Old June 20th, 2006, 05:33 PM   #1 (permalink)
elmerbumpkin's Avatar
"Slippin' Around" by Floyd Tillman
There is a discussion on another guitar forum about Floyd Tillman, and one of my all time favs of his is "Slippin' Around". That song seems like it would be ideal for some chord substitutions and extended chords (not just a I-IV-V7 kinda thing).
Does anyone have changes for that tune?
Thanks
elmerbumpkin is offline   Reply With Quote
Old June 20th, 2006, 08:13 PM   #2 (permalink)
Leon Grizzard's Avatar
This is nothin' fancy; just chunk-chunk with some movement. The C chord in bar one, and the F chord in bar 2 can be played as a regular old F-form; I just like this one.
(In the second line of tab, the G7 walking up to the C, the second chord is named F, but is not functioning as IV chord; it is just a passing chord. You could just as well call it some type of Am based chord.)
Code:
 C     C/B   C/A   C/G     F     Gm7   F     F#dim
-8--8--5--5--5--5--------+-1--1--3--3--1--1--1--1--+-
-9--9--5--5--5--5--5--5--+-2--2--3--3--2--2--2--2--+-
-------5--5--5--5--2--2--+-------3--3--------1--1--+-
-10-10-------------------+-3--3--------3--3--------+-
-8--8--7--7--5--5--3--3--+-1--1--3--3--1--1--2--2--+-
                           First Ending
 G7    F     A#dim G       C     Ebm7  Dm7   G7 G7/b5
-------------------------+-8--8--11-11-10-10-8--8--+-
-4--4--5--5--6--6--7--7--+-9--9--11-11-10-10-10-10-+-
-3--3--3--3--5--5--5--5--+-------11-11-10-10-9--9--+-
-------------------------+-10-10-------------------+-
-3--3--5--5--6--6--7--7--+-8--8--11-11-10-10-10-9--+-
Second Ending
 G7    G7      C / / / / /   C#dim
-6--6--8--8--+-8-------------8--8---+-
-7--7--10-10-+-9-------------9--9---+-
-5--5--9--9--+---------------8--8---+-
-------------+-10-------------------+-
-7--7--10-10-+-8-------------9--9---+-
Bridge:
 G7    G7/F  G/E   G7/D    C     Cdim  C
-8--8--8--8--8--8--8--8--+-8--8--7--7--8--8--8--8--+-
-10-10-7--7--7--7--10-10-+-9--9--8--8--9--9--9--9--+-
-9--9--9--9--9--9--9--9--+-------7--7--------------+-
-10-10-8--8--7--7--------+-10-10-------10-10-10-10-+-
-------------------10-10-+-8--8--8--8--8--8--8--8--+-
 D7    D7/C Bm7Bbm7Am7D7    G7    F A#d G7    G7+
-------7--7--7--6--5--3--+-----------5--6--6--4----+-
-11-11-7--7--7--6--5--5--+--4--4--5--6--7--7--4----+-
-10-10-7--7--7--6--5--4--+--3--3--3--5--5--5--3----+-
-10-10-8--8--7--6--5--5--+--3--3--5--6--7--7--3----+-
Last edited by Leon Grizzard; June 8th, 2008 at 05:35 PM. Reason: Added the matter in parenthesis
Leon Grizzard is offline   Reply With Quote
Old June 21st, 2006, 08:29 AM   #3 (permalink)
Pink Floyd Tillman
That first ending is wrong. Oughta be G7 / G7 / C / C /.
Old June 21st, 2006, 10:48 AM   #4 (permalink)
Thank you, Leon.
I was hoping you would respond based on your other informative posts.
Old June 21st, 2006, 11:15 AM   #5 (permalink)
Shucks
My pleasure. What other forum are you referring to? Sounds like one I should check out.
Old June 21st, 2006, 11:27 AM   #6 (permalink)
No frets!
the SteelGuitarForum, I think I've seen you over there, no? It's like going back in time.
Old June 21st, 2006, 11:48 AM   #7 (permalink)
Yes, I am a member over there; it's one my favorites because the high level of music discussion, and the musical interests are much like my own, although I am not as reactionary as some of those cats, and really do like a lot of this new hot rod stuff.
