Old August 3rd, 2012, 09:25 PM   #1 (permalink)
Turtletwang's Avatar
Using thumbpick
I've been using a thumbpick lately for some rockabilly style progressions and like the way it sounds. However, my pick keeps knocking against the pickguard making an audible clicking sound. Is this normal, or am I doing something wrong?
Turtletwang is offline   Reply With Quote
Old August 3rd, 2012, 10:01 PM   #2 (permalink)
jbmando's Avatar
Your muscle memory is trying to play the string with the meat of your thumb.You have to practice holding your hand away from the strings a little, or you can try to sand the tip of the pick down a little bit.
"Theory only seems like rocket science when you don't know it. Once you understand it, it's more like plumbing!"~John McGann
There is no "A" anywhere in Lynyrd Skynyrd.
It's S Q U I E R! Not Squire. Look at your guitar!
jbmando is offline   Reply With Quote
Old August 3rd, 2012, 11:17 PM   #3 (permalink)
I've been using a thumbpick for many, many years; started using them back in the early 70s. And I learned right out of the gate to cut/file/sand the tip down on the thumbpick. I do mine in a "spear-point" style, leaving just enough sticking out past my thumb that it can be barely seen when holding my thumb level on the table with the flat part of the pick down flush to the table-top. Experiment around till you find your "shape". Picks are cheap. Good luck.
bender-freak
bender-freak is online now   Reply With Quote
Old August 6th, 2012, 01:20 AM   #4 (permalink)
Thanks for the advice!
