What do you do to fatten up your strats tone? - Telecaster Guitar Forum
Old September 8th, 2007, 08:54 AM   #1 (permalink)
I'm primarlily a tele player but I've been uysing the strat a bit more lately. Wondering wihat some of you may do to fatten up your tone.
I'm currently playing an AM. Series strat with Texas Specials through a vox AC30. I'm using the following effects in my rig:
Barber Tone Press, Barber LTD, Barber Direct Drive, Boss Digital delay, Arion Chorus, boss TU 2 tuner
I really like you the strat sounds with the OD pedals and don't want to loose the basic chimy tone . Just want to fatten up the clean tone so it is not so thin on its own.
Teleman is offline   Reply With Quote
Old September 8th, 2007, 09:36 AM   #2 (permalink)
SixStringSlinger's Avatar
Maybe you can use the OD and roll back the gain or volume, so you have some grit when you pick hard, but not too much difference from the original tone when you pick softly.
"Is a hippopotamus a hippopotamus, or just a really cool opotamus?"
-Mitch Hedberg
SixStringSlinger is offline   Reply With Quote
Old September 8th, 2007, 09:52 AM   #3 (permalink)
adjust the amp....
works for me !
y.m.m.v.
Sponsored Links   #
Old September 8th, 2007, 09:57 AM   #4 (permalink)
PhatTele's Avatar
Ditto...turn up the midrange on your amp. There's plenty of warm dirt in the midrange that you can play with.
Old September 8th, 2007, 10:31 AM   #5 (permalink)
JohnK24's Avatar
If you got a Barber Tone Press, it's easy...a small amount of the compression-maybe 8 or 0 o'clock , then add some of the clean signal in ..around 10-11 o'clock and then dial in the volume to taste. If the Tone Press and Texas Special get you a phat tone, then you've got your amp dialed in without enough bass. Perhaps playing .011 gauge strings, tune down to Eb...that's the easiet way to phat strat tones.
JohnK24 is offline   Reply With Quote
Old September 8th, 2007, 11:26 AM   #6 (permalink)
Crank your amps master volume to almost full.........adjust the individual channel volume to get the right tone.......this helps to get some 'dirt' from the tubes. Sounds really good (at least on my amp!!). I have 3 EQ adjustments where I have the mid and bass on almost full and the treble setting about 1/2 way. I also use my neck PUP a lot; gives you a bluesier, more gutsy tone. My amp also has one huge 15 inch speaker so that thickens the sound as well. I find that by manipulating the channel volume rather than the master, the chimes remains but the tone has more balls...........
thaus is offline   Reply With Quote
Old September 8th, 2007, 12:08 PM   #7 (permalink)
PK
PK's Avatar
I swapped out my saddles and trem block for Vintage Callaham's stainless steel Saddle & block. IMHO the sound is much more fat & Chimey when clean compared to stock Am series (now I really love mine:))
PK
PK is offline   Reply With Quote
Old September 8th, 2007, 01:46 PM   #8 (permalink)
NWinther's Avatar
Usually a good setup and maybe 11-48/52 strings??
And readjust the amps for more fat tones.
You are not thinking, you are merely being logical.
NWinther is offline   Reply With Quote
Old September 8th, 2007, 04:29 PM   #9 (permalink)
most guys using a "fat" strat tone are leaving somekind of boost on all the time and then riding the volume and usually kicking in a second peda lfor actual "dirt"
WNC Bill is offline   Reply With Quote
Old September 8th, 2007, 04:40 PM   #10 (permalink)
mdkrek's Avatar
Yup 11's make a huge diff in tone, SRV used 13's I think but tuned down a 1/2 step
Sing a song, play guitar
Make it snappy
mdkrek is offline   Reply With Quote
Old September 8th, 2007, 07:48 PM   #11 (permalink)
Former Member
Turn it up as the late Ronnie Van Zandt said on Sweet Home Alabama.
