Pedal steel sound?
Not sure where this ? should go, but does anyone know how to get pedal steel sound from a standard electric?
Skip ahead to 1:00 http://www.youtube.com/watch?v=Yltq0...eature=related |
Volume pedal? Yes and no! There are a lot of things I play on pedal steel (Kline U-12 & '59,'64,'67,'74 Shobuds) that never use the volume pedal. And don't "pump" it too much. As for compressors, use a very transparent one. I use a Meek VC-3 for steel sounds on 6-string. Also,,, steel pickups are generally wound to around 18-20 K,, a lot more oomph than even a very hot humbucker! Keely Katana helps there. Reverb? Definitely! Delay? Sometimes. Technique? All the time!
#8 (permalink) | |
Also check out players like Arlen Roth and Jerry Donahue.
"When I first started out, all I had was a dream....... and 6 million dollars!" |
Sure. No solid body electric is going to really. It's more the style that he is adopting here that is steel-esque. I have seen other clips of him where he gets scary close to a steel sound using nothing more than his Tele and volume pot with the pinky on it. He 'stole' a lot of steel licks off of Buddy Emmons when he was playing with him in the late seventies.
#11 (permalink) | |
"So I says to Mable, 'Mable', I says...." |
Swells ? Sure they are nice and sound kool, but that is not why Steel Players use a volume pedal...
A seasoned Steel player, for the most part you won't even recognize that they are using a volume pedal. Typically the V Pedal is set at about 50% to achieve normal volume..the rest of the Pedal is used for extended sustain of chords or notes... Beginner players have way too much swell, one of the practice techniques recommended is for new players to put their right foot on a block of wood for a month or so, maybe longer...this prevents it from moving with all of the other physical things going on...feet moving, knee's moving, both hands moving..all while trying to stay on pitch ! Volume swell may be used as an effect but it is not a typical Pedal Steel thing, quite the opposite, players need to be able to NOT swell and control it... proper right foot technique is to be able to prevent the swell from occurring. Most of the great Telecaster bending things we hear are artifacts from Pedal Steel phrasing , not necessarily Pedal Steel phrases. They began with the influence and turned into another kool technique for guitars which many think are actually Pedal Steel licks ! t
www.tprior.com |
#18 (permalink) |
Even after watching the video until the end and and after read the text below I'm still not sure that there is no pedal steel guitar.
http://www.youtube.com/watch?v=DBRCEHuJ210 |
#19 (permalink) | |
#20 (permalink) | |
As for the rest of the tone - try using a combination of mild reverb and a short to medium delay (140-180ms or so, 20-30% mix, zero repeats) to fatten up the notes. |
