Aluminum pickguard shield questions.
Callaham has one for fifteen bucks and now Guitar Fetish has one for just under eight.
Are they worth using? I just spray the back of the pick guard with adhesive and put on aluminum foil, seems to work fine. If you did use one of the shields I'm assuming you would still shield the cavity, correct? |
You already have the same shielding that one of those pre-cut shielding plates would provide by using a completely foil-backed pickguard. The cavities would need to be addressed to make a complete shield if they are not already.
Shielding is shielding. Any grounded conductor, no matter how thing, will do the job equally well.
These prepared shields are easier to apply and they don't get holes that easily. Not that small holes would matter if you don't have the sides and back shielded at all. I would be a little careful with heavier shields around the pickups. Eddy Current can change the sound quite a bit. Thick aluminium or copper should not go right up to the pickups. |
#4 (permalink) | |
How about Strats with aluminum pickguards? (like mine) I noticed no tonal difference when I went from plastic to aluminum |
I actually just shielded my Strat a couple days ago. I bought the shielding kit from Stew Mac but I did not shield the actual pickups like the instructions say to do. I used heavy duty aluminum foil from the grocery store and glued it to the back of my pickguard and I completely shielded the cavities with copper tape from the Stew mac kit. It helped a lot but I still pick up noise from computer monitors which is kind of annoying.
Aluminium is tricky because it is naturally coated in aluminium oxide which is an insulator. You can solder aluminium if you abrade it and solder it under oil. Not easy and needs practice but can be done to ground the plate.
| why shield a tele pickguard? | Tommy Tourbus | Telecaster Discussion Forum | 27 | February 20th, 2009 12:44 AM |
| Tele pickguard shield. . . does it work? | Upgrade | Telecaster Discussion Forum | 7 | April 10th, 2008 01:28 PM |
| Can I shield a Guitar with Aluminum foil? | TelZilla | Bad Dog Cafe | 11 | October 20th, 2007 03:39 AM |
| ground wire from pickguard shield to volume pot question | flapjack | Tele-Tech | 8 | April 26th, 2006 01:23 PM |
| And yes another: Callaham aluminum shield. | TeleGeir | Stratocaster Discussion Forum | 17 | March 11th, 2004 10:17 AM |