Old September 8th, 2007, 08:09 PM   #12 (permalink)
bobthecanadian's Avatar
EMG - SPC
[COLOR="Navy"]It don't mean a thang if it ain't got that [/COLOR][COLOR="Red"]TWANG!!![/COLOR]
bobthecanadian is offline   Reply With Quote
Old September 9th, 2007, 12:09 AM   #13 (permalink)
octatonic's Avatar
I kick in an octaver and midrange boost for solos.
Old September 10th, 2007, 07:31 AM   #14 (permalink)
TG
TG's Avatar
That's a good example of a 'good' strat tone, but it also shows how a tone that sounds good played by someone else doesn't necessarily work for yourself. What I mean is, I can hear that and think how nice it sounds but if I imagine being onstage playing a guitar and that sound was coming out I know I wouldn't be happy at all and would want to tighten and 'fatten' it up somehow. Most strat recordings that I like are like that if I listen to them and imagine my guitar sounding that way.
Those of us who feel comfortable with and respond to the type of sound a tele makes often seem to have a hard time with the relatively thin and hollow sound of a strat, even when it's overdriven or boosted or whatever.
If that's the case then there's very little you can do, I suspect.
Yet I'm typing this with a strat on my lap, as a matter of fact. I abolutely adore the tones I get from it sitting here, but I can't use it onstage to save my life. Not fat/solid enough, and I don't want to have to effect the life out of the thing to make it so.
Old September 11th, 2007, 12:33 AM   #15 (permalink)
bek
bek's Avatar
Just drop in one of our own Deaf-Eddie's Fat-O-Caster switches. Cheap, improves your tone control setup, allows all the normal tones and adds the big-dog in-series and in-series/out of phase and the very cool semi-Tele neck and bridge combo. No-brainer.
bek is offline   Reply With Quote
Old September 11th, 2007, 01:01 AM   #16 (permalink)
tjalla's Avatar
+1 on a few already mentioned
11s
Tone pot on bridge pup ala Jimmie Vaughan/Eric Johnson
Mids at the amp and/or cranking the amp
That'll go a long way...
tjalla is offline   Reply With Quote
Old September 11th, 2007, 02:17 PM   #17 (permalink)
purpletele's Avatar
yup
all good suggestions.
Sometimes I use an old Electro Hamonix LPB -1(back when stoned out NYU art students were building them). It's really FAT sounding, it just kinda annoys me that it only has a slider switch.
purpletele is offline   Reply With Quote
Old September 11th, 2007, 05:23 PM   #18 (permalink)
Wildhawk's Avatar
Like others I use the right amp.
Wildhawk is offline   Reply With Quote
Old September 11th, 2007, 07:13 PM   #19 (permalink)
Telarkaster's Avatar
I was playing the other day through a Peavey Classic combo and it wasn't giving me any love. My Strat sounded thin and weak and wasn't cutting through the mix like it should. The other guitarist was playing an SG through a Marshall half stack and I was drowned out. Then I fiddled with the knobs and cranked the volume and got the sound I wanted. Too bad the jam was almost over by then.
I told that story to the salesman who sold me the Strat and he suggested I try a Marshall compression pedal. Bam! Instant volume boost, then I fiddled with the knobs and got that compressed sound that was big in the 80s. I was enthused at first, but when I turned it off I realized that I like the sound of a pure Strat better, no pedals. I bought the Strat for it's sound, I didn't want to mess with it. The compressor could serve as a boost pedal, but I decided to stick with the volume knob.
Next jam I played through the regular 100 W Marshall half stack and everything was just right...
To summarize:
-fiddle with the knobs on what you have
-compression may work if you can live with that sound
-find the right amp
I've been thinking of going back to pick up the compression pedal and giving it another chance...
Telarkaster is offline   Reply With Quote
Old September 11th, 2007, 11:02 PM   #20 (permalink)
Former Member
mellecaster's Avatar
Your Strat....1 quality cord....into a Nice Amp....and Practice your A$$ off...it's simple, but it Works !
» Random Photo for Guests
before
» Recent ThreadsGuests
Fender Logan Custom Guitars
