Old February 25th, 2012, 09:19 AM   #41 (permalink)
ludashoeless's Avatar
i don't do it because my tele is my only good electric
Oh ya Nigel? Mine goes to 12
Originally Posted by BobbyZ View Post
Heck I'd like to see dynamite legalized.
Sure it would be very noisy but think about it in Darwin terms.
'11 Am std strat>blues deluxe reissue
ludashoeless is offline   Reply With Quote
Old February 25th, 2012, 09:53 AM   #42 (permalink)
chippertheripper's Avatar
I do it pretty frequently with my tele. The round upper body shape gives you something real solid to push against.
My crappocaster, on the other hand, is so flimsy, I'd snap the neck right out of it if I tried. (I gave it a little zing once, I don't feel comfortable doing it regularly)
It's another reason why cheap guitars rule. You can do this stuff, and another neck or body is just a few dollars away.
The Dividersgarage/surf/rock&roll
Originally Posted by Brad Pittiful View Post
my parents hated my tone when i was little...they kept saying...i dont like your tone young man!
chippertheripper is offline   Reply With Quote
Old February 25th, 2012, 10:40 AM   #43 (permalink)
Monte Montgomery is another acoustic guy I've seen mercilessly honk on the neck for vibrato.
I checked that Chuck Prophet video (thanks for that, never heard him before but will seek out more). Tried what he did and you do get a waver in the sound. You have to be fairly violent and swing it pretty hard back and forth.
They're just guitars. Do what needs to be done to serve the music. If you break a neck, rip out neck screws or crack the body in the neck pocket, then ya know how hard you can push. Patch er back up and come out swangin again.
cnote is offline   Reply With Quote
Old February 25th, 2012, 11:23 AM   #44 (permalink)
fezz parka's Avatar
Do what it takes to make the sound you want. Tele's are tough, you can break up cement with 'em.
Old February 25th, 2012, 11:51 AM   #45 (permalink)
klasaine's Avatar
Pffft! It's not gonna break.
If you're not tweaking the neck of a tele ... you're not playing it!.
I do it to some degree with EVERY guitar I have - including Gibsons.
A Tele is made for it!
Spanning 23 years ... http://soundcloud.com/klasaine
Old February 25th, 2012, 01:58 PM   #46 (permalink)
tjalla's Avatar
Originally Posted by IPLAYLOUD View Post
It's called "2 seconds from hearing SNAP!!!".
I cringe...
You can snap a 1" thick maple board with your bare hands? For real?
*insert bodybuilder joke here*
tjalla is online now   Reply With Quote
Old February 25th, 2012, 09:56 PM   #47 (permalink)
chabby's Avatar
I have a strat, but even with that I've grown so used to bending behind the nut I sometimes do it on the start too. May as well keep in poractice. I remvied the handle of the whammy bay and even when I do use it, ijust use the heel of my hand on the bridge on the strat. But to each his own, I won't sya I've never done it, but it does kind of rub me the wrong way. I'm gentele whern I do it.
chabby is offline   Reply With Quote
Old February 25th, 2012, 10:00 PM   #48 (permalink)
Hoopermazing's Avatar
Why attempt to flex the neck--which strikes me as ill-advised--when you can easily bend the strings behind the nut?
Hoopermazing is offline   Reply With Quote
Old February 25th, 2012, 10:18 PM   #49 (permalink)
Its usually for full chords. You can't reach down and bend a chord up unless your a octopus.
And you can only bend up with a behind-the-nut. You can't pull notes flat, and thats what a neck bend is suppose to do with a guitar sans a movable bridge system.
Its great if your doing a rockabilly or something and end on that 6/9 chord high up the twelth fret and give then that Bigsby like shimmer by flexing the neck and body.
"Ask not what your Tele can do for you, but what your fingers can do for your Tele."
The versatility of a Tele is almost unmatched. - Ted Greene
Breen is offline   Reply With Quote
Old February 25th, 2012, 10:25 PM   #50 (permalink)
Ridge runner's Avatar
I used to do it,and I remember Jake E Lee doing it a lot live with Ozzy..
