The Thrill Is Gone
Here's something fun, that really helps to open up the old Standard, "The Thrill Is Gone".
So, it's a modified 12 Bar Blues Form, with these Changes: Bm7 Bm7 Bm7 Bm7 Em7 Em7 Bm7 Bm7 GM7 F#7 Bm7 Bm7 As you can see, the real "action" happens over Bars 9 and 10. And this opens the door to some interesting possibilities. One thing I like to do, is Superimpose one Chord over another. So in Bars 9 and 10, I will often play the ii-V of the GM7 Chord. This yields a cool, Jazzy quality to the proceedings. Code: Some different ideas for superimposing various chords over M7 chords. ---------------------------------|------------------------------------------|- ---------------------------------|---------------------------10--13--10/11v-|- ---------------------------------|------------9--12------11-----------------|- -------------5-4-------7--4v-----|--------10---------12---------------------|- ----------7------5--7------------|----12------------------------------------|- ----5--8-------------------------|------------------------------------------|- Over GM7 Play it's ii V (Am D7) These resolve to F#7 As In "The Thrill ---------12--15--12-----------------------------------|----------------------- -----13--------------13--10-------------10/11-10/11v--|----------------------- -14--------------------------10h11--------------------|----------------------- ------------------------------------12----------------|----------------------- ------------------------------------------------------|----------------------- ------------------------------------------------------|----------------------- Is Gone" by B.B. King ------------------------------------------|----------------------------------- ----------7b8----------6b7----------------|----------------------------------- -------5------------7---------------2b3---|----------------------------------- --5h7----------5h7----------2h4-----------|----------------------------------- ---------------------------------4--------|----------------------------------- ------------------------------------------|----------------------------------- Thinking Of A "Country" Type Of Feel We Could Add Some 6ths. And Some 1/2 Step Bends. For these, I'm thinking of those "Faux-Pedal-Steel" types of Bends. So, let all the Notes ring as long as possible. Now you've really "set-up" the last 2 Measures ( Bars 11 and 12) for some real "Blowing"! Let me know, if you give it a try. And if you have any ideas for TTIG share them here. Maybe we can get a lot of cool ideas going. Last edited by Budda; July 2nd, 2009 at 12:47 AM. |
Is it that you've reversed the order of the changes of bars 9 and 10 because typically it would be played GM7 to the F#7.
I played through it the way you've written but I can't make it sound right to my ear. If I play bar 9 and 10 like this F#7 - GM7/F#7 it sounds okay but moving from the #VM7 to the I sounds awkward to me.
Oh...the girls are out to bingoand the boys are gettin' stinko...." Sudbury Saturday Night |
You are correct Boneyguy!
Dan
My Music Page |
oooh...but what if you played bars 9-10 like this...
| F#7 | Gmaj7(2 beats) A7 (1beat) Bbdim (1beat) | sure, it ain't "thrill" anymore, but it's a cool minor blues turnaround...
"Jazz isn't a what, it's a how" -- Bill Evans |
I see the problem. I think.
I should have written out the lines a little more clearly. Each Line covers both Bars 9 and 10. Like this: Code:
-|---------5-4-----7-|-4v---|-|-----------------------------------------------
-|-------7-----5-7---|------|-|-----------------------------------------------
-|---5-8-------------|------|-|-----------------------------------------------
GM7...............F#7
Below, pretty similar. 1/8 Notes leading to a sustained Note (A#). Code:
-|-------------------------|----------|-|------------------------------------- -|-------------------10-13-|-10/11v---|-|------------------------------------- -|--------9-12----11-------|----------|-|------------------------------------- -|-----10------12----------|----------|-|------------------------------------- -|--12---------------------|----------|-|------------------------------------- -|-------------------------|----------|-|------------------------------------- GM7.......................F#7 Below, I removed a Note for easier timing. So, it's also 1/8 Notes leading into a 1/4 Note and a Dotted 1/2 Note. (In Bar 9, the G String, 10h11 counts as a single 1/8 Note.) Code:
