Old February 18th, 2007, 06:06 PM   #1 (permalink)
Administrator
TAB and Chord BBCODES Now Installed
Another guitar website and I hired a programmer to create TAB and Chord BBCODES and they are now installed and appear on the Advanced Post Form.
I think you'll find them self-explanatory... I hope you will because I actually haven't spent the time to check them out in great detail.
Play around with them and see how you like 'em.
Thanks
Paul Green
TDPRI is offline   Reply With Quote
Old February 18th, 2007, 06:12 PM   #2 (permalink)
Leon Grizzard's Avatar
Thanks Paul; looks like it will work fine. Just have to remember to use typeover instead of insert. You take such good care of us.
Leon Grizzard is online now   Reply With Quote
Old February 18th, 2007, 06:43 PM   #3 (permalink)
Larry F's Avatar
Leon, can you put something up for us to look at?
Check out my new book on Amazon: 2000 Blues Licks That Rock!
Larry F is online now   Reply With Quote
Old February 18th, 2007, 07:51 PM   #4 (permalink)
Problem?
One fretboard diagram seems to work fine. Here is the 5th mode of D harmonic minor:
Code:
||---|---|---|---|-x-|---|---|---|---|---|---|---|---|---|---|---|---|
||---|---|---|---|-x-|-x-|---|-x-|---|---|---|---|---|---|---|---|---|
||---|---|---|---|---|-x-|-x-|---|---|---|---|---|---|---|---|---|---|
||---|---|---|---|---|---|-x-|-x-|---|---|---|---|---|---|---|---|---|
Old February 18th, 2007, 07:52 PM   #5 (permalink)
Problem?, con't.
Code:
This doesn't make sense. I deleted the text and it should work correctly. Paul
Old February 18th, 2007, 07:53 PM   #6 (permalink)
Code:
I manually put the line breaks in above but not below in MS IE 6 -- Paul
Code:
That's what you get with two chord diagrams. Paul, should I being these experiments in the experiment section? Duh.
Old February 18th, 2007, 08:27 PM   #7 (permalink)
Super Moderator
Chris S.'s Avatar
Chord test
Code:
||---|-X-|---|---|---|---|---|---|---|---|---|---|---|---|---|---|---|
||---|---|-X-|---|---|---|---|---|---|---|---|---|---|---|---|---|---|
This should be a D chord - let's see how it turns out.
Nope, not working so far. Wherever I put an "X," it moves those "fret" lines all out of whack with the "open strings." I'll keep playing around, maybe in the "test forum" and let you know.
Thx, CS
If you don't change to type over you can delete the extra dashes manually. But that's not right nor good. Paul
"I go online sometimes, but everyone's spelling is really bad. It's depressing." – Tara, from "Buffy the Vampire Slayer"
"It was born at the junction of form and function." – Bill Kirchen, from "Hammer of the Honky-Tonk Gods"
Chris S. is offline   Reply With Quote
Old February 18th, 2007, 08:50 PM   #8 (permalink)
Thx, CS
You need to hit the "insert" key to switch to "typeover." That I have done so does not appear anywhere that I see, as it does in WordPerfect, but it works.
Old February 18th, 2007, 11:11 PM   #9 (permalink)
Administrator
Testing text
Code:
||-x-|---|---|---|---|---|---|---|---|---|---|---|---|---|---|---|---|
||---|-x-|---|---|---|---|---|---|---|---|---|---|---|---|---|---|---|
I just highlight the center dash and then type my X. No insert or replace needed then.
Code:
Chris I know you are on a Mac. Are you as well Leon? I'm trying to figure out why it's working with me. I'm using Firefox. I'll try IE.
Old February 18th, 2007, 11:20 PM   #10 (permalink)
Administrator
Testing with MS IE 6.
Code:
It doesn't work correctly with IE. You have to manually put the line breaks in.
Old February 19th, 2007, 01:21 AM   #11 (permalink)
Super Moderator
Chris S.'s Avatar
Hey Paul. Yes, I am on a Mac, running OSX 10.3.9. I tried viewing this thread with four different browsers:
- Firefox 1.5.0.7, which is what I normally use
- Safari 1.3.2
- IE 5.2 for Mac
- And even an old version of Netscape 7.2
I also tried a variety of fonts, both fixed-width and variable.
