Old June 30th, 2009, 12:50 AM   #1 (permalink)
How to stop unintentional pull-off?
When I play this string:
|--5--0-----0--2--0-----0--5--0-----0--2--0-----0--
|--------2-----------2------------2------------2----
The open B sounds when I lift my index finger (i) from the C# to go to the F#. This is a pull-off but unintentional as I don't want the B to sound.
So the question is how to prevent this?
These are 16th notes at 120 bpm (8 nps).
Thanks,
Hugh
jsntg is offline   Reply With Quote
Old June 30th, 2009, 01:10 AM   #2 (permalink)
jazztele's Avatar
i was able to do it--index for the C#, use your middle finger for the F#, and pinky for the A.
"Jazz isn't a what, it's a how" -- Bill Evans
jazztele is offline   Reply With Quote
Old June 30th, 2009, 01:15 AM   #3 (permalink)
Jazztele, does this mean you are partially releasing your index into a mute?
Also curious if you're using a pick, are your picking strict alternate or economy?
Old June 30th, 2009, 01:15 AM   #4 (permalink)
rangercaster's Avatar
slow it down and practice it a lot ... then speed it up ...
"Work is the curse of the drinking classes."
Oscar Wilde
Old June 30th, 2009, 11:33 AM   #5 (permalink)
jazztele's Avatar
the index finger is not released, but it does "pivot." when the middle goes for the F#, the knuckle on the index finger is pointing more toward the nut. when the pinky extends for the A, the finger pivots and the knuckle is more parallel to the fret...but i never need to release pressure...
as for picking, straight up alternate, though i must admit, my first instrinct was to treat every F# to open E and A to open E as a pull off, and i played those with my picking hand middle finger, hybrid style...then the speed really took off, but that might not be the sound you want...
Old June 30th, 2009, 11:37 AM   #6 (permalink)
Thanks Jazz, that works great and sounds much better!
H
Old July 1st, 2009, 12:58 PM   #7 (permalink)
The index finger on the C# does indeed mute that note when time comes to determine its duration. ONE of the big tehcnical 'errors' I see guitarists make is to pull the fingers far away from the strings. KEep things close and you can control things like this. IT becomes second nature...your ears will govern your fingers without concious thought, ime. I play this series of notes with just the index and the pinky with no 'pull off' problems on the C#. My index finger always controls the strings.....that is, keeps them muted when not played. The picking hand has some responsibility for this muting/damping, also, when the fretting hand can't take the 'assignment'. Soemtimtes, both hands are busy keeping extraneous string vibrations under control....my ears demand that my hands keep those noises from happening. PRactice, practice, practice.
Stop me! Help! KC Amp Central Station 6 February 13th, 2009 06:11 PM
stop me before I mod again Harry Stone Tele-Tech 10 January 6th, 2008 01:46 AM
Stop Pete Galati Bad Dog Cafe 0 August 16th, 2007 08:38 AM
Stop me before I bid again! Tim Armstrong The BASS Place 29 September 11th, 2006 01:13 PM
Stop the MPA mearlhart Tab, Tips, Theory and Technique 22 January 10th, 2006 02:18 PM
