Old April 29th, 2009, 04:08 PM   #1 (permalink)
GhostofJohnToad's Avatar
How do you make tummy cuts and forearm cuts?
I am assuming some spokeshaves or the like? But how do you design for them? Is it like picking two points on the body and sanding a chamfer to the edge retaining a certain thickness when you get to the edge?
Getting close to starting a build from scratch and wondering whether it's worth it or not to try. I'd hate to do ok on everything and then botch it big time trying.
GhostofJohnToad is offline   Reply With Quote
Old April 29th, 2009, 04:40 PM   #2 (permalink)
jwells393's Avatar
I actually copied this one from a Japanese Telecaster that had the back coutour. I roughed it out with a 7 in. disc sander then cleaned it up with an orbital sander.
The back contour on a Stratocaster is drawn by drawing an arc with a 7 3/4 in radius connecting two points 12 3/4 in. apart. The center of the contour stops 5/8 in. short of the front.
This Stratocaster blueprint might help.
http://img.photobucket.com/albums/v2...P2642x1757.jpg
Old April 29th, 2009, 07:03 PM   #3 (permalink)
Shepherd's Avatar
Are you building a Strat? I just did a couple and just went off the blueprints and used one of these on a grinder. It's actually really neat to see it take shape. Alot of people use belt sanders. If your doing something custom, probably just draw it out until you get something your happy with. If you do screw it up you can always use filler. Dont ask me how I know this
Shepherd is online now   Reply With Quote
Old April 29th, 2009, 07:20 PM   #4 (permalink)
jefrs's Avatar
Freehand on cushion drum sander and flap sanders.
jefrs is online now   Reply With Quote
Old April 29th, 2009, 07:34 PM   #5 (permalink)
actually a jazzmaster. Shhh.
Old April 30th, 2009, 07:59 AM   #6 (permalink)
jkingma's Avatar
I do my forearm cut on a jointer. It takes about 2 minutes. It requires removing the guard, so if that makes you nervous, don't try it!
First, which double sided tape I stick on a piece of 1/4" scrap along the line where I want my cut to begin.
Then I draw a line on the back following the same line on the front for "eyeballing" purposes so that I can keep the body lined up with the fence of my jointer.
Then using a push pad to tilt the body I make 10 or 12 passes on the jointer to shape the forearm cut.
Lastly, I round over the cut with my random orbit sander.
The result is not as "round" as a normal Strat cut... but a couple more minutes with the sander can fix that.
Don't forget to put the guard back on your jointer!
Old April 30th, 2009, 09:44 AM   #7 (permalink)
VENDOR
Ronkirn's Avatar
how I have done it. . .
http://www.tdpri.com/forum/stratocas...sed-strat.html
Ron Kirn
www.ronkirn.com
Old May 1st, 2009, 01:12 PM   #8 (permalink)
ramseybella's Avatar
I did mine with a rasping file and sand paper.
ramseybella is offline   Reply With Quote
Old May 1st, 2009, 01:50 PM   #9 (permalink)
Good advice guys thanks. I guess I need some more tools.
Old July 28th, 2009, 12:08 PM   #10 (permalink)
Joel Terry's Avatar
Ah HAAA! So it CAN be done this way! I've thought about doing it this way. I just bought two a couple of trem-loaded Tele bodies, and I simply can't afford to have me (the incompent oaf that I am) let a disc sander get out-of-hand and mess them up!
Call me a sissy about the disc sander, but I figure I'm safer taking the ol' manual route.
Thank you for letting me know that this can be done, you magnificent southpaw.
And, apropos de bottes, thank you falletin me be mice elf agin.
Joel
Currently reading: Jack Lord Was An Insufferable Ass; For Example, His Christmas Gift To The Cast And Crew Was Passing A Roll Of Clorets Mints Around: Bitter Recollections From The Set Of Hawaii Five-O by Kam Fong as Chin Ho
Joel Terry is offline   Reply With Quote
Old July 28th, 2009, 12:27 PM   #11 (permalink)
MikeMurray's Avatar
I used a rasp, surform and lots of sandpaper on my body. Will definately use a larger surform next time, it really does the trick.
MikeMurray is offline   Reply With Quote
Old July 28th, 2009, 12:32 PM   #12 (permalink)
There is a tool sold called a Ferrier's rasp ( for horseshoeing and woodworking) and it is a couple of inches wide with big sharp teeth. It won't take too long doing contours with that, but it requires some muscle power. I'll use that on less denser woods like swamp ash, basswood, and pine.
Old July 28th, 2009, 01:23 PM   #13 (permalink)
I used a hand saw and a vice,then a sander for a forearm cut. I was shocked at how good it came out.
craigoslo is offline   Reply With Quote
Old July 28th, 2009, 10:00 PM   #14 (permalink)
I use an angle grinder with a flap disc attached and finish up with an orbital sander
http://i637.photobucket.com/albums/u...d/DSC_2145.jpg
fletch is offline   Reply With Quote
Old July 28th, 2009, 10:53 PM   #15 (permalink)
fishtownmike's Avatar
I use a spoke shave. I just pencil in the back and sides where the cut will be and shave away then sand. I'm thinking of getting one of these in the link below to help do this. I also have a few other ideas for it.
http://grizzly.com/products/7-1-2-x-...-Sanders/H2882
fishtownmike is offline   Reply With Quote
Old July 29th, 2009, 02:02 AM   #16 (permalink)
A good rasp is hard to beat. Never had to replace a cord on it !!!!!
shoretyus is offline   Reply With Quote
Old July 29th, 2009, 09:57 PM   #17 (permalink)
Originally Posted by Ronkirn View Post
I like this idea. I have a grinder and one of those sanding flap disk. I just never thought of using it for that. Good tip!
Old August 3rd, 2009, 03:54 PM   #18 (permalink)
For mine i used a coping saw, rasp, really small plane, and a sander
Nicktarnow is offline   Reply With Quote
Old August 4th, 2009, 12:32 AM   #19 (permalink)
Sand, sand, sand...
Bought real rough sand paper (60 maybe). Put it on a palm sander and went at it.
Came out nice and my forearm and gut like it.
More of a taper than a cut though.
blimpo is offline   Reply With Quote
Tummy Cuts mralmostpopular Tele Home Depot 12 February 22nd, 2009 01:16 PM
Tummy Cuts on Teles.... Freedom Fries Telecaster Discussion Forum 83 December 9th, 2008 05:59 PM
Forearm and body cuts celeste Tele-Tech 8 October 13th, 2006 06:58 AM
Tummy Cut and Forearm Cut maxbruch Tele-Tech 27 September 16th, 2005 05:19 AM
Tummy cuts and arm contours TonyBlack Stratocaster Discussion Forum 7 May 28th, 2003 07:19 PM
