NGD customized my Strat! (Sea Foam green and wide range humbucker content)
So I had a white mim strat sittin around. I think it's a mexican, I actually can't find a serial number. I bought it off a friend of mine for 150 bucks, which was a killer deal! I'm not much into strats, but I couldn't pass it up. He had a ball bearing nut and graphite bridge and what I think were lawrence pickups in there so it was pretty cool from the get go.
Here's a small pic of it in its original state
So I had it like this for a few months, then I got to thinking that I've always wanted a sea foam or surf green guitar. And since I already have a white blonde tele, I mught as well refinish my strat! I thought hard between surf and sea foam, but eventially decided on the slightly darker sea foam. The funny thing about sea foam green is it always appears bright blue in pictures, but it does have that green to it that the camera can't capture very easily.
Anyways, onto the refin project! I actually didn't have a guitar with humbuckers at the time, so I figured I might as well put humbuckers in it too. I hate to cut out the pickup route to "swimming pool style". I don't have a router so I carefully used a circular saw to put a couple cuts in the wings that poke out and used a chisel to pop em off. worked well enough! ![]()
It's MIM
Just a note: Your paint stick is so close to the sides of the neck pocket, I'd be good and sure no spray fills and drys between the two before you pull it.
A Twin always will cut it... but I don't recommend it for everybody. It's like a big dog, you have to take responsibility for it. Not to mention... be prepared to lift it. |
taking off the poly coat sounded like a lot more work than I wanted to do. Since it was white anyways, I figured I'd use that as the base. I scuffed it up with 400 grit sand paper so it felt like a big guitar shaped egg. I then used reranch rattle cans to spray on the sea foam green. I hung it off my back porch because I didnt want to figure out ventilation and plastic covering. Kind of half-assed..
![]() I also ordered some tinted clear coat to yellow up my neck a bit, and put on about 6 coats of that over the clear poly on the neck. Maybe you can help identify what kind of neck this is? It looks american, but then again what do I know? looks like it had different tuning machines in there before and some one replaced them with what I think are the vintage spec tuning machines. the holes for the tuning pegs are too big for the tuning peg collars I have, so that's an annoyance. But at least it works ![]() ![]()
sorry, these pictures are obnoxiously big..
I ordered my humbuckers. I went all out because it took me so long to paint, and I wanted something awesome. So I ordered Lollar Regals, which are the lollar version of the fender wide range humbuckers. That put me out quite a few bucks, but onward and upward! except, wide range humbuckers are quite a bit bigger than normal humbuckers. sunuvabitch, my swimming pool isn't wide enough for these suckers! I looked into it a bit more and found a thread with someone who put FWRH in a strat but said that it wouldn't fit in the neck, because the mounting plate would extend past the pickguard. http://www.strat-talk.com/forum/stra...ue-meanie.html Which I was not happy about because I certainly wanted one in the neck position and one in the bridge. not one bridge and middle/ So, I figured I could make it fit. barely. I took my dremel tool (again, no routers here) and went to town. I marked where the pickguard was in that tight spot for the neck pickup and made absolutely sure I didn't pass it. ![]() I also made it concave slightly so it actually overhung a bit. here's a picture of the wide range sitting comfortably in the neck spot. ![]() I did it to both the neck and bridge spot and was good to go
![]() I ordered a precut pickguard for 2 humbuckers, and measured it out and enlarged the holes to the right size with the dremel tool. I got black because I love the look of a black pickguard with chromed humbuckers Last edited by mraymond77; November 4th, 2011 at 01:26 AM. |
The suspense is tough...
Want.... to... see.... guard...... with WRHBs............. on.............
That suks!
How does it sound and what did you go with Pots and cap et al?
You can see how close the screw came to the edge. Its just barely hanging on! But it worked, and these pickups sound Incredible!! I wired it up with a 3-way selector switch, 2 volume pots, and one master tone all 500 k.
Boy, that is right at the edge of getting fit in.
You can always make a new guard one day if it bothers you. Looks really good, luv to hear that bad boy...
Yeah sorry about the jump, heh. But I might need to open it up again because the knobs sit a little high. I might need to put a washer on the cavity side of the pots to bring them down a bit. If I dow, I'll take a shot of the wiring. The cap I put on the tone pot is .047 orange drop.
#16 (permalink) |
BTW, I was going to say something when you initially did not widen the pool route beyond the inbetween wood removal. Was not sure you meant real WRHB size HBs.
I did almost the same thing once. Did a pine body for a P90 Squier II guard, and got a WRHB populated guard while the Nitro was curing. So had to open up the routes to get the WRHBs in it with a freshly painted body... grrr.... ;)
#17 (permalink) |
Good job there - and all without a router anywhere in sight!! You must have a very steady hand to tackle that with a circular saw...........!
So how does it sound?? We need some sound clips.
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad...... www.reverbnation.com/delthomas1 www.myspace.com/delthomas www.myspace.com/manalishinz |
#18 (permalink) | |
I'll get some sound clips up tomorrow I think. |
#19 (permalink) |
BTW, I mean suks as in good / boss / tubular etc