But one thing I've noticed on like used Jackson and Charvel guitars is that the paint on the body around the neck joint will have a hairline crack or they will have a small piece break off up at the headstock so while the neck may flex the paint probably won't.
I've noticed on my dad's tele.It's an American Ash telecaster
And the paint is chipping off which really sucks.
Ridge runner is offline   Reply With Quote
Old February 25th, 2012, 10:37 PM   #51 (permalink)
Ahhhhh... I hadn't considered the possibility of pushing the neck forward, and I rarely play 6 string chords. I can bend a 4 or 5 string chord with my picking hand quite easily (w/ the side of my index finger.)
Old March 1st, 2012, 01:39 PM   #52 (permalink)
Steveareno's Avatar
I've used this technique and behind the nut bends for years. It doen't take much pressure to put some vibrato on your chords. It's one of the cool tricks for Teles (or Strats) that don't have a wang bar. Saw Jim Camplilongo a few years ago and it seemed like his neck was made of rubber (sounded fantastic though). I prefer to take it easy and use the technique sparingly.
Swang on,
Steveareno is offline   Reply With Quote
Old March 1st, 2012, 02:04 PM   #53 (permalink)
fezz parka's Avatar
Jim's hands can crack walnuts.
Old March 2nd, 2012, 11:04 AM   #54 (permalink)
asatfan's Avatar
I've been pushin' on my G&L (3 bolt) necks for years...never thought I could break one....still don't.
"......gotta keep rockin' while I still can....." - Steve Earle
http://www.facebook.com/pages/Rug-th...s/112739214212
asatfan is offline   Reply With Quote
Old March 6th, 2012, 06:14 PM   #55 (permalink)
Jim Campilongo's Avatar
Hi guys -
I enjoyed this thread and the Chuck clip. But Chuck didn't do what I think of as a classic neck bend a la Frisell, Volkaert etc
Me? For a chorus-ing effect I stabilize the guitar body with my elbow of my left arm while pushing and pulling the neck with my left hand as I play...
For an medium effect I bend my neck by pushing the neck from behind with my left hand while gripping and stabilizing the body with the flat of my right hand...
If I want an extreme pitch bend I'll move my left hand closer to the headstock where there is a "softer" neck that I can bow and bend...
It's all done with some finesse, but not as much as let's say, nudging a pinball machine below a tilt sensor. I hit my guitar pretty hard...
I've been doing this for 25 years and it hasn't hurt any of my guitars what-so-ever...
http://www.jimcampilongo.com
Jim Campilongo is offline   Reply With Quote
Old March 6th, 2012, 07:17 PM   #56 (permalink)
Originally Posted by Jim Campilongo View Post
Hi guys -
Me? For a chorus-ing effect I stabilize the body with my elbow of my left arm while pushing and pulling with my left hand as I play...
Jim wow Ive been listening to your stuff quite a bit recently, its just very organic and real. Not over processed and it makes a difference.
I will give these a shot. Its also good to know it wont hurt my tele. Thanks for the inside info!
Davo17 is offline   Reply With Quote
Old March 6th, 2012, 09:06 PM   #57 (permalink)
stlthinkin's Avatar
Neck wiggle + delay can make clean big chords come alive. Not talking the big pitch dives but the subtle push/pull action you can get with the fret hand still fretting.
stlthinkin is offline   Reply With Quote
Old March 7th, 2012, 05:29 PM   #58 (permalink)
ryokan's Avatar
Bending the neck is one of the great joys of playing electric guitar, and it is particularly easy to do with a telecaster. If you aren't doing it, you're missing out on a beautiful sound/effect. I prefer it to a vibrato system as it is more subtle, and therefore I don't abuse it like I do with a whammy bar...
www.inksound.com
ryokan is offline   Reply With Quote
Old March 9th, 2012, 07:53 PM   #59 (permalink)
I've been doing it for decades on my `69 with no ill effects, though probably not more than a quarter tone or so.
krelnarb is offline   Reply With Quote
Old March 14th, 2012, 09:14 PM   #60 (permalink)
bobsway's Avatar
Always have, always will. Seems a little harder to do on my Tele than on most guitars though, much more solid, not so flexible.
Wanker, Twangker, Tele-Spanker
bobsway is offline   Reply With Quote
