Old November 7th, 2009, 09:03 PM   #1 (permalink)
Albert Collins sound
Any ideas on how to get Alberts sound ? I heard he used some open cord tunning any idea what cord he tuned to ? any body have any GuitarPro files of his work ?
wb4h is offline   Reply With Quote
Old November 7th, 2009, 09:15 PM   #2 (permalink)
brokenjoe's Avatar
Albert used a D minor tuning, and just capo'ed up the neck when hew wanted to switch keys. He also played with his thumb and fingers, which was a BIG part of his sound.
He'd whack that low string with his thumb while picking lead notes with his fingers in a sort of mutant banjo style.
He played through a Fender Quad Reverb wide open with everything on 10 except for the bass, which he would use as his volume control.
"Son, always eat your vegetables.... and stay away from those whole tone scales!!"
brokenjoe is offline   Reply With Quote
Old November 7th, 2009, 09:22 PM   #3 (permalink)
Thanks brokenjoe
Old November 7th, 2009, 09:24 PM   #4 (permalink)
klasaine's Avatar
Don't forget the 100 foot long cable that he'd use too (so he could walk around the club and even out the front doors). Though his sound was 'piercing' to be sure, can you imagine what it would have sounded like with just a 20 footer!?
Old November 8th, 2009, 12:27 AM   #5 (permalink)
On the pitch side of things, he loved to do that fast trill into fade out between minor and major third. He also liked hemiolas, such as C Eb C Eb C Eb C Eb C Eb all as triplets. Also, if he did a run down to the major third, he usually followed it by a minor 6th up to the tonic.
larry
Larry F is offline   Reply With Quote
Old November 8th, 2009, 08:25 AM   #6 (permalink)
Tele-Bender's Avatar
What a sound!
Tele-Bender is offline   Reply With Quote
Old November 12th, 2009, 10:27 AM   #7 (permalink)
JTM45blues's Avatar
Fairly certain that Albert used Open Fm tuning. If you watch the videos and play along with the videos then realize that the capo is usually 1 fret higher. For instance, alot of time he plays in D, and is capoed at the 9th fret. He uses lots of horn keys, because he plays with horns. So lots of stuff in C, D, and Bb.
You can get pretty close to his tone with a Deluxe Reverb reissue or even a Super Reverb. Use the bridge pickup, lots of volume and a significant amount of reverb.
Don't forget the heavy vibrato at the end of phrases, and his wild slides up into notes and then quickly sliding back down. Then do some "cussing" on the low strings. Do a few trills on the 1st and 2nd strings in first position and you'll be right in Albert's neighborhood.
BTW, Anson Funderburgh can also completely dial in Albert any time he wants, check out his youtube videos, he nails that tone on his 57 strat through his old BF Super Reverb.
JTM45blues is offline   Reply With Quote
Old November 13th, 2009, 07:07 PM   #8 (permalink)
What a great term. Can you describe how that is played?
larry
Old November 14th, 2009, 04:22 AM   #9 (permalink)
brokenjoe's Avatar
If I may be so bold as to attempt to explain.....
AC played with his fingers, and he used to have a move where he yanked the low root (Always an open note, because he capoed to his key) with his thumb, a split second before he played a higher note.
It's hard to explain, but it was sort of a da-DA sound -if that makes any sense!!
I don't play with my fingers, but I've got an AC type riff that I like to do that is inspired by that one.
Say you're playing in 'A'. Play the open G string hard, and then (really) quickly hammer on to the seventh fret, and bend up a tone. The idea is, is that the open G is inconsequential -I'll do it in any key- but it's an almost percussive 'pre-note' that adds to the effect.
It doesn't have to be the 'G' either. I'll do it on any string, but I usually prefer to use it in a riff where I have a big contrast from low to high note.
Old November 17th, 2009, 01:10 AM   #10 (permalink)
JTM45blues's Avatar
Play your 4th, 5th and 6th strings in a staccato fashion with a popping motion to your fingers, then follow that up with some high string snaps. That's cussin' the Albert Collins way.
BTW, a master on this style, is a forum member here, Kenny Blue Ray, I believe he goes by KBR, please look him up, he's an incredible player, with phenomenal tone.
Old November 21st, 2009, 11:47 AM   #11 (permalink)
Albert Collins was & will forever be " THE MAN "!
SnidelyWhiplash is offline   Reply With Quote
Old November 21st, 2009, 12:16 PM   #12 (permalink)
backalleyblues's Avatar
Couple other details to fill out the AC sound-
That Quad Reverb had JBLs in it (I believe D120s), this made for a LOUD amp, to say the least...
His main axe was a '66 telly, he painted on the binding 'cuz he liked the look-some sort of humbucker on the neck... he always had the ashtray on as well, so any kind of muting was done with his fingertips...
Before he got the Quad Reverb, he was using a BF Bandmaster top w-2x12 cab... not sure about his early stuff, but I'll bet it probably was a 3x10 Bandmaster (tweed).
He used to use Dm, then went to Em, then finally Fm over his career. Strings were .010, .013, .017, .024, .032, .038. Capo was God-knows-what, wrapped in electrical tape, and as noted above, moved it to the key he was playing in. Albert was mostly a first-position player, and kinda like Gatemouth Brown in that regard (though Gate could play a LOT of jazz!).
+1, Albert was THE MAN!!!!
Franc Robert
When Will The Blues get YOU?!?!?
The Delta Aces
http://www.myspace.com/francrobert
backalleyblues is online now   Reply With Quote
Old November 21st, 2009, 12:49 PM   #13 (permalink)
AMEN!
Old November 27th, 2009, 06:31 AM   #14 (permalink)
Kirfew's Avatar
looks like he's got a paf in the neck, which explains why his tone sort of reminds me of the other great albert - albert king.
Jazz is not dead. It just smells funny. - Frank Zappa
Kirfew is offline   Reply With Quote
Old December 8th, 2009, 11:28 PM   #15 (permalink)
black_doug's Avatar
I was just on YouTube watching him and I had thought he was using the neck pickup to get his tone. In fact it seems that it's the bridge he's using most of the time. Sometimes he starts out on the neck and then quickly switches to the bridge. It could be that the neck gets more use when he's playing rhythm, when he's jammin, I don't know.
"Men are admitted into heaven not because they have curbed and governed their Passions, or have no Passions, but because they have cultivated their Understandings."
- William Blake
black_doug is offline   Reply With Quote
The Ice Man - Mr. Albert Collins! seansdadj Bad Dog Cafe 13 January 28th, 2008 06:23 PM
Albert Collins = THE Man. P-Zilla Telecaster Discussion Forum 9 April 24th, 2007 10:20 PM
MIJ Albert Collins? RichardL Telecaster Discussion Forum 1 December 24th, 2005 10:19 AM
Albert Collins TG Bad Dog Cafe 25 July 18th, 2005 01:17 AM
Albert Collins........ Pedalworld Telecaster Discussion Forum 21 September 22nd, 2003 01:30 PM
