Shielding opinions: paint or foil?
I'll be doing this soon on my first partscaster with a fresh body, and the thing only I can tell is:
1) shielding paint is expensive but looks much much easier 2) copper is cheaper but seems like a major pita (and blood letting) If this helps, I don't gig or play at excessive volumes, I'll be using a 3 way control/switch assy from a donor MIM Standard, and my choice of pups (for now anyway) is an SD Vintage '54 Tele bridge and an SD SSL-2 Strat neck. As always, thanks in advance Tom |
I prefer to use the foil, cuz if you ever decide to remove it you can. Some people claim it affects tone. Perhaps it does, but my hearing isn't good enough to tell. (Severe ringing in both ears).
I used the foil for the cheap aspect. It works, but I thought it was a pain the the backside to install. To get it looking nice and smooth was hard and my fingers were ripped to shreds as a result.
I'm going to try the paint next time. On instructables there is a howto for making your own. I may try that. The link is below. it talks about glue but there is a section on paint as well. http://www.instructables.com/id/SEOH3GFFABRWUOD/ |
Why do it at all then? Unless you need something quiet for recording I can't see why one needs a sheilded guitar.
![]() _____________________________________________ confucius said: man who want pretty nurse, must be patient. |
I use the copper tape with the conductive adhesives. I cut the pieces to the approximate shape, then smooth them into position with a pencil eraser. It works great. My unshielded guitars hum like a megawatt transformer; my shielded ones are dead silent.
Oderint Dum Metuant - Caligula Caesar "of those men who have overturned the liberties of republics, the greatest number have begun their career by paying an obsequious court to the people; commencing demagogues, and ending tyrants." - Alexander Hamilton |
I shielded my partsesquire with the graphite-based paint that StewMac sells. It was very easy to do - water based so easy cleanup - and the guitar is now dead quiet. It looks pretty good too.
I did use a little self-adhesive copper tape to connect the cavities to the control plate and bridge. I plan to do the same on my next assembly. |
How about some photos, amigos?
mud
MudBean Music Nekkid Bart: "This is the worst day of my life." Laffing Homer: "Worst day SO FAR!!" |
Kitchen aluminium foil works just fine, if you can work with it without breaking it. But even if you leave a couple tiny holes, it's a huge improvements over just a pickguard shield.
I put it in using the paper glue sticks that you give school kids. Works fine and is removable with no problems. |
#17 (permalink) |
The copper tape works fine. Just use the 1" wide one and move slow and overlap. Your fingers will be fine as long as you don't drag it across the edge (which will happen, haha). I use it every-time, takes an hour or so, but no hum.
"There is nothing like the smell of "Twang" in the morning" - Arlo |
#18 (permalink) |
Four shots.
