IKEAcaster #3: the double uncut Tele build
As the original double uncut tele thread is increasingly becoming a photoshop contest for making the most horrible tele abominations, I decided to create a separate build thread for the double uncut tele. This one will become a guitar especially for slide.
For those that didn't read the original thread; this idea is inspired by the Fender TC-90 double cut Tele. Just as the body of that one is a symmetrical, doubled treble side of an normal Telecaster, this one gets a body that is a symmetrical doubled bass side of a normal Telecaster As I am on a really tight budget these days, I'll use only what I have lying around. What I got so far:
Here's the donor guitar. Its body is no more, it ceased to exist, is an ex-body (of plywood). ![]() The first things are done. Following the lines of the Tryggvecaster and the Teiscocaster, I started with a Tryggve plank that's going to be the middle part. I'll make it a hollow body again, maybe with a f-hole, maybe even with two, I''m undecided yet. Here's the middle body part with the neck: ![]() Close up of the body part and the headstock. The decal reads: Goldene Harfe (meaning gold harp in German, though on the backside it reads Made In Italy...)
Next, I started to pre-drill the front and back part, in preparation of routing them out until approx. 0.5 cm thickness.
![]() I have bought a router bit with a guiding wheel... but I couldn't use the middle part as a guide, as i was not thick enough. Didn't think much of it and left it clamped in place. But then... the bit stuck and took a part of the middle part out. ![]() Guess I have two ways to go: make a new middle part, or glue this together. I got enough wood, so I am opting to create a new one. This is how far I am by now.
Not much done today, I finished the routing on the front panel and sanded the front and middle panel. Ready to be glued, if only I had enough woodglue...
![]() Because the neck is meant to be a glued neck, I have to create a joint. I'm going to saw that in the combined front and middle panel using the jigsaw. That way the back panel stays intact. |
Where there's a will there's a way.
This is reminding me of the recent thread about talent and desire. You may not have the woodworking talent(as you have said) but you sure got the desire my friend. I admire your spirit.
Oh...the girls are out to bingoand the boys are gettin' stinko...." Sudbury Saturday Night |
#11 (permalink) | |
I glued the top and middle panel together today. Here is a group pic of my 3 IKEAcasters. The Double Uncut is going to be somewhat shorter, but to me it still looks allright.
A little progress today. This will be the first set neck guitar I ever make, plus I make this up as I go...
Prepared the body to receive the neck joint... ![]() Took a bit of scraping and stuff to make it fit... ![]() Close up of the body... ![]() I might want to shim the neck... ![]() This guitar gets more and more Danelectro feel to me. |
#20 (permalink) | |
MDF templates can be repaired ........ just glue in MDF patches and re-rout.
#21 (permalink) | |
Great evolution of a "parts on hand" guitar, but partscaster? I dunno. |
#22 (permalink) |
Well the idea is that the body is like a Tele body minus the cutout. A Tele bridge would really validate it's Tele status but I like the look of the bridge being used. I'm definitely looking forward to this build.
#23 (permalink) | |
Now I am in a cooling down period. Now I do see the benefit of a table router; it keeps stuff straight and protects from horror scenarios. But: my handrouter is one that operates by pushing and holding a button... therefore it cannot serve as a basis for a table router I think. |
#24 (permalink) |
DOH!!! Nice tear-out bro!!! I haven't seen one like that since the last time I was in the shop!!!
I hope that you can make good repairs and that you managed to keep all of you fingers Bob
It don't mean a thang if it ain't got that TWANG!!!
#25 (permalink) | ||
You gotta have respect for routers. Last edited by tuuur; June 3rd, 2008 at 03:48 PM. |
#28 (permalink) |
tuuur - keep going man! This thread is fascinating and I am looking forward to seeing your progress.
You say you have little woodworking experience but you have loads of talent. Good job!
#29 (permalink) | |
Nice build, by the way. It's a lot different from the stuff in the original thread. |
#30 (permalink) |
it looks to me that the original guitar had steel strings (not nylon) so the neck should be ok as it was built for steel strings. however tuuur would have to confirm it did have steel strings as it is hard to tell from the picture.
EDIT: Tuuur, I was wondering... how thick will the body be when all three pieces are fitted together? Last edited by JasonRobert; June 14th, 2008 at 03:21 PM. |
#31 (permalink) | |
"Everybody wants to go to Heaven, but no one wants to die to get there!" -B. B. King |
#32 (permalink) | |
I don't think the neck has a trussrod (I'm not home, so I can't check). It's a laminated neck with a maple centerpiece if I'm correct. The donor guitar didn't have strings when I got it, so I'm not sure if it's suited for steel strings. |
#34 (permalink) | |
By the look of the neck and headstock I would say it's a pretty safe bet that it came off a guitar strung with steel strings IMO. I don't think you'll have any problems with it in terms of string tension. EDIT: I've brightened up the photo of the 'donor' guitar and by the looks of the bridge it's almost certainly a steel string instument.
#35 (permalink) |
This thing is gonna be cool. When I look at it I think delta blues. Know what I mean?
#36 (permalink) |
So I went on and tried to route the body using the thinner template.
![]() Looks nice eh? But, the horror: ![]() My routerbit is not able to do the body from one side. I had to turn it around, attach the template to the back of the body and do another pass. Turns out the Telecaster template is not exactly symmetrical. ARGH! I left it lying for a bit, and then decided to finish the body anyway. It won't be symmetrical, nor perfect, but hey, Seasick Steve doesn't play perfect guitars and plays a hell of a blues... So this is how it looks now: ![]()
#37 (permalink) | ||
I even made the nut out of a piece of oak. Last edited by tuuur; July 1st, 2008 at 08:24 PM. |
#39 (permalink) |
This is so cool.
Good recovery from the asymmetry. Like so many things, nobody will notice it unless you spill the beans.
#40 (permalink) |
How are you gonna finish it? I think it'd be a shame to hide the grain, not that it's the most beautiful grain in the world, I just think this guitar would look better stained or transparent, not solid.
