#21 (permalink) | |
Compare these two charts made using the StewMac Fret Calculator. See how the 25.5 scale fret to fret beginning on the second fret compares with the 22.75 scale fret to fret beginning at the nut. The numbers only differ by 1 or 2 thousandths.
...... ![]() Another way to look at it........... On the 25.5 scale 2nd fret is 2.782 from the nut. Twelve frets from the 2nd fret ...... the 14th fret is 14.141 from the nut. The difference: 11.359. Double that......... 22.718 .......... not exactly what I was hoping for but close...... 32 thousandths short of 22.75 ...... about the gap on your spark plugs. I'm going to blame it on the StewMac calculator. As the picture below shows, if I line the mini neck nut up with the first fret of the 25.5 neck, the frets don't line up further down the neck. Compare it to the earlier picture where I lined the mini neck nut with the 2nd fret. ...... ![]() Quote:
. Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" I'm just not cool enough to be a Mac person. I'm a PC and Windows 7 was my idea. |
#23 (permalink) |
Great build . During my research on guitar design , I remember reading that scale is determined by measuring from the nut to the twelfth fret , then doubling that distance . not by measuring from the nut to a specified distance . Is my memory failing me ? I think that it would look funky with the rear set bridge . If you don't want that template , may I have it ?
#27 (permalink) |
The 22.75 scale Squier Mini-Strats do have a truss rod. You're right that 9s or 8s on such a guitar wouldn't create much bow on the neck. Squier does supply the Mini-Strats with 9s but they do play better and maintain tune better with heavier strings. I've put 11s on a few Mini-Strats I've refinished.
Since the scale length is short, when turned to concert pitch, there's not as much tension in the strings as a full sized guitar. Using light guage strings, there's even less tension. With 8's the strings would be very slack. Fender Japan made some ultra-mini Strats and Teles back around 1993. The scale length was something like 18 in. These had no truss rod. I think I put 12s on them. You could go ahead and build the neck without a truss rod. It would probably be fine. If not it could probably be added later. If it works OK without a truss rod, it would surely make building a Mini-Telecaster easier. Let us know how it works out.
#28 (permalink) | |
try 9s or 10s. I am definitely trying a neck without truss rod, only problem is I can't make it to fat since it is for my 5 year old son. But like you say, one could always add a truss rod later if problems occur. |
#29 (permalink) | |
Great build thread BTW! Learning loads of good info here! |
#30 (permalink) | |
I would love a copy of this drawing. Either format or both. Thanks
Did I mention I was cheap Proud member of IGPA Ed |
#34 (permalink) |
With regard to the PDF, I don't have a PDF. It's appears Superc_1 has one.
I cropped the body outline in Terry's drawing using the Snapshot Tool, pasted it into IrfanView, reduced the length to 14.5 in.. I then cropped than Jpeg into four overlapping quadrants printed the quadrants and taped the four sheets together to make my pattern....... sort of a cave man method. All my guitar work has been on a back burner for the past few weeks. I've got a few projects going. I need to get back to them and update the threads. Hardlock .............. that undersized body only has the neck pocket routed. Location of other cavities would depend the scale length of the neck used. Would you want it as is?
#36 (permalink) |
Pulled this little guy off a back burner earlier this evening. Looks like it's been over a year since I did anything on this project. (One of many I've started and not finished.) Took about a half hour to find the neck. It had fallen behind a workbench. I fretted the neck, drilled the ferrule holes and fit the neck to the pocket. I'll try to get it finished before another year passes.
#39 (permalink) |
I bought a flame maple blank for a neck but it's about three inches short for a full size. I'd considered a scaled down travel size. Now I know I can do it!
If only my taste for guitars equaled my ability to play them!! |
