Old June 14th, 2012, 07:04 AM   #1 (permalink)
1955's Avatar
Favirite moveable 13th shape?
Whats your favorite moveable shape for a 13th? Trying to learn a good fingering I can apply most anywhere and still get the basic guitar essence for a 13th.
Thanks!
"Discipline is the bridge between goals and accomplishment." Jim Rohn
1955 is offline   Reply With Quote
Old June 14th, 2012, 07:09 AM   #2 (permalink)
evanrw's Avatar
from the 3rd fret (G) :
X
Such a workhorse chord.
evanrw is offline   Reply With Quote
Old June 14th, 2012, 07:14 AM   #3 (permalink)
jazztele's Avatar
You just need the inside notes...7th, 3rd, and the 13th.
So here is a G13: x x 3 4 5 x
Jeff Matz, Jazz Guitar: http://www.jeffmatzguitar.com
jazztele is offline   Reply With Quote
Old June 14th, 2012, 07:31 AM   #4 (permalink)
evanrw's Avatar
You're right. I only mention the 5-string version as my 'favourite' because it is such a wide voicing. Great for playing solo.
Old June 14th, 2012, 08:11 AM   #5 (permalink)
jbmando's Avatar
Evan, I can't tell what shape your chord is. Normally, vertical diagrams are high to low, top to bottom, but the easiest way to read it in "text" form is horizontally, low to high, left to right. I'm guessing yours is 3x3455? FWIW, I like 353453 for a six string version and 3x345x for moving around.
"Theory only seems like rocket science when you don't know it. Once you understand it, it's more like plumbing!"~John McGann
There is no "A" anywhere in Lynyrd Skynyrd.
It's S Q U I E R! Not Squire. Look at your guitar!
jbmando is offline   Reply With Quote
Old June 14th, 2012, 08:49 AM   #6 (permalink)
I'm really liking 5x5422 (A13). The ninth (on the third string) can be altered relatively easily too.
As mentioned by jazztele, most commonly when comping I'll use the three note 13th voicing.
bigbandtele is offline   Reply With Quote
Old June 14th, 2012, 11:07 AM   #7 (permalink)
Thumb fingering the root on string 6.
ronkmd is offline   Reply With Quote
Old June 14th, 2012, 11:32 AM   #8 (permalink)
Instead of thinking about how you are gripping the chord, think of the construction of the chord. With a dom 13, you have the root, 3rd, 5th, 7th, and 13th (You could also include the 9th, and 11th, if you so desired). In essence you have the entire scale at your disposal. The obvious disposable tones are the root and the 5th, also I would stay away from the 11th, because with a dominant chord many times our ears hear the sus4 sound even when we play the 3rd.
So here are some options... You could play as Jeff said the 3rd, 7th, and 6th. You could also play the 7th, 9th, and 6th. You could also voice the 13th sound between the 3rd and 7th, although that may require Ted Greene-esque finger stretching and get the 3rd, 6th, and 7th.
Another thing to think about... Take all of the dominant 7th chord voicings you already know and just move the 5th up a whole step. I have found in learning chord voicings and inversions, you will do so much more efficiently if you start with what you already know and find the most logical path to where you want to go. By the same token, you could learn many versions of a dominant 9th chord by takingthe root and raising it a whole step. Keep in mind that you want to avoid doing this with the bass notes. It is much more cohesive if these changes are happening in the upper and middle voices. Example...you could play X-X-3-4-3-0 and the high E sounds nice, whereas if you played the same chord with an open low E in the bass it may just sound like a hot mess.
I hope some of that helps, I know I have a tendency to ramble.
twangjeff is offline   Reply With Quote
Old June 14th, 2012, 12:02 PM   #9 (permalink)
klasaine's Avatar
X67788 - F13
XX9555 - D13
This one's the same as JT's just voiced on a higher string set:
XXX799 - E13 (technically there's no 9th so it's really a 7/6)
X55566 - Bb13
X56586 - Bb13
and for some 'bite' : XX5673 - A13
Spanning 23 years ... http://soundcloud.com/klasaine
Old June 14th, 2012, 12:41 PM   #10 (permalink)
BigDaddyLH's Avatar
+1. As always, drop the root if it's in the way.
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” -- Charles Bukowski
Old June 14th, 2012, 04:52 PM   #11 (permalink)
1955's Avatar
Lots of help everyone! Will try each of these and try to absorb it! Thanks!
Old June 14th, 2012, 06:57 PM   #12 (permalink)
slowpinky's Avatar
I like this one in a trio setting (not a horn player favourite..)
C13 - x77333 or x
"We were making music before language"
slowpinky is offline   Reply With Quote
Old June 14th, 2012, 07:18 PM   #13 (permalink)
czgibson's Avatar
You guys are way too clever for me.
For A13 I'd stick to:
5x567x
or
5x5422
and for C13:
x32335
or
x1221x (if you're lucky)
Plenty of really cool chords in this thread, but those have got to be the first ones to learn, right?
czgibson is offline   Reply With Quote
Old June 15th, 2012, 04:07 AM   #14 (permalink)
evanrw's Avatar
Cool. Thanks for the chord-convention lesson! ^_^
Old June 15th, 2012, 04:36 AM   #15 (permalink)
boneyguy's Avatar
This voicing has already been shown but here is a nice way of using it in a blues setting to get both a dom13 and dom7#9 from one shape.
So we're working a 12 bar blues in G and we're moving from I to IV.
xx345x (G13) > xx91011x (G7#9) > xx8910x (C13)
The gist of this is that the same shape can be both a dom13 and a dom7#9 with the same root depending on where on the fretboard you grab it. The G13 has it's root on the low E, third fret and the G7#9 has it's root on the fifth string, 10th fret. The G7#9 could also be seen as a Db13 (root on low E, 9th fret)
This is a simple move that will 'jazz up' a 12 bar a little bit. You can see it as either using an altered I7 chord (7#9) to move to the IV or as using tritone substitution (Db13) to move to the IV. Either way it makes it a bit more 'uptown' sounding. And it's dead simple. Bonus!!
I am the center of the universe and so are you.
boneyguy is offline   Reply With Quote
Old June 15th, 2012, 04:41 AM   #16 (permalink)
evanrw's Avatar
nice!
Old June 15th, 2012, 04:45 AM   #17 (permalink)
boneyguy's Avatar
Originally Posted by evanrw View Post
nice!
I'm embarrased to say that although I've used this move a million times I had always just seen it as a tritone sub. It was only recently that the 7#9 aspect revealed itself to me. Doh!!
Old June 15th, 2012, 07:00 AM   #18 (permalink)
1955's Avatar
I've been playing 353453 for a while, not knowing it was a 13th. I thought it was a sixth, as I am new to jazz chords and theory. I play this shape like a major barre chord, with my pinky on the second string.
I am liking 3x345x because it is similar to a maj7 shape with my index finger on the 5th string root, so that's the first one I'm comprehending.
So much more info here, this is a treasure trove! Gonna take a while to absorb. Thanks so much everybody!
Old June 15th, 2012, 07:02 AM   #19 (permalink)
1955's Avatar
I meant index on 6th string root, sorry!
Old June 15th, 2012, 07:32 AM   #20 (permalink)
telequacktastic's Avatar
This is a good one too, this is D13th:
The root is on the 5th string, 4th string is the M3rd, 3rd string is the b7, 2nd string we have the 9th, and high e string we have the 13th. Horn players like this one. Omit the root as needed ;-)
1-----7-----
2-----5-----
3-----5-----
4-----4-----
5-----5-----
6-----------
telequacktastic is offline   Reply With Quote
