Old April 24th, 2010, 10:56 PM   #1 (permalink)
PICKING HAND:Floating hand or fingers anchored on the body??
Which do like or think is better technique??
jalguitarman is offline   Reply With Quote
Old April 24th, 2010, 11:19 PM   #2 (permalink)
I tend to use the lower heel of my right hand on the back edge of the bridge as an anchor. I used to do the little finger anchor, but found it constricting.
Dirty Steve is offline   Reply With Quote
Old April 24th, 2010, 11:26 PM   #3 (permalink)
jrich99's Avatar
I once heard somewhere to avoid anchoring your hand, but I anchor the lower heal of my right hand as well.
Originally Posted by drf64 View Post
He loves getting the last laugh, especially when nobody else thinks it's funny.
jrich99 is offline   Reply With Quote
Old April 24th, 2010, 11:28 PM   #4 (permalink)
Kingpin's Avatar
I think floating is the preferred technique, it leads to less tension in your picking hand. That said, there have been some fantastic players that plant a pinky on the body.
You can achieve a similar point of reference as anchoring provides by just letting the heel of your picking hand graze the bridge/strings. Helps with muting too.
FREE BILL KIRCHEN!
Kingpin is offline   Reply With Quote
Old April 25th, 2010, 12:01 AM   #5 (permalink)
Uma Floresta's Avatar
Palm anchor
Uma Floresta is offline   Reply With Quote
Old April 25th, 2010, 12:01 AM   #6 (permalink)
rangercaster's Avatar
a combination of both styles is what i use ... i pull my pinky off the body if i need to use it ...
"Unum saltum et siffletum et unum bumbulum"
Old April 25th, 2010, 04:32 AM   #7 (permalink)
JayFreddy's Avatar
+1. Pinky "posting", as it's called in Bluegrass parlance, pulls your hand out of balance and causes tension to build up. However, as Kingpin noted, there are lots of great players who post the pinky.
The fastest, most fluid pickers I've known have all been floaters. When you hear fast, fluid, flowing lines, that's pretty much a guarantee of floating.
What do Joe Maphis, Tal Farlow, Geroge Benson, Al Dimeola, Yngwie Malmsteen, Eric Johnson, and Alex Hutchings have in common?
They're all floaters.
JayFreddy is offline   Reply With Quote
Old April 25th, 2010, 05:01 AM   #8 (permalink)
jefrs's Avatar
Floating.
Planting the pinky is for bluegrass banjo players, it restricts movement of the picking point along the strings to one place. I cannot even do that on the banjo, I find that having one finger permanently extended restricts the fluidity of wiggle movement of the rest of the fingers. Plus on an acoustic guitar it dampens the vibration of the soundboard, this also true for banjo. And those funny metal claws get caught in the strings.
Floating follows the classical technique, jazz players use it too even with a pick. This may be parallel development since the 'classical technique' is historically quite new (mainly Segovia, but check Freddy Green's technique and Django's). The forearm should not be clamped to the body of the guitar either but move freely from the shoulder.
Initially planting a finger or the heel of the palm lends accuracy but resting the thumb (or a finger) on a non-vibrating string to damp it serves the same purpose. It takes some practice, eventually the hand, which is after-all constantly playing the strings, knows where the strings are, and it becomes easier than nailing the hand to the plank.
Old April 25th, 2010, 07:23 AM   #9 (permalink)
I've been planting the pinky on the guitar whenever I play for 30 something years . Never had a problem with it.
I have however in the past few years been hybrid picking more and more and I have a floating hand for this.
Paul
Pauljazzguitar is offline   Reply With Quote
Old April 25th, 2010, 07:42 AM   #10 (permalink)
JayFreddy's Avatar
Paul
Hi Paul, do you have any samples of your playing? I did a search on Youtube to try and find "fast and fluid" players who posted their pinky, but I couldn't come up with anything. The closest I found was Merle Travis' doing his Kentucky Thumbstyle thing, but that's not strictly flat picking...
I'm sure there are some "fast and fluid" players who post the pinky, but I can't think of any... The ones who float are much more common.
Jimmy Page has a habit of posting his pinky intermittantly, it's not a consistent thing, but it's a safe bet that it contributes to his legendary sloppiness.
http://www.youtube.com/watch?v=kXNqJx9H75s
Old April 25th, 2010, 08:53 AM   #11 (permalink)
brokenjoe's Avatar
I play with the outside of my palm ever so lightly on the bridge -actually it's more closer to the back of the bridge, with my fingers up most of the time. For certain things, I'll drop my pinky where it ever so lightly brushes against the body to use as a depth gauge.
