How many trems still have a spring in the hole?
I unscrewed my trem bar to have a look at the spring and I couldn't get it out. It was completely stuck. It was jammed in real tight. I tried various methods to get it out and they all failed.
Eventually, I got a hand drill with a bit that fitted inside the spring and very carefully drilled into the hole and the spring wound onto the bit and out it came. GENIUS. I now use the trem bar without a spring because I don't want it to happen again. Does anyone-else not use a spring? Is a spring rather surplus to requirements?
"You won't part with yours either" Fender adverts 1957 http://www.myspace.com/cradlehallmusic Last edited by cradlehall; May 12th, 2007 at 04:01 AM. |
I got fed up of the sloppiness, so I made a bar holder that stays screwed permanently into the trem block, allowing me much finer tolerances where the trem bar slots in.
It's the rusty thing in the photo. (Ignore the other devices on the guitar, they just stop any de-tuning during string bends).
Using the trem arm without the spring can cause the threads to distort at the end if you are screwing it in all the way to help keep it in place. I can't see why you shouldn't/wouldn't use a spring, they are cheap, and keep the arm in place. And you just shot yourself in the foot cradlehall because you already admitted you can now get the old ones out easily enough.
They don't last forever, buy a pack and use them up, then buy another pack. |
#7 (permalink) | |
"You won't part with yours either" Fender adverts 1957 http://www.myspace.com/cradlehallmusic |
#8 (permalink) | |
#9 (permalink) | |
Hey Arby,
That's a freeky little trem unit you got yerself. I think I like it's funktion. Other than it looking really non-traditional, how does it work for you? Do you ever catch your hand on it, or something like that? Cheers, Bob PS - How about a shot of the whole guitar? Quote:
It don't mean a thang if it ain't got that TWANG!!!
#10 (permalink) | |
#11 (permalink) | |
I think all that removal work was overkill. Sears has a small inexpensive tool that pulls it right out. It looks like an awl with it's needle end bent a bit. It works swell everytime. I ALWAYS use the spring-no fuss, no muss. Just drop it in and screw the trem bar in until your desired level of tension is met and you're good to go. Actually, a very smart idea. I actually change them about once (maybe twice) a year.
"I'm a man who believes that right is right and wrong is wrong. Treat me right, and I will give you my all. Treat me wrong, and I will give you nothing. They don't like me for that, but that's the way I am." - Johnny Paycheck |
