Old June 13th, 2009, 07:13 PM   #1 (permalink)
kyle1167's Avatar
Need help finding a good hardtail bridge.
I've had a hardtail strat body for a few years now and I've decided to add to my partscaster collection.
My other strats have trems so I haven't dealt with a hardtail before. I'm looking for something that isn't so cheap that I'll have to replace the saddles but I also don't want to spend a truck load on something with all the bells and whistles. I just want one that I can put on and be happy with the tone and quality.
The body has three screw holes drilled for the bridge, don't know if this is the same cofiguration as a Fender hardtail bridge. From the research I've done so far it seems to be.
I know Guitar Fetish has one for 11 bucks and I've seen some from AllParts for around two hundred. Rather not go that low and won't go that high.
I look forward to your recomendations.
Thanks, Kyle
My Guitars
Guitar Projects
kyle1167 is offline   Reply With Quote
Old June 14th, 2009, 01:18 PM   #2 (permalink)
VENDOR
mellecaster's Avatar
Be aware that Fender makes 2 Hardtail bridges...Vintage and Modern, and they are not interchangeable....I would guess most aftermarket bodies would be drilled for the Vintage spacing....but you should check.
Old June 15th, 2009, 06:07 PM   #3 (permalink)
ddhr's Avatar
I am interested in opinions as well. Callaham has one for $63. No affiliation...
http://www.callahamguitars.com/partsstr.htm
Doug
ddhr is offline   Reply With Quote
Old June 15th, 2009, 07:36 PM   #4 (permalink)
Have you checked these out?
http://guitarheads.net/products/bridges/bridges.html
tomringg is offline   Reply With Quote
Old June 15th, 2009, 09:08 PM   #5 (permalink)
kyle1167's Avatar
Doug
Someone on the Strat-talk forum pointed that one out to me. That is one I'll be going with.
My Guitars
Guitar Projects
Old June 15th, 2009, 09:45 PM   #6 (permalink)
VENDOR
Telenator's Avatar
Hipshots makes absolutely the finest hardtail bridges I've seen and they come in two different thicknesses as well.
Beautifully machined and reeking of quality. I like their products a lot.
http://store.hipshotproducts.com/car...t_detail&p=163
Dogs have the right idea!
www.telenator.com
Old June 16th, 2009, 11:21 AM   #7 (permalink)
boris bubbanov's Avatar
That is a great one. I've got 3 of those.
Full 2 + 7/32nds width at the bridge, so make sure your neck is wide enough and that the frets are not rolled too much on the ends.
Read Bill Callaham's advisory on vintage and American Standard parts and some lack of compatibility.
When i listen
Old June 16th, 2009, 09:23 PM   #8 (permalink)
kyle1167's Avatar
Thanks Boris I'll check that out.
My Guitars
Guitar Projects
Old June 17th, 2009, 12:29 AM   #9 (permalink)
rangercaster's Avatar
Gotoh is fine, but if you want to go for Callaham, it's your money !!!
"Work is the curse of the drinking classes."
Oscar Wilde
Old June 17th, 2009, 12:57 AM   #10 (permalink)
Ns10Fan's Avatar
+1 on the hipshots
Ns10Fan is offline   Reply With Quote
Old June 18th, 2009, 09:06 AM   #11 (permalink)
How about a G+L Saddle Lock Bridge. Requires a little routing but, sustain up the ying yang. Linky:http://www.glguitars.com/shopping/shopexd.asp?id=175
Bill Jones is offline   Reply With Quote
Old June 22nd, 2009, 10:23 AM   #12 (permalink)
ddhr's Avatar
Angela is a source for Fender parts. Anyone have experience with this one?
http://angela.com/fenderclassicserie...eassembly.aspx
Doug
Old June 28th, 2009, 10:36 AM   #13 (permalink)
ddhr's Avatar
I purchased the bridge from Angela. It lined up perfectly on a Warmoth body drilled for a vintage hardtail. BTW, quick service from Angela. I ordered parts on Thursday and they arrived (via USPS) on Saturday.
Doug
Old July 2nd, 2009, 08:20 PM   #14 (permalink)
I've had great luck with the Callaham bridges, and now have them on all my strats and Teles. This is a picture of their Hardtail bridge on a Partsocaster I put together. This was actually a Callaham narrow spaced bridge...
724SP is offline   Reply With Quote
Old July 3rd, 2009, 12:14 AM   #15 (permalink)
iansmitchell's Avatar
I say go with a 3 barrel cutoff tele bridge...
Please do not insinuate anything sexual from that.
iansmitchell is offline   Reply With Quote
Trembridge vs. Hardtail bridge? mowcheeba Stratocaster Discussion Forum 0 April 19th, 2008 08:50 PM
Hardtail bridge on a non-hardtail body? normantrophy Stratocaster Discussion Forum 5 November 7th, 2007 09:34 PM
Need help finding a good amp tech creepy guy Amp Central Station 2 September 24th, 2006 01:08 PM
Tele hardtail bridge supa_scoopa Tele-Tech 10 February 9th, 2004 10:23 AM
who uses strat hardtail bridge? simon Stratocaster Discussion Forum 2 March 28th, 2003 02:07 PM
