Old April 25th, 2009, 08:17 PM   #1 (permalink)
My Very First Custom Tele . . .
. . . come to think of it, this will be my very first Telecaster, period!
A custom relic'd Tele, built by Mike (Kundracik Guitars).
http://bayareaguitarswap.com/topic/43
Tricone is offline   Reply With Quote
Old April 25th, 2009, 08:47 PM   #2 (permalink)
Stuco's Avatar
Nice! Welcome to the forum!
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Old April 25th, 2009, 09:24 PM   #3 (permalink)
Thanks, Stuco!
Old April 26th, 2009, 12:04 PM   #4 (permalink)
BTW, I'd appreciate any input or comments regarding this build. By all measures, I'm a Tele newbie. I'm having a Glendale bridge and Greenwich-modified Lollar pickups installed, on recommendation from the builder. I'm familiar with Lolllars, as I have a set of Imperial High Winds in my SG Standard. The rest of the build, I have absolutely no clue.
Again, any comments or suggestions would be highly-appreciated, both here, or preferably at this website, so the builder can see the comments:
http://bayareaguitarswap.com/directory
(Look for the "My Custom Tele Build" thread).
Thanks!!!!
Old May 3rd, 2009, 06:36 PM   #5 (permalink)
A custom relic'd Tele, built by Mike (Kundracik Guitars). Updated pics:
Old May 3rd, 2009, 07:03 PM   #6 (permalink)
Dababy's Avatar
Should be awesome! Looking good already. I'm a big fan of Nels' playing too. He's got a style all his own.
Check out my website: Indie/ alt country/ praise & worship/ blues. Is that a genre? http://www.wix.com/JoelSkaggsMusic/dababyguitar
Dababy is offline   Reply With Quote
Old May 3rd, 2009, 08:09 PM   #7 (permalink)
Tim73's Avatar
Looking good. The Glendale stuff is great. There is nothing quite like owning a custom built guitar. Welcome to the forum
Born in the '70's & in my mind, still living there now...
http://i38.photobucket.com/albums/e1...oodooTDPRI.jpg
Tim73 is offline   Reply With Quote
Old May 4th, 2009, 10:49 AM   #8 (permalink)
Thanks Tim73 and Da-Baby! Any suggestions, or is it on its way to having that Tele mojo?
Old May 8th, 2009, 08:18 PM   #9 (permalink)
Have some updated pics:
Old May 10th, 2009, 04:01 PM   #10 (permalink)
Bump . . new pics added today.
Old May 13th, 2009, 07:25 PM   #11 (permalink)
It's moving along. Primer!!
Old May 15th, 2009, 04:31 PM   #12 (permalink)
First coat of lacquer! It's moving along!
Old May 27th, 2009, 01:10 PM   #13 (permalink)
Time to relic the hardware:
Old May 30th, 2009, 03:24 PM   #14 (permalink)
More pics posted of the relic'd hardware. Does it look vintage??
http://bayareaguitarswap.yuku.com/topic/43
Old June 2nd, 2009, 03:03 AM   #15 (permalink)
olaftheholy's Avatar
Tricone; what is the chemical agent you use to aggrevate the chrome bits?
You could help me out by answering as i'm in the progress of relicing a tele...
edit ; found it out myself!
www.olaftheholy.nl
olaftheholy is offline   Reply With Quote
Old June 2nd, 2009, 10:16 AM   #16 (permalink)
I'll try and find out anyways. What was your findings?
Old June 2nd, 2009, 10:19 AM   #17 (permalink)
nasonm's Avatar
Tricone, that is some nice work!!!!!
"i have learned to just grit my teeth, change the subject, consider their deep total ignorance, fondle the thumb picks in my pocket and go on my way" - bender-freak
It's been lonely in the saddle since my horse died
nasonm is offline   Reply With Quote
Old June 2nd, 2009, 10:20 AM   #18 (permalink)
Hydrochloric acid or "zoutzuur" in Dutch ;o)
www.olaftheholy.nl
Old June 2nd, 2009, 10:32 AM   #19 (permalink)
Here's what the builder stated:
". . . it's Hydrochloric, or Muriatic acid. Pool acid! You can buy it at
any pool supply store. I also use Ferric Chloride, which is used to etch
circuit boards. That works well for screws and other things that the HCL
doesn't etch or oxidize enough."
Of course, the stuff is caustic, so use safety precautions!
Old June 2nd, 2009, 10:59 AM   #20 (permalink)
and a bit more detail:
"You should tell them to pay attention to the way the parts are placed. The large items are placed flat on the bottom so only the tops age. That way you don't have roughed
up areas on your bridge plates that can cause harmonic issues and poorly seated control plates.
The bowl with the small parts has little holes drilled in it for the fumes to flow through. Then the parts must be checked and some are chrome and some are nickel and they all have different thicknesses, so different ones age at different rates. Some only take hours and others take days. I tried to make note of this as I posted the pix. It also of
course depends on the look and year you're going for.
There are other ways, but this is a very easy and clean way of doing it.
Just sand and scuff, then let it do it's thing..."
