All my Improv sounds the same?
Whenever I decide to improvise, it seems to always come out the same. Just a pentatonic scale up and down with a little varitation. Is there any way to improve on my improv?
Thomas "That's no reason to cry. One cries because one is sad. For example, I cry because others are stupid, and that makes me sad." -Sheldon |
Here's something I sometimes do... Instead of playing what comes out of my fingers, I use my voice and play what comes out of my mouth. It gets me outta my muscle-memory rut.
If you practice to some backing tracks, you can get more familiar with what notes match your voice. |
I learned scales, and could never figure out why they didn't do any good. My solos only started to sound interesting when I threw away the scales and played the notes of the chords -- and other notes that were physically near the chord.
It's easier to do than to explain. If you start learning licks off recordings (particularly 60s stuff), you'll notice that the licks use pieces of the chords. There will be other notes, but more often than not, those notes will be so close by, you won't even have to move your hand to grab them.
"It looked like a giant green gum drop to me." |
#4 (permalink) | |
learn how the pentatonic scales fit into the major scale. learn the blues scale too. sometimes it takes a little while to get a good solo going, be patient with it and try singing what you play too.
I suggest that you learn the melody line. You start with that, and once it is firmly ingrained you can begin to embellish on the melody. You will find this works well with what was previously suggested to "play the changes", or following the chords. This is exactly what you will be doing. The arpeggios work particularly well for fills and embellishments even when you are not soloing.
#7 (permalink) | |
Chicks dig me! |
Take the time to learn solos of different players. Pick one player and play in that style for a little while, then pick another and play in that style. Over time you will have a bigger vocabulary to draw from when you play different songs.
#9 (permalink) | |
![]() Poster Extraordinaire
This is a really interesting problem to me. I agree that you should learn the melody and learn about scales. Beyond that, though, is where it gets interesting. I like to pay attention to what I am playing, and not playing, then trying to figure out what my reflexes are. Once I am aware of those, I try to replace them with other reflexes. This is a long term project.
If your technique and knowledge are far enough along, you might try this. Find a song or backing track to solo over and go ahead and do it for a while. Then, find a live YouTube performance of another guitarist, and try to mimic what he does. It is not important to stop and copy, just take a stab at the rhythm and pitch contour. This should only take a few minutes. Then go back to your backing track and try to channel the other guitarist. Again, accuracy or transcription are not the focus. The emphasis should be on using the skills that you already possess to adapt to a different musical impulse. But, as I said, this may not be the thing for you to do if you don't already have enough fluency.
Check out my new book on Amazon: 2000 Blues Licks That Rock! |
I do various things...like channeling; weird things like how would a frog do the melody or visualizing two birds doing arial dogfight or dance; sometimes I can hear a melody within the melody, i.e., that is more fundamental or basic and try to stretch it, compress it, put some heat or cold to it; try with different rythms/times, play the edges of it; or try to fit a different genre into it...like a reggae into a bluegrass. But I'm a basement noodle that plays along to whatever....so I don't worry about the musicality and sometimes it works and many times not. The problem with the approach, is that I'm a reactive/interactive noodle and need something to play againist or with and have a hell of a time just coming up with something on my own.
#14 (permalink) |
Try to think about the melody and the chord changes. Play around with the melody, pull chord notes and fragments out of the chords, anticipate changes by moving into the new chord tones just ahead of the change, mix up flat and normal 3rds and 7ths, try some chromatics, play "outside" notes on the off beat and strong chord tones on the beat, try to phrase your playing as if you were having a conversation, pause for natural "breaths" rather than just wailing away, mix up your articulation by playing slower passages among your faster playing, play with plenty of dynamics including varied attack and vibrato styles, try to mimic other instruments and phrases from saxophonists/pianists etc, transcribe your favourite solos and then work out why they played what they did, every time you learn a new lick or technique try to use it musically in as many contexts as you can.
That should help. |
I'll just echo what some others have said, in hopes that it gives these ideas more credence.
1. Learn to be able to play what you can sing/hear in your head. It just takes practice. 2. Try to copy the style of other players. I wouldn't suggest doing this on a gig unless it's purposefully a bit of a joke, but it's a good way to have fun and learn. getting better at either one of these things will help you get better at the other. |
#16 (permalink) |
I am new enough to actually learning guitar that I have no true right to respond but I am nailing down my first scale well. Am pentatonic with additions.
I occassionaly DO apply something I learned playing other instruments at times and it always sounds much better when I do this: Simply imagine your guitar as two people having a conversation. There's just something about a woman nagging a man (the higher notes) and the man trying to defend himself and calm her down (lower notes) Of course when she doesn't listen the intensity increases and well then there's the make up se... |
#17 (permalink) |
Try learning another instrument - bass, mandolin, ukulele, banjo, keyboards, harmonica.
Learning these will improve your vocabulary on your guitar. Learn chromatic scales. Very few songs truly use pentatonic, blues does not (blues "pentatonic" is at least six notes). All the keys, major and minor, all the notes but not necessarily in the right order. And the jumps I- IV, V, VI, VII, &c. Learn some jazz. Most modern popular music has its foundations in jazz. The chords and changes are extremely useful for any improv.
#18 (permalink) |
Remember, if you're using the pentatonic scale, that's only five notes!
Get those notes burned into your brain.. Then you can play guitar when you're not even with a guitar. In the shower, on the bus, at work, wherever. I'm sure a lot of you are doing it right now. And yeah, I do this too. I play with my fingers not my brain and it just sounds like random notes of a scale. But you have to stop yourself doing that. Try to tell a story, think about the rhythms and phrasing of just everyday conversation. There's music everywhere, breath it all in! Enjoy! |
#20 (permalink) | |
"We were making music before language" |
