String gauge tip - Telecaster Guitar Forum
Old September 24th, 2007, 12:11 AM   #1 (permalink)
String gauge tip
I've used just about every combination of string I can think of over the years , from rediculously heavy , to remarkably light , and dipped my toe into most styles at one time or another .
As i've gotten older , i've started to appreciate harmonies between notes a lot more , and though I still play single note runs , i'm always looking out for the opportunity to add a double stop , triple stop , faux steel bend etc , and i'm really not a country player at all .
After recently suffering a ring finger break , and spending the past 6 months getting my finger working again , I decided that I needed to find a match across the six strings which gave me the flexibility to bend more than 1 string with ease , whilst not losing too much feel or tone in the process .
I'm now playing all my country / blues / tele rockabilly ( not semi ) etc with a set of 9's , but with a twist .
A standard set of nine gauge comprises of :
.009
.011
.016
.024
.032
.042
I'm now using :
.009
.010
.015
.024
.032
.042
I have found that this balances the strings much better , and believe it or not , loses no tone , but actually helps me to do exactly what I want with the strings , therefore increasing dexterity , and also increasing finger speed .
I still have big strings on my semi's , which I tend to bend less with , and i'm fully aware of the ' big string is better ' attitude amongst some players ( I used to be one of them ) , but if you are open minded , and enjoy the lap steel type bends and hybrid picked running double stops etc in your playing , then I really can't promote this gauge balance enough
Especially if you float between 9's and 10's as your normal gauge .
Give it a whirl , and feel the difference
Flat357 is offline   Reply With Quote
Old September 24th, 2007, 01:01 AM   #2 (permalink)
aznrambo481's Avatar
so do you mix and match? or did you find a stock set like this. It sounds interesting, I use 10's and 11's and maybe I could implement something similar...
aznrambo481 is offline   Reply With Quote
Old September 24th, 2007, 09:37 AM   #3 (permalink)
I normally buy spares for the G B E strings about 6 of each for example .
I then replace the G & B with the new 15 and 10 , and simply use the other strings as emergency backup .
This way , my full sets remain full . I normally use Daddario , and have toyed with GHS and DR strings recently too .
Sponsored Links   #
Old September 24th, 2007, 09:39 AM   #4 (permalink)
yegbert's Avatar
Big City String advertises here that they will customize the plain steel strings in a GHS set to your specs for no extra charge. They list the GHS nickel plated steel Boomers here for $4.25.
(I have no affiliation with Big City String or GHS.)
I might try that particular guage spread myself. I like the tone and feel of 9s.
On the 1st/2nd strings' and 3rd/4th strings' saddles in a straight set, that guage spread might provide better intonation than the typical 9/11 and 16/24 pairings.
Old September 24th, 2007, 09:42 AM   #5 (permalink)
all_identaties_taken's Avatar
I had the same thing with my 5 string bass. I swpped the low B for a .125 instead of the .130 that it came with. Much better for what I want.
John.
„Guitar playing is all about ego problems" Blixa Bargeld
all_identaties_taken is offline   Reply With Quote
Old August 26th, 2013, 08:56 PM   #6 (permalink)
I do the same thing 42-32-24-16-12-10
bluescaster72 is offline   Reply With Quote
Old August 26th, 2013, 10:40 PM   #7 (permalink)
teleprompted's Avatar
I started using ghs thin/thick 10-52 and I really like the sound. I came from acoustic and have never liked very thin strings. This is a nice compromise and warms up the bass nicely while maintaining some bite and twang on strings 4,5, &6. Not sure if this is common with teles or not but I just bought ten packs so I might be stuck for a while
teleprompted is offline   Reply With Quote
Old August 26th, 2013, 11:03 PM   #8 (permalink)
Several places online will let you order your own guage strings. I am currently, (as with everything else, subject to change) using 10-12-14-30-34-38. Works for me, but not for everybody.
Used to be a Gibson-holic, but recovering nicely with Teles.
jackal is offline   Reply With Quote
Old August 27th, 2013, 06:38 AM   #9 (permalink)
Donelson's Avatar
Every guitarist who is "any good" should experiment with this stuff to the nth degree. Especially with the plain strings, as they are all about the same, and can be bought for little money.
The OP's choices would be rated by me as unplayable "rubber bands". Yet, he likes them! The way you figure this stuff out to your own "needs" is by trying them all, when you are getting it all together.
Donelson is offline   Reply With Quote
Old August 27th, 2013, 07:08 AM   #10 (permalink)
Otis Funkmeyer's Avatar
To the OP, D'Adarrio Balanced Tension sets might be just what you are looking for. They are designed to have similar tension across the whole set. I use either the .009 BT set or the regular .008s set on my Tele.
Otis Funkmeyer is offline   Reply With Quote
Old August 27th, 2013, 07:46 AM   #11 (permalink)
I use the D'addario version - light top, heavy bottom, Tele and Strat. They work really well for me for the same kind of reasons.
The mighty oak was once a nut that stood its ground
PinewoodRo is offline   Reply With Quote
Old August 27th, 2013, 03:50 PM   #12 (permalink)
telex76's Avatar
I order all single strings. Usually 12 of each gauge in 6 different gauges.
I can get the set I want (I use modified hybrid set 9-46, but lighter G string than used in packaged sets).
I get mine from Just Strings and a bonus is that it's cheaper to buy them this way.
I get 12 sets for the price of what 10 packaged sets would cost.
telex76 is offline   Reply With Quote
Old August 27th, 2013, 03:56 PM   #13 (permalink)
waparker4's Avatar
I have ordered a custom set kind of like this except starting w/ 10.5 from naked strings dot com. I like it pretty ok. Not that different from a set of 10's or 11's though. Not enough to obsess over
waparker4 is offline   Reply With Quote
» Random Photo for Guests
Green Tele Thinline 69 RI
Fender Logan Custom Guitars
