some of my jigs and templates
so.....one day last month i decided to make me a Tele and doing a google search for tele blueprint brought me here to tdowns Rev D PDF then to ehawley's '53 CNC build thread, thats all it took to get me started, I only had to buy a router , everything else i had laying around, so i started making my jigs and templates
these were easy enough ![]() then the neck stuff neck template ![]() and truss rod jig ![]() fret slot cuttin jig
Nice setup. Looks like it's under control - down to a science.
The radius sanding block... did you make that yourself? If so, how? and what radius are you making them? a skunk stripe and a glued fretboard? or a couple of each? I like the warm color of the body on the white guard in your other post - what kind of wood is that? questions questions questions... |
Thanks for sharing your setups.
Looks like you have the bases covered.
#7 (permalink) | |
the camera batteries were dead when I did these but I screwed the router to a board, plunged a hole and measured 7.25 and 9.5 from the front of bit and nailed it to the bench so that it swung side to side ![]() ![]() then cut a bunch of pieces of 3/4" wood to this shape ![]() then glued them all together ![]() the necks are all solid maple, the white guard tele is made of oak from an old antique table that was sitting around in my way, it was almost black, I just sanded it and cleared it, the oak tele neck was a piece of the table that was 7/8" so i guess i did glue on a 1/8" piece of maple to get 1" after i did the skunk strip on the back, that was a practice piece anyway |
Awesome shop! and for what you showed awesome a pure quality results! BTW that leather strap pf the sexy cowgirl its fantastic! |
#12 (permalink) | |
Awesome set up - wish I had a shop like that. Nice work on the leather too. What kind of dye did you use for the black horizontal box across the girl's chest? I've never seen a leather dye that opaque...
Every now and then I know it's kind of hard to tell, but I'm still alive and well. |
Well that's the thing about oak furniture, isn't it? It's much easier to carry around in telecaster sized pieces.
I do like the pecan shade of it in the picture. the sanding blocks - simple and elegant. Thanks. I had some sort of brain block as to how it could be done. Visions of the tip of a belt sander swinging back and forth on an adjustable swing set were going through my head. |
#19 (permalink) | |
Ouch. have you been introduced to www.mcmaster.com? barrel nuts - threaded standoffs as many taps as I've snapped... |
#21 (permalink) |
Hi Lee,
I like your cool sanding jig. You might be interested in checking out my router version on www. luthiersforum.com and mimf. Search for McClary jig. More chips, less dust, less time, and I think you could adapt it to your rails pretty easily. I love jigs. :-). That is quite an art in itself that leatherwork you do. mimf.com/library/fingerboard_radius3.htm Marty |
#23 (permalink) | |
#25 (permalink) |
I always did think that would be a perfect jig to dedicate to one of the cheap laminate trimmers you can get for 20 dollars at harbor freight since very little material is removed from the neck or fingerboard. Maybe I'll do a new version.
#27 (permalink) |
i want boobies on my strap! Do you make straps to sell? Where would one go about checking out what you have?
Awesome workshop and jigs by the way, looks like you have it down to a T |
#28 (permalink) | |
Someday...when I have the room...
#31 (permalink) |
On that fretboard radius jig - if you were to put two slightly different radii on the two arcs of the router base, and skew the guide rods so they're not parallel - aside from entirely unpredictable results would that give you a way to get a conical/compound radius?
Trying to avoid reinventing the wheel here since I'd bet one of you talented people has come up with it already. I was thinking about a sled on the router table but it would be more complicated than this jig. Also, gotta say, I've never seen sculpture in leather tooling anywhere else.
#32 (permalink) |
I'm fairly certain you won't get a compound radius..
in order to get the compound radius, you'd need the different radius on each end of the fretboard and the router would need to travel down the length of the fretboard (while those radiused rails stay in the same place) http://www.cambrianguitars.com/compradjig.html Last edited by LocustPlague; February 3rd, 2009 at 02:15 PM.. |
#33 (permalink) |
I don't do compound radii. My jig runs in a matching bottom section with the same arch as the top, like what is on the bottom of a band saw table that allows it to tilt. Check out the luthiersforum for more variations for compound radius jigs.
Marty |
#35 (permalink) |
Both, on my jig, I tilt the router by pushing it forward on the arc and then running it left and right. Push router forward some more, repeat left to right. You do this until it is arched. Takes about 2 minutes or less. I finish up with a radius block to remove tool marks.
Marty |
#39 (permalink) |
today I needed a planer after making a body to thick, so I found an old vinyl window frame, some PVC water pipe, old ceiling light track, piece of plywood and two little 2x4 pieces, screwed on my router and BAM!, got me a planer
#40 (permalink) |
The ideas that you are giving me!
Thanks again.
