Old July 17th, 2006, 03:11 PM   #1 (permalink)
ryokan's Avatar
How to emphasize harmonics?
Any ideas on how to get harmonics to jump out of my tele? Any recommendations on a bridge pickup that will help out? Also, any ideas on amp settings as well? I use a Hwy 1 tele with a HR Deluxe with a pro junior extension cab. I don’t want to use a pedal, I prefer to keep my signal chain as simple as possible. To be clear, I am not interested in harmonics achieved through distortion, but clean, chimey harmonics.
ryokan is offline   Reply With Quote
Old July 17th, 2006, 03:15 PM   #2 (permalink)
Mark Davis's Avatar
Pickups dont make those sounds you do its all in your fingers.
Old July 17th, 2006, 03:20 PM   #3 (permalink)
Tele295's Avatar
Yeah, there are a few things you can do.
1. Use a smaller pick. I use a 358 small jazz teardrop, and they jump easier than when I use a regular 351 shape pick. Billy Gibbons uses a Mexican peso and pinches the heck out of those harmonics. Try a metal pick or a dime.
2. Harmonics jump out easier if you have a lot of volume or gain, even if you're not using it. Turn up the amp if you don't want to use a pedal, pick lightly for regular notes, and lean into the harmonics
3. Akin to the more gain concept, use a very hot, bright pickup, like a Barden.
"Turn it up and it doesn't need any reverb." - Danny Gatton
www.dannygatton.info
Tiger Town Aces - Music That Bites Back
In Redd we trust!
Free Bill Kirchen!
If lawyers are disbarred and clergymen defrocked, doesn't it follow that electricians can be delighted, musicians denoted, cowboys deranged, models deposed, tree surgeons debarked, and dry cleaners depressed?
Tele295 is offline   Reply With Quote
Old July 17th, 2006, 03:26 PM   #4 (permalink)
There are several ways to do it - the master of the pinched harmonics, Roy Buchanan, hit the string with his pick and index finger nail at the same time, preferably close to either the bridge or the neck pickup.(You gotta have rather long finger nails to achieve this.)
Personally, I find it easier to use the pick and middle finger nail, holding my middle finger close to the pick. (Sounds more like Robbie Robertson.)
It's important to hit the string with the pick and the nail simultaneously.
Hope this can be of any help.
Telemarkman is offline   Reply With Quote
Old July 17th, 2006, 03:42 PM   #5 (permalink)
yegbert's Avatar
a few ideas
True the player needs the playing technique to create the harmonics, like those that have now been suggested, but I suspect the right secondary techniques, settings and components can help to emphasize and sustain them.
Aren't harmonics generally high frequencies? I'd try things that foster high frequencies. Keep the treble up relatively high on the Tele and amp.
I think my Teles with stainless steel saddles do better at emphasizing or sustaining harmonics, than mine with heat treated steel saddles.
Try minimizing the pickups' magnetic pull in the strings.
I remember reading that some folks like an Esquire for harmonics, the idea being that the additional magnetic pull on the string caused by a neck pickup inhibits harmonics.
My Duncan APTL-1 bridge seems good for harmonics. AlNiCo 2 pickups are usually less strong magnetically so again they could help compared to AlNiCo 5. And so lowering any pickup from the strings might help for the same reason.
Make sure you're not muting the strings with your palm or fingers, that you want the harmonics on.
yegbert is online now   Reply With Quote
Old July 17th, 2006, 03:43 PM   #6 (permalink)
Practise
Practise
Practise.
chickenpicker is offline   Reply With Quote
Old July 17th, 2006, 04:00 PM   #7 (permalink)
woodman's Avatar
Mojo Picks
Mike McBride, the guy who builds Giant Guitars, also has a line of Mojo Picks he makes out of quarters minted in the year of your birth (or any other year you want). those suckers squeeze out agonized harmonics like nobody's bizness! check them out at www.MOJOpicks.CJB.net ...
i have no interest in his company or anything, he's just a friend who LOVES Tele's (he plays the Muddy model).
BAND PAGES:
Old July 17th, 2006, 04:41 PM   #8 (permalink)
boogaloo's Avatar
+1 Mojo picks
No company affiliation, but I got three from me lovely wife for Easter- man, I love 'em. 'Course you'll cry if you loose one. I drilled one to hang around my neck and am keeping two to use. 1956 vintage (as, I am)! Very nicely shaped and the strikings are in very good to excellent shape for the year.
