Old November 6th, 2009, 09:33 PM   #1 (permalink)
fshboat's Avatar
buzzing Alparts neck?
Hoping to get a suggestions from you guys.
I just installed an Alparts 7.25 radius, soft V neck with vintage frets on a squire strat that was given to me. The body is one that is solid wood not plywood if that makes any difference.
I set have set it up to the Fender specs from the set up guide on their web site. Problem is have buzz when the the wound strings are fretted. It does not buzz when the strings are played open. It can be heard through the amp, more noticable at lower volumn.
I have wondered if a shim to change the neck angle would make any difference but I can't see where it would. Being a novice I don't know what would constitute the need to change the neck angle.
Any suggestions? Thanks.
fshboat is offline   Reply With Quote
Old November 7th, 2009, 01:59 AM   #2 (permalink)
Hiya fshboat, i think it might be that you have slight backbow on it, try to eyeball along the side of the neck to see if it has relief or backbow.
Zmatko is offline   Reply With Quote
Old November 7th, 2009, 11:10 AM   #3 (permalink)
As far as I know allparts necks need to have the frets dressed and crowned! I didnt do it to the tele neck I got and it seems allright but I may have been lucky!
It could be in need of a truss rod adjustment as Zmatko suggested! When some more of the experienced guys chime in they will sort ya out!
irishtele is offline   Reply With Quote
Old November 10th, 2009, 01:57 AM   #4 (permalink)
Brad J's Avatar
I have 2 allparts necks, and another on the way, The first was a boatback, needed nothing doing to it,
the second was the TRO-V (same as yours but for a tele) I found it had a little fret sprout up around the 14th fret,
I've done a little filing and it's better but still not perfect, needs more work.
Cast an eye down the neck and check for backbow, or raised frets, the go from there.
_
“It's one thing to have talent. It's another to figure out how to use it.” - Roger Miller 1936-1992
Brad J is offline   Reply With Quote
Old November 10th, 2009, 10:58 PM   #5 (permalink)
Hard to say without seeing it but most aftermarket necks I've seen have needed some fret dressing/leveling. Could need some more relief... Before shimming, I'd bring the guitar to a good tech and get some advice.
Jan Folkson is offline   Reply With Quote
Old November 11th, 2009, 01:09 PM   #6 (permalink)
boris bubbanov's Avatar
The TMO-VEE (which I think you have) has smaller frets than for example the frets on the TMO-FAT. Those FAT frets will need reduction in height anyway so a level and crown is already locked in.
But the TMO-VEE frets are low enough that, unless you have the neck in wrong or the wrong amount of relief, they shouldn't prevent you from playing to quite this extent.
Good advice from others so far; let me also suggest you go back and make sure the holes through the body attaching the neck are 11/64ths. Your neck may not be fully seated in the pocket if paint, etc. is making the fasteners bind up.
My experience does not match Jan's insofar as mandatory fret attention, but the bulk of my necks have been Warmoth and even better, USACG. His advice is correct for Mighty Mite, etc. I would bet.
When i listen
String Buzzing on frets 15 - 21. Neck shim needed? JKSteger Tele-Tech 7 May 6th, 2009 01:28 PM
advice on neck / buzzing... JKSteger Tele-Tech 8 March 5th, 2009 11:18 AM
I think my bridge is buzzing? Maybe my neck is loose? jdfoosh357 Tele-Tech 1 January 14th, 2005 03:59 PM
Buzzing Meltinpix Tele-Tech 9 June 26th, 2004 12:46 PM
buzzing newb Telecaster Discussion Forum 6 July 16th, 2003 05:09 PM