-|-------12-15-------------------|----------------|-|------------------------- -|----13----------13-10----------|----------------|-|------------------------- -|-14-------------------10h11----|----------------|-|------------------------- -|----------------------------12-|-10/11-10/11v---|-|------------------------- -|-------------------------------|----------------|-|------------------------- -|-------------------------------|----------------|-|------------------------- GM7..............................F#7 Below, let the Notes ring as long as possible. It's basically 1/16 hammer 1/16, 1/16, 1/16 Bent into Dotted 1/8, with a 1/16 Rest. Repeated Rhythm for Beats 3-4. Code:
-|-------7b8-------6b7-|-------------|-|--------------------------------------
-|-----5---------7-----|-------2b3---|-|--------------------------------------
-|-5h7-------5h7-------|-2h4---------|-|--------------------------------------
-|---------------------|-----4-------|-|--------------------------------------
GM7....................F#7
So, no. I had it GM7 to F#7. It's just that I never resolve the GM7. I play the Am7-D7, and then roll right into the F#7 with Chord Tones of the F#7. But the G never gets it's resolve. Adds to the new vibe, I think. Hope this makes it easier to follow. Let me know, if not. Now, some of those Changes you Guys threw up look promising! Back to the Woodshed for me............ |
For the V turnaround in this tune, I like GM9-F#7#9-F#7b9. Fairly stock, but effective. These grips'll do:
---------- -9--10--8- -11--9--9- -9---8--8- -10--9--9- ---------- I also sometimes like *resolving* to a I chord that contains no 3rd, such as this A/B shape, or B11no3, or whatever you want to call it. You can easily get the m3 in there as desired with a barre across the fifth fret; the m3 (D) lives on the A string. However, I like the ambiguous nature of the unresolved resolution...! The trick here is to let that chord hang for just a little while, and then quickly bring the listener's ear "back home" with some sort of Bm voicing that definitely does contain a minor third. -(0)-- --5-- --6-- --7-- ----- --7-- |
Along the lines of what you just mentioned Tim, I too like to sort of not resolve to im right away. A lot of times I'll hang on a IV chord (post turnaround) voiced like this ...
E13 ----------x------------- ----------5------------ ----------6----------- ----------6----------- ----------5---------- ----------x----------- Voiced this way, with the 7th on the bottom, it won't get in the way of the bass hitting a B. And, it can be thought of as sort of a rootless Bm11 thing anyway. (It doesn't just have to be on a blues either - any minor tune that has a i chord for the last two bars.) * Another one I stole from a piano player * |
Ken, I've used that grip a bunch, but always as a dominant extension (Wynton Kelly got tons of mileage out of it as a piano voicing) - but I'd never made this connection. That makes perfect sense, thanks.
I also like to treat I and IV minor chords as separate little dorian entities. So obviously for B minor, the parent key is A. A stock move is to play ii - iii - IV (over either or both of the actual I and IV minors). Typically I'd treat ii and iii as stock min7 voicings, but I like to dress up the IV just a tad; I like 1 - 7 - 9 - 5, low to high; or, as viewed as a Bm chord, b3 - 9 - 11 - b7. ---- -10- --9- -11- ---- -10- |
cool ideas guys.
i learned about some of this "suspended resolution" stuff from, you guessed it, a piano player. he was also big into the idea guitarists think of T-Bone automatically with--starting a half step off key with a dominant chord in a "standard" blues. though, getting a little off track, my buddy and mentor joe (now passed) would have done it like this, i think... bars 9-12, 1 beat per chord... Gmaj: 7x578x Gmaj7: 7x577x G6/A: 5x575x A7sus: 5x577x C#m7b5: x4545x C#m7b5: 3x242x F#7+5: 2x233x F#7: 2x235x Bm6: 7x677x F#7#9: xx4355 C#7#9: x4345x C9: x3233x Bm/maj7: x2032x (whole bar, let sustain, and then back to the i) yeah, that's fun...you can also take what i have for bar 11, make it two beats per chord, and span that progresion for bar 11 and 12...then we get back to the i as the m/maj7....ooh...
#14 (permalink) | |
#15 (permalink) | |
#17 (permalink) | |
So, now that we've corrected my Chart, did you try the Lines I posted? Any use for you? Or, did it spark any ideas? |
| 1st recording - humorous cover of the Thrill Is Gone | tweeddeluxe | Twanger Central | 2 | March 11th, 2008 09:03 PM |
| The Thrill is Gone | Rich Rice | Twanger Central | 6 | November 15th, 2006 06:44 PM |
| B.B. King turnaround "The thrill is gone" | DougF | Tab, Tips, Theory and Technique | 2 | February 28th, 2006 03:39 AM |
| Blues "The thrill is gone" what do you think | bluesjammer | Twanger Central | 1 | January 22nd, 2006 05:53 PM |
| Thrill Of A Lifetime, Part 2. (NTC) | jumpnblues | Telecaster Discussion Forum | 4 | November 19th, 2003 10:59 PM |
