#41 (permalink) | |
Cheers ED |
#42 (permalink) |
I was referring to what appears to be a misplaced bridge mounting hole.........maybe it has another purpose.
How long does it take to cut the cavities......... for instance how long for the bridge pickup cavity?
#43 (permalink) | |
![]() ![]() 53 build pics of the nails and body on the "lazy susan" This guitar took about 38 min to cut. after it was cut to thickness. I'm getting faster! Cheers ED |
#44 (permalink) |
Here's a loop I writed to run though your 'puter that makes the ferrule holes look like Leo drilled them.
while (aBitDrunk = true) { x = aBitToTheLeft; y = aBitToTheRight; z = faGetaBoutIt; for(something; meh; x++){ drill(x, y, z); return(); } }
#45 (permalink) |
Ah ..............I understand now. I refinished a 1960 Strat once. It had the nail holes and I used them.
#46 (permalink) | |
Hey Nick...here's my little touch of Australia..My blind Silky Terrier named Matilda.... ![]() Cheers ED |
#48 (permalink) |
yup...we went to have them removed but she also had retinal problems so they wouldn't operate She gets around fine....inside, outside...Still chases squirrels by the sound of them running. They give her no respect!! Cheers ED |
#49 (permalink) |
I've never seen a CNC build. This should be interesting.
Cute puppy. Was she born blind?
"Everybody wants to go to Heaven, but no one wants to die to get there!" -B. B. King |
#52 (permalink) |
My pleasure guys
Edutainment...she went blind about 6 years ago. She is already 15! I just finished roughing out the back of the "veneer" neck. Pics will be posted tonight! Cheers ED |
#53 (permalink) |
The back of the verneer neck has been cut. This is not the neck that will be going on the broadcaster. This is a neck I am making to replace a neck on one of my other guitars.I thought that it would be interesting to do because you don't see anyone making these much. It differs from a slab rosewood neck in that the fingerboard is a thin piece of verneer glued to a curved maple top.The markers and side dots are MOP. Fender used this method in the 60s'. There is no skunk stripe on the back of the neck because the truss rod is inserted in a slot under the fingerboard. This result is one of the nicest looking necks in my opinion.
The raw board is double faced taped to the machine to flycut it flat. This is an end cut from the board, hence the raw area along the edge. ![]() ![]() Once the board is flycut it is flat and I can flip it over to start the machining on the other side. ![]() the board is flipped and a test cut is made to check the fit. I don't need it running off the piece!! ![]() I'm ready to begin cutting. |
#55 (permalink) |
With the back roughed out I drill the mounting holes. Because I make the bodies also, I can pre-drill the mounting holes in the neck and they will be perfectly aligned. I also drill the "template" holes.
![]() With the neck done I pop it off ![]() Some finished flame shots! ![]() ![]() There is still alot of hand shaping to be done on the headstock. But that is the fun of it!! I have to do some things by hand! I still have to cut the top side and route for the truss rod. I won't cut the top radius until I pick the verneer. I want a 9.5 radius on the neck so I have to cut the radius on the maple 9.5 - the thickness of the verneer. I have to get the verneer first. I'm off to Willard Bros. thursday to pick out the rosewood verneer for the finger board. I'll have pics when I get it. In the mean time I will be routing the radius on the body and doing alot of sanding. Pics of that to come! Cheers ED |
#60 (permalink) | |
Thanks Cheers ED P.S. I used to use a 2 flute...you could cut faster and higher RPM, but for some reason the finish wasn't as clean and there was more tear out in the ash! |
#62 (permalink) |
Thanks Gaber...
The weight of the body is just a hair under 5 lb (4lb 15 1/2 oz to be exact) The guitar should come in just under 8 lb. Most of the ones I build come in around that mark. Not too heavy and not to light! Right in the middle of the "Tone" range!.. Cheers ED |
#63 (permalink) |
I can't contribute much to this thread other than that I love watching builds like this, especially since I design automotive tooling on the computer all day so it's nice to see things actually being built.
I'll just drop in a gratuitous picture of my soldering buddy Milo to help tie in with the sidebar in this thread.
#65 (permalink) |
Amazing as always Ed. You're very generous taking the time to take the pictures and provide all the details. Hopefully soon I'll take advantage of our CNC machine's down in our plant using one of your files. You've done an incredible amount of "footwork" with the files you created. Much appreciated. I imagine many hours were involved.
Dan
"I can do it quick. I can do it cheap. I can do it right. Pick any two." - Red Adair |
#66 (permalink) | |||
Cheers all ED |
#68 (permalink) |
The boss just put an order in on a $150,000.00 Onsrut CNC router multi machine for use in the shop.
Now I am setting here thinking about starting Tele body drawings instead of working on what I am supposed to be working on...
So many guitars... so little time. |
#69 (permalink) | |
#70 (permalink) |
Ed, I know I'll be like everybody else on the site, and can't wait till the next post. I'm honored to be able to contribute in some small way. Your builds inspire everybody on this forum in one way or another. Man o' man those are going to be some sweet looking axes when its over. Hot diggie dog. Later and Cheers!
#73 (permalink) |
So, let's say I brought you 10 correctly cut blank's, how many bodies could you accurate produce in let's say a week?
I have access to a CNC and talked to other friends about the possibility to cut bodies. I am wondering, once you have the map, how easy and fast it is? |
#76 (permalink) |
Hi all...Been very busy at work the past 2 weeks! I haven't had much time for building!! BUT...I went to Willard Brothers today to pick out fingerboard wood for the verneer necks. The rosewood selection wasn't much this time around but there was a super selection of Macassar Ebony. I always liked ebony for a fingerboard. Macasser ebony has colors anywhere from a grey_pink to a dark red_black. A beautiful wood. I picked a piece that was dark red in color. Almost the same color of vintage rosewood. Very dark! Here are a few pictures of my find. The piece was 39" long by 1" thick (a true 1" (5/4)) I cut it in half to 19 1/4 long. I can get 6 fingerboards out of it . If I want to take the time and REALLY set up my band saw for re-sawing, I may be able to get 4 pieces from each blank, but I think I'll play it safe and get 3!!
Here is a picture of what I consider heaven! Willard Bros. exotic shed!! ![]() Here is a shot of the ebony... ![]() Nice straight tight grain... ![]() I cut 4 necks out of the piece of flamed maple that Dwight sent me. The ebony will be going on these necks. ![]() Next week I'll be cutting the ebony to glue onto the necks. The finger board side of the necks will be cut for the verneer and the truss rod slot also. I haven't had time to fill and sand the body yet , but that is coming . Thanks all Cheers ED Last edited by ehawley; July 18th, 2008 at 12:05 AM. |
#77 (permalink) | |
#78 (permalink) |
I think there is alot more going on in your cave then mine right now!! Work is (real work!) keeping my "fun" work in check!
On another note, I'm planing another "RT 66" trip this winter. I'm going to stop along the way and visit fellow TDPRIers. You are on my list if you would like to join me for a few quick ones!?! We'll talk about it when the time gets closer! Alot of you live along that great road! Cheers ED |
#79 (permalink) |
Wow Ed, glad I finally stopped lurking at the right time! Loved watching your thread. I wont lie, I've been using your CAD files on my own CNC (SCM Tech99 if theres woodworkers here) for a while now.
I wish I could get ours to do 3d dimensional better (ie shaping necks), I have to trick it into doing any sort of rough in. |
#80 (permalink) | |
Cheers ED |