I'm not sure if I buy into this whole 'right way, wrong way' thing. Jeff Beck rests the side of his fingers on the top of the guitar a lot. Mind you, he doesn't use a pick, and usualy has the trem bar in his hand.
Jim Campilongo puts his pinky down occasionally, as do lots of guitarists. I think I'd find it limiting if I had my fingers anchored all the time though.
I also play Bluegrass banjo. I've seen heated arguments over whether it's necessary to have one, or two fingers fingers planted!
Yes, it's another photoblog...
brokenjoe is offline   Reply With Quote
Old April 25th, 2010, 11:24 AM   #12 (permalink)
emu!'s Avatar
This question has come up a few times since I joined here. From my perspective, I used to be a pinky anchor person. All the world was in sync.
THEN, I decided to learn chickin' pickin'...which uses the picking fingers along with the plectrum. MY WHOLE WORLD WAS SCREWED UP! I had to re-learn my picking technique...using the palm heel plant...losing the pinky anchor.
THEN, I decided to purchase a Les Paul. IT iS ALMOST IMPOSSIBLE TO PALM HEEL PLANT ON A LP! Back to pinky anchor.
So, I've come to the conclusion that, depending on what type of guitar and what type of picking technique used, a person should be able to do both.
emu! is offline   Reply With Quote
Old April 25th, 2010, 12:46 PM   #13 (permalink)
Joe-Bob's Avatar
Don't "anchor" your hand at all. Go ahead and learn to be accurate now, and get it over with. You can't strum with your hand anchored, why would you play other stuff that way?
Only God Knows Why...
Old April 25th, 2010, 02:34 PM   #14 (permalink)
jazztele's Avatar
i gotta float--i use those fingers!
i tried pinky anchoring once...i would imagine somebody could injure themselves doing it. I'm with joebob, a little good technique goes a long way.
Jeff Matz, Jazz Guitar: http://www.jeffmatzguitar.com
jazztele is offline   Reply With Quote
Old April 25th, 2010, 03:33 PM   #15 (permalink)
awfulguitarnois's Avatar
I've only been playing about a year and a half, and the first year I struggled mightily with my picking hand (I really only flat-pick, though). I kept hitting the wrong string. Funny thing was, I was pinky posting. I decided to completely stop anchoring and as others have said, my picking is much more fluid and ironically, more accurate. But that's just me.
MJT Telecaster | Reverend Warhawk 390
TU-2 --> OS Clone --> ZVex Instant Lo-Fi Junky --> Dead Hipster --> Tonebender clone --> Boss DM-3 --> Allen Hot Fudge
awfulguitarnois is offline   Reply With Quote
Old April 25th, 2010, 03:51 PM   #16 (permalink)
I don't really have a consistent strategy (i think), but from what i did in the last five minutes, i think i mix floating, resting the base of my hand on the saddles and sometimes planting a thumb. Normally i pluck basslines with my thumb though, which seems to offer enough (though moving) support
mr.jef is offline   Reply With Quote
Old April 25th, 2010, 04:00 PM   #17 (permalink)
My Dad used to plant his pinky on the guitars body but I never did. It wasn't a consious thing I just learned to play that way naturally. It seems an effort for me to plant the pinky and makes it more difficult.
Gareth John is offline   Reply With Quote
Old April 25th, 2010, 04:11 PM   #18 (permalink)
emu!'s Avatar
I guess that would work if you keep your body perfectly still...but when your on stage and in "the moment", it's pretty difficult to stand that still while picking individual notes.
Old April 25th, 2010, 04:20 PM   #19 (permalink)
redstringuitar's Avatar
Some very useful info here, I have to admit to being a pinky and heel planter at times...but I hate the constriction and tension build-up, so I'm going to make a conscientious effort to get accurate and stop that nonsense from now on.
That said, I understand that in flamenco picking, the thumb should be rested on the E string while it isn't being played.
Don't blame the view, blame the scenery
redstringuitar is online now   Reply With Quote
Old April 25th, 2010, 04:34 PM   #20 (permalink)
fezz parka's Avatar
Both. Palm muting can be very important.
