Fezz Parka mod, not working!
I wired it exactly like this. I know the pickups work, I just changed it from a normal strat.
![]() Edit: How do I make the picture smaller?
"I thought, I'll get a Tele because I always hated them. I don't like the way they look or sound, so I'll go get one" - Alex Lifeson |
I tried both sides of the switch and it did the same thing. The bridge and middle pickups work sometimes, the neck is very quiet. The switch seems to be working right, and all the knobs do what I expected them to do. I know the pickups work. It's connected to the jack the way it should.
Are you using a no-load pot for the blender?
"Out here in the middle, where the buffalo roam, they're puttin' up towers for your cell phone..." --James McMurtry, via Robert Earl Keen |
I'll try a different switch. Should I take off the treble bleed? I added one because I use the volume knob a lot, but I don't think this should cause any problems.
Ok, I'll take it off. I tried a different switch and it works, except the neck pickup. It is a low output pickup (5.5k), but I'm not hearing much at all. I checked the wiring again, it's right.
Meaning, a no-load pot is required, right? Or, wrong?
I have a different neck pickup in it now, it works. But now the volume isn't working. It worked fine until I screwed it on the pickguard in and started putting strings on it
Sounds like you may be shorting something when you are trying to make everything fit into the wiring cavity. I've done this before. Try and make everything as nice a tidy as possible before trying to fit it all in as you install the pickguard. You could have also pulled something loose whilt fitting the pickguard.
The point of the no-load is to get the 'other' pickup completely out of the circuit. With a normal pot, when your using the bridge pickup you'll still have a tiny amount of neck pickup in the signal.
I modified the setup a bit to make it a bit more intuitive. 1) The way it's shown in the diagram, the blender pot at 10 is no blend, and turned all the way down, is full blend. It's shown like that so it can work with a normal no-load (that was designed for a tone control). So, I reversed the wires on the pot, so 10 is now full blend. 2) No-loads are audio taper, but a blender works better with a linear pot. With an audio pot, one pickup would blend in gradually, while the other came on all of a sudden. (I had a 300k linear sitting around) 3) Since I still wanted the 'other' pickup completely out of the circuit, I made a reverse no-load. I just put the nail varnish on the other side of the carbon trace. Hope this helps! I'm afraid I don't know what's not working in your setup. Maybe try disconnecting the blender from the switch, the test the switch connections with a multimeter. |
#17 (permalink) |
It works fine with a normal pot. I don't hear anything different.
#18 (permalink) | |
This is my favourite setup on my strat now, and I did some experimenting to get it right. I didn't try using a journal pot though, but having 250k in series with the pickup is probably going to block just about everything. Do you think it's about the same as a no load? |
#19 (permalink) |
LOL. It shouldn't have my name on it.
I wire up my Strats a little different. Three way switch, wired like a tele(B/B+N/N) and blend in the middle if I have the urge to "quack"(Which I very rarely do!) |
