formerly ye olde fretmonkey
Wondering about a certain bend...
"Who's Cheatin Who" by Alan Jackson
2nd guitar solo (before the baritone solo starts). I've figured out what Brent Mason's playing on the I and IV, but what is that bend he's doing when he comes back to the I again?? Is he bending 2 strings at once, like a contrary motion bend?
"Greater love hath no man than to attend the Episcopal Church with his wife." -- Lyndon Johnson |
I'm 90% sure he uses a B bender to do this, but it can be done without it.
Just use a pre-bend. Below, where it is noted as pb6 simply pre-bend the F (6th fret on b string) up 1 whole tone to G. Bend it up the whole tone before picking it, then release the bend to the F as required for timing. ----7----------7--------- -------pb6--------------- ------------7------------- -------------------------- --------------------------- EDIT: I should have added that all the notes are allowed to ring together. Cheers, Shawn
#3 (permalink) | |
Re: Wondering about a certain bend...
Code:
B-bender Unintentional B-bend -13--------12--------------------------------------------- -15b17b15--13--13b14b13--12------12---9--10--------------- ---------------14b16b14--12------12--10--11--11-10--9----- -----------------------------14--------------12-11-10----- ---------------------------------------------------------- ---------------------------------------------------------- Brent uses this lick a lot. Check out "Summertime Blues" where he trades with the Dobro: Code:
B-bender --8------8--7-------------------------------------------- -10b12--10--8-10----------7\5-----5---------------------- ---------------9b11b9^7---7\5-----5---------------------- ------------------------9------7-----7\5^3-5--3b4-------- --------------------------------------------------5-3---- ------------------------------------------------------5-- Lots of good stuff in that lick. Thanks for bringing it up. |
#5 (permalink) | |
It's gonna take more poring over on my part. Sounds like I should try it with some gauge other than .011 strings.
Oops.. when Dave quoted you I just realized I didn't read the original post close enough.
It's the return to the I stuff you wanted - in which case Dave has it notated that same way I usually play it. Cheers, Shawn
#7 (permalink) | ||
I have to quit reading these posts about how I do and don't do stuff on here. It makes me think stuff I don't like to be thinking..... like the guy who said I sped up my playing on Hot Wired outta here ~Brent Mason |
#8 (permalink) | ||
#9 (permalink) | |
The double-stop on the 12th fret right after the bend is "barely" made, which I put in quotes because it's obviously still good enough for a world-class recording. It's just not as cleanly picked as the rest of the double stops. The way Brent pulls it off, however, is exactly why he's The Man in Nashville: Even after getting himself into a positionally tight spot, he comes out of it perfectly in the pocket with solid tone. The only people who catch the gaffe are the six or so nerds on telecaster.com picking it apart on a Sunday afternoon. :) By the way, if you want to play this lick a little more reliably, and aren't afraid of a quick position change, just keep it on the B and E strings: Code:
-13--------12---8---------7-------7---4---5--------------- -15b17b15--13--10b12b10---8-------8---6---7---7--6--5----- ------------------------------9---------------7--6--5----- ---------------------------------------------------------- ---------------------------------------------------------- ---------------------------------------------------------- |
AGAIN --
let me state that it was not a gaffe as you call it, a mistake, it is exactly the way I meant for it to be. I know you mean no disrespect, but you have no idea what you are talking about.
~BRENT MASON |
#11 (permalink) | |
Re: AGAIN --
#13 (permalink) | |
Unless the person who actually played the piece is writing about it, it's all some degreee of conjecture. Now, if it comes to be that the person who actually played the piece notices an error in the interpretation or transcription and is kind enough to offer a gentle correction, all the better. BTW, Brent - big fan here. Keep on pickin! Cheers, Shawn