In Firefox, I have the problem I described.
In Safari, it was better, but the frets on the "open strings" still don't align perfectly.
In IE, NOTHING showed up in the boxes marked "Code" – nada, zip, zilch. Very perplexing.
In Netscape, same as Safari: better, but still not right.
I dunno if that helps, but that's what I got. Thanks for all your hard work, CS :-)
Old February 19th, 2007, 07:06 AM   #12 (permalink)
Big Tony's Avatar
Code:
||---|---|-x-|---|---|---|---|---|---|---|---|---|---|---|---|---|---|
Code:
This should be an E7.
Tried to insert a new tab code below, but it didn't work.
Instead I copied the first code, pasted it below the E7, and made my changes to an A7.
PC with XP, and Firefox.
EDIT: Tried it again, and this time I was able to insert new code below the first one, by clicking the "Add guitar chords" icon...
/ Tony
{8^)>
Big Tony is offline   Reply With Quote
Old February 19th, 2007, 08:56 AM   #13 (permalink)
I use XP and IE.
Old February 19th, 2007, 09:24 AM   #14 (permalink)
Administrator
Originally Posted by Leon Grizzard View Post
I use XP and IE.
Next time you click the chord box look and see how everything has run together. Manually add a return at the beginning of the fretboard lines to break the tags from the fretboard (I'm not sure this is necessary but it's what I did) and then add double manual returns at the end of the line where the || for the "nut" representation is to break it into separate lines. Don't let there be two line spaces though. It will show up just like it looks on the message post box.
I'm working with the author of the mod to see if I can get this fixed.
Thanks
Paul
Old February 19th, 2007, 09:39 AM   #15 (permalink)
Willie D's Avatar
The Jimi Hendrix chord
Code:
||---|---|---|---|---|---|---|-x-|---|---|---|---|---|---|---|---|---|
||---|---|---|---|---|---|-x-|---|---|---|---|---|---|---|---|---|---|
||---|---|---|---|---|-x-|---|---|---|---|---|---|---|---|---|---|---|
The SRV variation
Code:
||---|-o-|---|---|---|---|---|---|---|---|---|---|---|---|---|---|---|
"I didn't like being young. It just never appealed to me that much. I always thought the adults seemed to be having all the fun. And now I am old, and I'm having lots of fun!" - Elvis Costello
Willie D is offline   Reply With Quote
Old February 19th, 2007, 12:07 PM   #16 (permalink)
stevieboy's Avatar
The spacing problem Chris points out is obviously because on computers each character doesn't have the same width, and the dash is short compared to most of the other characters including the x. I played around a little and found that for me, Mac with Safari, the = and the # are the same size. Here's three varitions, I think the first might be the most easily read. Of course on other systems it might be totally off.
"... I'm gonna show you the inside of me." Albert Collins
stevieboy is offline   Reply With Quote
Old February 19th, 2007, 12:27 PM   #17 (permalink)
stevieboy's Avatar
Also, if the template looked like this
o||===|===|===|===|===|===|===|===|===|===|===|=== |
you could then do this to show muted strings
x||===|===|===|===|===|===|===|===|===|===|===|=== |
o||===|###|===|===|===|===|===|===|===|===|===|=== |
o||===|===|===|###|===|===|===|===|===|===|===|=== |
o||===|===|###|===|===|===|===|===|===|===|===|=== |
On my system, cap X and O don't space right, but lower case seem to.
Old February 19th, 2007, 12:56 PM   #18 (permalink)
Super Moderator
Chris S.'s Avatar
Excellent ideas, IMO. Way to go, stevieboy! And thanks! – CS
Old February 19th, 2007, 02:46 PM   #19 (permalink)
Administrator
= and # are not the same size on PCs and so your fret bars don't line up all neat or anything at all.
On my PC the standard dashed version with a middle X lines up perfectly.
I'm waiting to hear from the guy that made the BBCODE for us.
Paul Green
Old February 19th, 2007, 02:50 PM   #20 (permalink)
stevieboy's Avatar
Paul Green
Too bad. The = sign makes it look like I use really heavy gauge strings!
