Highway one bridge question
I recently acquired an early version of a highway one strat { the one with the smaller headstock} and the string spacing on the bridge is a little wide. it makes the first and sixth string really close to the edge on the higher frets. does fender use the same spacing on all the 6 hole mounted bridges? or is there a replacement i can put on it to pull the strings a little closer together?
I'd suggest looking at the Callaham website. (Even if you don't buy anything, he has lots of info.)
He has info on specific Fender model/year Strat tremolos that could answer your question. If I'm not mistaken, the pre-2006 Hiway 1's are different than the recent Hiway 1's. In general, vintage Strat mounting spacing and string spacing was 2 7/32". MOST MIM's (but not all) have "modern" 2 1/16" mounting spacing and string spacing. I just purchased and am waiting on the Callaham tremolo for a new USACG Strat build that has vintage mounting spacing but the modern string spacing. AFAIK, I don't believe that anyone else does this. His products are pricey, but very well made and worth it (to me). I'm about to mount a right handed tremolo in a lefty guitar...with the bar on top. Gotta remove some wood to make it fit. Good luck with your search.
I spent most of my money on women and beer...the rest I just wasted. Grand High Exalted Mystic Poobah of the He-Man Woman Haters Club and Silver String Submarine Band (Left-handed Chapter) |
http://www.callahamguitars.com/blocks.htm
there's the link According to Bill, 2005 and prior Highway 1's apparently have vintage 2 7/32" for both mounting and bridge spacing and the 2006 and later Highway 1's have 2 7/32" mounting spacing with (narrow) 2 1/16" string spacing. (So Fender DOES make this bridge that I needed, but not the same steel that Bill uses.) You can determine the year of your Highway 1 by the serial number, or there should be a date on the heel of the neck. Or you could just measure the distance between the center of the outside two mounting screws for the mounting spacing and measure the distance between E strings at the bridge for the string spacing.
according to my serial number it is a 2004-2005 model and the date on the neck heel is 2004.
so i should have the 2 7/32 mounting hole spacing and the 2 7/32 string spacing. so with the information provided, i need a 6-pivot bridge with 2 1/16 string spacing and 2 7/32 mounting spacing. also according to your previous post and the information on the callaham website. the newer highway one series strats have this mounting spacing and string spacing. by any chance did i interpret this wrong? |
#8 (permalink) | |
It sounds like you need the 2 7/32" mounting spacing, but I would measure to make absolutely sure. You already know that you want the 2 1/16" string spacing. Good luck and give us some feedback after its installed and played.
