Old January 9th, 2009, 07:54 PM   #1 (permalink)
ChicknPickn's Avatar
P90 in Standard Humbucker Route?
I'm gearing up to build a Tele with a Kent Armstrong P90 soapbar in the neck and a Lawrence Keystone in the bridge. Can anyone tell me whether the P90 would fit well in a standard humbucker route, and is there anything I need to do differently with the electronics?
ChicknPickn is offline   Reply With Quote
Old January 9th, 2009, 08:29 PM   #2 (permalink)
Pots and caps should be the same as humbuckers for your starting point (500K vol, 500K tone, .015 or .022uf tone cap) BUT, the route is not the same. Different shape, different width, different depth, mounts a different way. Not interchangeable with a humbucker as to the route and mounting.
Old January 9th, 2009, 08:32 PM   #3 (permalink)
Formerly known as Eryque
KokoTele's Avatar
What Wayne said. If you really need to go with the humbucker size, there are P-94 pickups, which are P-90s in a humbucker frame. There are a few manufacturers making them, so you get a little bit of choice there.
Parts & Pickups
www.kokoteleguitarworks.com
Old January 9th, 2009, 08:50 PM   #4 (permalink)
Thanks, fellas. I reckon you can tell I've never built anything with P90s. I'll be much obliged if someone can point me to some tried-and-true routing instructions for these pickups.
Old January 9th, 2009, 08:58 PM   #5 (permalink)
mgwhit's Avatar
StewMac has router templates for most pickups -- here is the P-90 soapbar template. Not sure about depth.
As for P-90's in humbucker form factor, I'm pretty happy with a Rio Grande Bastard in my neck position.
mgwhit is offline   Reply With Quote
