Old June 26th, 2009, 07:05 PM   #1 (permalink)
Herco Flat/Thumbpick fit on my thumb??
Hi there...
What can I expect from these picks? I doubt that they would fit on my thick thumb.... Or can I order them in different sizes?
HELP me outa here !!!
Robert from the Netherlands
Robert Lottmann is offline   Reply With Quote
Old June 26th, 2009, 07:06 PM   #2 (permalink)
surfco's Avatar
Yeah, they have them in different sizes.
surfco is offline   Reply With Quote
Old June 26th, 2009, 07:26 PM   #3 (permalink)
VENDOR
Ronkirn's Avatar
Personally, I think you're kinda stuck with whatever size your thumb is.
Ron Kirn
www.ronkirn.com
Ronkirn is online now   Reply With Quote
Old June 26th, 2009, 07:32 PM   #4 (permalink)
Spidercaster's Avatar
I think they come light, medium, and heavy, like regular picks, but I've never seen them
sized by "thumb size". I use them occasionally, and like them over traditional thumb picks.
".................what daily routine?" - Sol Philcox
www.LiveFromMyLivingRoom.com
Spidercaster is online now   Reply With Quote
Old June 26th, 2009, 09:23 PM   #5 (permalink)
VENDOR
mellecaster's Avatar
A saucepan of very Hot water, and some pliers will make them any thumb size you want.
Old June 27th, 2009, 02:07 PM   #6 (permalink)
Valvey's Avatar
The lighter ones don't stay on the thumb too securely because the loop is too flimsy. I also find these aren't as effective in doubling as a flatpick as some other types-- e.g. Fred Kelly Slick Pick, with its shorter, blunter blade.
Valvey is offline   Reply With Quote
Old June 27th, 2009, 03:25 PM   #7 (permalink)
jhundt's Avatar
I use those all the time. They work very nicely for me and how I play. I don't think they are available in different sizes - only different thickness light-medium-heavy as Spidercaster said.
I have never been able to find them here in Holland, but I had a friend bring over a bunch for me.
Robert - I see you are new here. Welcome! I maintain an email list of NL Tele players; we have organized several Tele jam-sessions in the last 4 years. If you are interested please email me and I will add you to the list.
the address is: jhundt@ziggo.nl
jhundt is offline   Reply With Quote
Old June 27th, 2009, 03:59 PM   #8 (permalink)
IME, these do not function as true thumbpicks do...that is, they are too light for thumb only use. They do keep a person from dropping a pick since the thumb 'ring' keeps the pick in place, but they aren't sturdy enough to pick 'thumb alone' things, ime.
Old June 27th, 2009, 08:40 PM   #9 (permalink)
Thorpey's Avatar
just use a jazz pick and 3 fingers
then you'll never have to worry about picks fitting your big thumb
"No charge for mistakes!" - Danny Gatton
Thorpey is offline   Reply With Quote
Old July 2nd, 2009, 06:54 PM   #10 (permalink)
Herco compared to Golden Gate Extra Heavy
I've used the Golden Gate Extra Heavy thump pick for almost 2 years now. I've been working on speed lately and tried out the Herco heavy. I was able to pick 5 bpm faster across multiple strings instantly. The Herco has a tinnier sound than the GG which is a downside for me.
As far as staying on your thumb, the Herco heavy 'sticks' as well if not better than the GG which has a thumb flange for extra stability. The main difference between the Herco heavy and the Golden Gate Xtra Heavy is:
- Thickness. Herco heavy is about 1/2 as thick as the GG Xtra Heavy and about 3/4 as thick as a National thumb pick and other bluegrass heavies. The physical thinness of the Herco means slightly more maneuvering room between strings and slightly less travel when outside picking multiple strings. This advantage here is non-trivial.
- Swing weight. The Herco heavy is about 1/2 the weight of the GG Xtra Heavy
- Flex. The Herco heavy flexes slightly while the GG Xtra Heavy does not flex at all.
- Rotation. The Herco heavy will give at the fulcrum point on top of the thumb yielding a quicker release from the string.
- Composition. The Herco is a softer plastic than the 'pearloid' GG. That said, it feels 'slippier' than the GG across the strings.
Being thinner and softer, the Herco wears out quicker. I can get over 250 hours out of a GG pick before it has degraded significantly but the Herco is starting to nick / crack after about 20 hours.
Hugh
jsntg is offline   Reply With Quote
Fralin Blues Special - flat, flat stagger, hybrid? DMace Just Pickups 4 November 14th, 2008 10:59 AM
Rockabilly Thumbpick Anyone? TeeBird Tab, Tips, Theory and Technique 10 September 1st, 2008 12:25 PM
Flat Colors and Flat Clear Coats Flashback Tele-Tech 2 September 28th, 2006 05:43 PM
Herco Thumpick-cum-flatpicks in Europe Iain Telecaster Discussion Forum 6 December 13th, 2003 06:01 PM
flat III and flat VII progressions Matt Plescher Tab, Tips, Theory and Technique 1 August 30th, 2003 08:00 PM
