10mm is what the modern tuners use.
ehawley is offline   Reply With Quote
Split-post vintage kluson style tuners....conversion bushings?.... CDKopf Tele-Tech 4 November 16th, 2008 01:37 PM
Drill Bit Size On Tuner Modification? castpolymer Tele-Tech 4 July 23rd, 2008 12:42 PM
How do you remove Kluson bushings?? Monkey Man Tele-Tech 8 June 24th, 2005 01:39 PM
Installing Kluson bushings on a maple neck... Cobra Tele-Tech 1 June 7th, 2003 11:05 AM
Weight issue - RG38 or kluson style with bushings? JWK Tele-Tech 2 April 13th, 2003 03:43 PM
