Old February 24th, 2012, 05:42 PM   #1 (permalink)
Flexing the neck for vibrato...
I dont know much about bending the neck for vibrato. I see people trying it when out and around, few get a musical result-I asked a girl the other night at the bar we went to what she thought the guitarist was doing there....she thought it was part of the performance in response to the singers lyrics. Hmm.
Id like to give the technique a try, to see if its something usable. The stuff
I play/write generally has little need for deep vibrato, but there are a few songs where it could be a tasteful addition, without needing a trem guitar. I tried this on my Baja today, and it was very difficult. Its easier on my thinner necked strat, but I dont need to use this with my strat.
Anybody have any tips or tricks for this technique? Whats the technique actually called? I am doing some reading on it right now, but thought Id ask other guitarists first if this is a usable option.
Davo17 is offline   Reply With Quote
Old February 24th, 2012, 05:43 PM   #2 (permalink)
IPLAYLOUD's Avatar
It's called "2 seconds from hearing SNAP!!!".
I cringe...
I play an Esquire because I can't afford the other pickup.
IPLAYLOUD is online now   Reply With Quote
Old February 24th, 2012, 05:46 PM   #3 (permalink)
Mur
Mur's Avatar
I won't pull on the neck, but instead, place a finger behind the nut and gently raise the string pitch on one string. It actually works, and sounds like more is going on than actually is.
Mur is offline   Reply With Quote
Old February 24th, 2012, 05:55 PM   #4 (permalink)
Buy a classic vibe tele, I can do it to mine without trying... but I like it.
mjbk24 is offline   Reply With Quote
Old February 24th, 2012, 06:04 PM   #5 (permalink)
psyched's Avatar
Big bends, goodness no... if you want to do those, get a trem instead of putting all sorts of pressure on the neck bolts that are already handling a decent amount of tension from the strings. Can a Tele handle it? Yeah, but that doesn't mean it should...
Now if you're talking about the slight shaking kind of neck vibrato, look up Ted Greene on YouTube and see how he does it. It's kind of hard to explain, but it does become sort of reflexive to do... it has it's own sound when done right, and done with a clean channel, I think it adds a lot.
All great deeds and all great thoughts have a ridiculous beginning. Great works are often born on a street corner or in a restaurant's revolving door.
- Albert Camus
psyched is offline   Reply With Quote
Old February 24th, 2012, 06:30 PM   #6 (permalink)
Do a little wiggle with the neck lots. Gives a nice kind of chorus effect to chords. Been doin it for years on bunches of guitars and never had a problem. Check Jim Campilongo, he's all over the neck bend thing. Saw Adrian Belew do it so hard to a strat once the strings almost went slack.
It's easier to do sittin down and push against your leg and ribs alternatively for a little wiggle. Just don't go tryin to rip the neck off and it shouldn't be an issue.
cnote is offline   Reply With Quote
Old February 24th, 2012, 06:37 PM   #7 (permalink)
telex76's Avatar
It scares me, but I know many players who always do this with their teles and say they have never hurt the neck.
telex76 is offline   Reply With Quote
Old February 24th, 2012, 06:38 PM   #8 (permalink)
Heres the technique in question, at 0:31 seconds in.
Is this dangerous in any way to the guitar? I thought these electrics could take quite a bit of tension.
Im thinking that while the teles bridge pup would be great for catching those harmonics, that the strats longer upper horn would facilitate more leverage on the neck. My baja has a heavy neck, so maybe this is better done on a thin necked guitar?
Old February 24th, 2012, 06:42 PM   #9 (permalink)
I will look him up. If I use it for recording (or loops) I wont at all have an issue sitting or putting my leg up.
Old February 24th, 2012, 06:43 PM   #10 (permalink)
Telemach_1's Avatar
Oh, man. I think this is not a nice way to treat your guitar. I personally absolutely dislike it and even watching people doing it makes me sick.
An other thing that gets me mad is the way how some players rest ther forearm on the neck.
Best regards
Rescue the Telecaster tone. Ban stomp boxes.
(Maybe not the Zen Drive)
Telemach_1 is offline   Reply With Quote
Old February 24th, 2012, 06:44 PM   #11 (permalink)
Was anything else hurt?
Old February 24th, 2012, 06:51 PM   #12 (permalink)
I agree it doesnt look nice, but if it does no harm I would be open to it. Are there cases of necks or bodies snapping because of this?
Old February 24th, 2012, 06:56 PM   #13 (permalink)
qwerty95's Avatar
I do it, I push or pull the base of the headstock. Never had any problems except going out of tune after a couple songs. My friend did it on his Les Paul once, snapped the headstock off.
Call me Syd.
Also, I'm a chick.
qwerty95 is offline   Reply With Quote
Old February 24th, 2012, 06:57 PM   #14 (permalink)
xtrajerry's Avatar
It's not just the thickness of the neck that effects the ease that this can be done.. I have a strat with a fairly thin neck but it's quater sawn maple and very stiff.. I need to really lean into to get that effect.. my other strat with much thicker neck but flat sawn bends with almost no extra effort..
xtrajerry is offline   Reply With Quote
Old February 24th, 2012, 07:10 PM   #15 (permalink)
Telemach_1's Avatar
It depends on how strong you have to bend and what guitar you have. I'm an old fashioned fart whose Fender guitars sometimes have been a real desaster when it came to neck fit and alignment. In the seventies there was no perfect MIM produced Fender guitars, but often enough sloppy built U.S. planks. Then there was this terrible 3 bolt neck era,...allright you're right, I'm traumatized.
Best regards
Old February 24th, 2012, 07:18 PM   #16 (permalink)
Bartholomew3's Avatar
Seems like a useless technique for most styles of music.
And in any event would only be good in a couple of tunes each night or may be approaching "wankerdom".
Just my 2 cents. I would put my time into something more musical...but that's just me.
Bartholomew3 is offline   Reply With Quote
Old February 24th, 2012, 07:25 PM   #17 (permalink)
What would you suggest?
I would use this mostly for my own songs, some of which are clean/ambient/looped. Getting another vibrato tone without needed to switch guitars when looping seems kind of cool.
Old February 24th, 2012, 07:28 PM   #18 (permalink)
w3stie's Avatar
Chuck Prophet uses the technique briefly in this clip around 4:50, but the clip is worth watching anyway; it's a masterclass.
FORTUNA FAVET FORTIBUS
w3stie is online now   Reply With Quote
Old February 24th, 2012, 07:33 PM   #19 (permalink)
e-merlin's Avatar
I cringe...
You've never seen Brian Hofeldt, have you? From the Derailers? Great stuff.
I've been doing that while playing Sweet Home Alabama on my #1 Tele for years.
'tone is in the underpants'
Old February 24th, 2012, 07:39 PM   #20 (permalink)
Thats a great clip, I dig that vibrato, plus I can actually hear it. :)
