I need "Georgia on my Mind" for dummies
Can anybody help a 3-chord Blues guy out with a simple way to play this one?
I need it for a gig. Thanks |
I got it Charlie. You just want a chord chart? What key do you want it in? Ray is G, but it's in F a lot.
"Theory only seems like rocket science when you don't know it. Once you understand it, it's more like plumbing!"~John McGann There is no "A" anywhere in Lynyrd Skynyrd. It's S Q U I E R! Not Squire. Look at your guitar! |
I edited while you were typing. F or G or some other key?
Okay, Ray Charles did it in G, so I'll give you G.
Intro: G D/F# Em Cm C#dim G Am7 D7 Verse: G B7 Em Em7 C C#dim G E7 A7 D7 B7 E7 A7 D7 G B7 Em Em7 C C#dim G E7 A7 D7 G C7 G Trans chord to bridge: B7 Bridge: Em Em#5 (put your index finger on the C at the first fret of the B string while you play a cowboy Em) Em6 (move it up to the second fret) Em#5 Em Em#5 Em7 A7 Em Em#5 Em7 F#7 Bm7 E7 Am7 D7 G B7 Em Em7 C C#dim G E7 A7 D7 G C7 G B7 Bridge: Em Am7 Em7 C7 Em Am7 Em7 A7 Em Am7 Em7 F#7 Bm7 E7 Am7 D7 Last Verse: G B7 Em Em7 C C#dim G E7 A7 D7 (this comes right before the tag:) F7 E7 A7 D7 G C7 G Ending: G#9 G9 - G7#9 (G7 barre with your pinky three frets up on the first and second strings - the Hendrix chord!) Some people play both bridges the same. Either way works either time. Hope this helps. Here's Ray so you can hear when the changes come. The chords In gave you will work even if they don't sound exactly like the record. I simplified it as much as I thought I could. C#dim: x4535x Em#5: 022010 Em6: 022020 G#9: x3434x G9: x2323x G7#9: 353466
Very cool, h, but not exactly GOMM for dummies!
be very careful use caution, do not proceed without deep thought and consideration...
you are entering territory that you can never return from. You can add a handful of chords to your vocabulary and change your entire approach , just like that... Playing songs like Georgia, is a game changer from basics and you don't need to add all the exotic substitution chords ..a few here and there and it's a whole new life ! The problem will be, going forward you will want to do more of it with the players you gig with regularly...this is a good thing ! go for it ! t
www.tprior.com |
After you get the changes down, try to substitute some extensions/alterations for some of the chords. Like you can put D7b9s or 7#5s in there for the D7s and 9s, 11s and 13s for some of the dominant chords. This is a great song for hearing and seeing how the ii-V or II-V progression is used because there are a bunch of 2-5s in this song.
Here's a chart; not sure how standard, but it sounds nice.
Georgia - C C/// E7/// Am/C7/ F/F#dim/ CBbA/ Dm/G/ (1: E7/A7/ D7/G7/) (2: CC7FFm C/E7/) Am/Dm/ Am/F7/ Am/Dm/ C/B/ Am/Dm/ CBbA7/ Em/Eb7/ Dm7/C#7/ |
Leon, that last set of changes for the bridge is giving me a little trouble. Seems to work better if I play:
Am/Dm/ Am/F7/ Am/Dm/ Am7/D7/ Am/Dm/ Am7/B/ Em/Eb7/ Dm7/C#7/ I must be doing something wrong.
That sounds good, too; maybe better. I have only played this tune with one band, and that is the way the leader taught it to me. I'm used to it. On the B7, the melody note I hear is F#. Same with your D7?
#16 (permalink) |
Many thanks JB--I've been trying to find a simplified version of this for some time. I had most of it down, but this filled in all the gaps.
One question -- in the intro -- Pardon my ignorance, but what is a D/F#? |
#17 (permalink) |
D chord with an F# bass. On guitar, a common shape is 20023x (I usually don't play the high F# if I put one in the bass.)
#18 (permalink) |
Yes, melody note on that chord is F#.
#19 (permalink) | |
When playing Key to the Highway in A, play the D7 on the first fret and grab the F# in the bass with your thumb. |
#20 (permalink) |
Yep. If you play all six strings: 200210, it's a D9 with that high E.