Brian
"..and I've got some tricks up my sleeve...oh yes indeed! It might come back to haunt 'cha..don't you throw that Mojo on me!"
boogaloo is offline   Reply With Quote
Old July 17th, 2006, 06:25 PM   #9 (permalink)
bradpdx's Avatar
There are IMHO two good ways to coax harmonics out of a Tele or Strat.
You gotta use the bridge pickup - not because it is bright, but because it is located near a string termination, which by definition will have a higher ratio of harmonics/fundamentals.
1. The random squeal
I use a small, stiff jazz pick (brand doesn't matter), turn it about 45 degrees to the string and pick close to the bridge, allowing another finger (I use my middle) to lightly damp the string at the same time. With a little practise and luck, all sort of upper harmonics will be activated due to the combination of:
a. Picking near the string terminus
b. Picking using a very narrow plectrum
c. Damping the fundamental
This works really well for lots of quick and dirty squeals, especially if you are a bit overdriven. Easy and cheesy.
2. The controlled harmonic
Harder to do and harder still to incorporate into improvisation. Like another poster, I use my pick and a finger - in my case, I move the pick grip to thumb/middle finger and use my index finger to select a damping point that corresponds to the desired harmonic.
I just picture the scale or arppegio I want to play in harmonics moved "up" whatever number of frets is required (e.g., 12 frets for octave, 7 frets for 5th, 5 frets for double octave, etc.) and use my index finger to point this out to myself. Look! There they are!
Of course, every song should be ended by playing the 4th fret open harmonic on the G string (that is a nasty, somewhat sharp 3rd) and yanking the G string behind the nut. No one will get the joke but you.
Old July 17th, 2006, 06:44 PM   #10 (permalink)
JerryPro's Avatar
ouch
...it's not the load that breaks you down it's the way in which you carry it.
JerryPro is offline   Reply With Quote
Old July 17th, 2006, 07:22 PM   #11 (permalink)
Moderator
getbent's Avatar
yanking the G string behind the nut....
woo wee... if you can yank the gstring and it is behind the nut, you are in for a sooooooprize!
'never pet a burning dog'
Old July 17th, 2006, 08:25 PM   #12 (permalink)
Moderator
J-man's Avatar
To really emphasize natural harmonics I remove my fret finger as soon as i hit the hramonic, it makes it jump out a lot more.
Write a wise saying and your name will live forever. - Unknown
"The large print giveth and the small print taketh away." - Tom Waits
J-man is offline   Reply With Quote
Old July 17th, 2006, 08:45 PM   #13 (permalink)
seafoamtele's Avatar
that harmonic thang
Seems like I remember reading where Roy said he turned up the treble all the way. . .I've found you can get that sound that way and you hit the string with the pick and the edge of yer thumb - you can change the harmonic & tone by where you pick the string - YMMV
mr.seafoam
seafoamtele is offline   Reply With Quote
Old July 17th, 2006, 09:02 PM   #14 (permalink)
Robert H.'s Avatar
Attack with the edge of the pick and the side of the thumb.
Robert H. is offline   Reply With Quote
Old July 25th, 2006, 09:47 AM   #15 (permalink)
Harmonics are generally hit or miss,and often fluke.
A good starting point is to hit it with the pic/thumb flesh,at the same time,and experiment as to where your right hand should be.Remember though,that there are lots of different ways to play a harmonic including pinched,natural and fretted.You can play a G on the 3rd fret,and with your thumb and middle finger holding the pic,lightly touch your first finger over the 15th fret,and so on.Even the greatest players on earth regularly miss them,and also hit them by mistake,so don't get to hung up where thats concerned.Forget about it being just in the fingers,cause that's just bull.NEW strings help,as does the material and attack of the pic,the bridge,the pup,the amp etc.etc.good luck
firefrets is offline   Reply With Quote
Old July 25th, 2006, 02:08 PM   #16 (permalink)
Moderator
J-man's Avatar
Pinched harmonics are so frustrating, they're fun to use, but I find it very hard to do them consistently.
