Guitar Stands
Hey guys. I need to buy a stand for my new strat. Are there any that I should avoid that react with finishes etc.? I have heard that this happens with certain brands that use cheap types of neoprene cushioning on them. Thanks in advance,
-Jack |
I have a Hercules that holds 2 guitars, and it's an excellent stand. But, my everday stand is one of those little A-frame deals. Strat rests on the bottom hooks and the top of the A is a padded piece that lands right on the neck plate. I suppose if there was any finish concern it would be where the body rests on the bottom hooks. If you have a nitro finish you could always put socks on the rubber parts if you have any concerns, but I've only seen actual problems with old vinyl straps blistering finishes. If you've got a poly finish, there is nothing to worry about.
#5 (permalink) | |
They all use the same type of "foam rubber" (whatever it is, I don't really know), far as I can tell. If you're trying to protect the finish, I'd probably create a "bootie" of some sort, to be sure.
My acoustic is nitro, and it doesn't seem to be bothered by any of the newer stands. Of course, its 30 year old, bar worn finish could hardly be harmed by much of anything at this point... |
i bought 4 K&M Wave stands when WWBW had a blowout sale last year ... i think i paid $3.95 each ... they are a cool design that folds flat
"Work is the curse of the drinking classes." Oscar Wilde |
At a local shop (Willies in St. Paul) they have a bunch of their nitro-finished CS strats and teles hanging on Hamilton stands: http://www.hamiltonstands.com/guitar/kb38.htm so I suppose those are probably AOK...
There's only two things in life that make it worth livin' That's guitars that tune good and firm feelin' women... |
Ok I got a fret rest stand at guitar center with that black foam padding on the parts that touch the guitar. I might wrap the foam in a bandana just in case. This is a new guitar so I am super-paranoid about messing up the finish.
I use a Hercules 3 guitar tree in the studio every day, and have 4 other Hercules stands for stage, road, and other uses. They look good, function great and are very durable. I switched from Ultimate brand stands when two of the leg locks failed.
Mike Bruce |
#12 (permalink) | |
Keep your nitro finished guitars away from the amber colored "surgical rubber tubing"-type stands. It's the rubber tubing commonly used in slingshots ("Wrist-Rocket" sling shots come to mind), and will eat away the nitro where the tubing touches the paint.
My band : www.theexecutivesmusic.com |
#14 (permalink) |
UHMW will not mar nitro according to a luthier that I spoke with before . He used to work for Martin . UHMW is ultra high molecular weight plastic . Otherwise known as a Wal Mart cutting board . Remove the foam and put this in place with confidence .
#15 (permalink) | |
That is good advice! I have a few of those and use them a lot. Is black rubber ok? Thanks |
#17 (permalink) | |
But I'm not sure what you mean by a "Wal Mart cutting board." Are you talking about one of those very thin, flexible mats? Or are you referring to one of those white boards, maybe 3/8" thick? In either case, how do you secure that material to the guitar stand???
"It looked like a giant green gum drop to me." |
#18 (permalink) | |
The other concern of these stands is that you can catch your finger in the guillotine-like movement of the guitar head holder. I did it once on my left hand, and have been wary ever since. I have had no problem with those Fender guitar stands, on which the guitar is placed on 2 rubber coated feet, and sits on a tripod. The only knock is that they may be easily tipped over, once the guitar is in place. But they are so convienient and compact that I keep one in my effects pedal bag. |
#19 (permalink) |
I highly recommend http://www.drsracks.com/.
They're worth the cash and built like a tank. Safe for Nitro guitars and a pleasure to deal with. I've got a performer 18 right now holding 2 LP's and 2 Strats. Does a nice job holding them and it looks great too. |
| Guitar Stands | all_identaties_taken | Tele-Tech | 3 | April 9th, 2009 01:24 PM |
| Guitar stands. anyone tried this... | Twang Man | Telecaster Discussion Forum | 12 | August 9th, 2007 03:15 PM |
| Guitar Stands | Togman | Bad Dog Cafe | 16 | April 22nd, 2005 01:44 PM |
| wall mount stands/multi stands | zsno | Telecaster Discussion Forum | 9 | April 21st, 2004 03:11 PM |
| Guitar stands... | Adam Waldron | Telecaster Discussion Forum | 13 | December 14th, 2003 05:52 PM |
