Old May 20th, 2009, 08:51 AM   #1 (permalink)
Strat Jack Problem Help!
So I got my CV Strat in March and love it but lately it started popping really bad. i thought it was the cable but I have a monster cable and it is fine. I noticed that the cable tip has a little bit of room to wiggle around in the jack. i don't know if I can fix it with some tools or if I have to buy a whole new jack. Need help.
Dark13579 is offline   Reply With Quote
Old May 20th, 2009, 08:56 AM   #2 (permalink)
Dauntless's Avatar
I would just replace it with a Switchcraft jack.
That's what I did.
Gene "Dauntless" Flannery
"If the only tool you have is a hammer, you tend
to view every problem as a nail."
-Maslow-
Dauntless is offline   Reply With Quote
Old May 20th, 2009, 10:19 AM   #3 (permalink)
Why not just remove the Jack plate(2 screws) and bend the tip end in a little to tighten the grip.Check the grip with your cable to get the right tightness then put the jack plate back.Easy fix and if you dont like the results then replace it.
I don't need no I.D.,I know who I am,I'm Tommy Bolin!
Post Toastie is offline   Reply With Quote
Old May 20th, 2009, 10:35 AM   #4 (permalink)
magicguitar's Avatar
+1 what Post Toastie said.
magicguitar is offline   Reply With Quote
Old May 21st, 2009, 03:43 PM   #5 (permalink)
Same here, just bend the tip and you are back in business for many years.
Stratotwanger is offline   Reply With Quote
Old May 22nd, 2009, 08:36 PM   #6 (permalink)
VENDOR
mellecaster's Avatar
Not really...the cheaply made jacks have crappy spring steel that won't hold a set...just get a $2.95 Switchcraft and enjoy your Guitar.
Old May 22nd, 2009, 10:00 PM   #7 (permalink)
Yep instead of trying to bend the jack and see if it fixes the problem: order a new jack, get delivery,do the replacement with a Soldering iron that you may or not have and you will be ready to go?
Old May 23rd, 2009, 09:56 AM   #8 (permalink)
VENDOR
Do I note a touch of sarcasm ?....didn't say it wasn't a Temporary fix...figured since he had invested in an overpriced Monster cable, he might want a permanent solution, so as not to have to concern himself with it again in the future...you know...fix it once the right way, and then move on to other things.Just seems like common sense to me ?
Jack socket problem - please help! Greene Tele Home Depot 23 April 2nd, 2009 05:40 PM
72 tele delux RI jack problem dubwise Telecaster Discussion Forum 1 January 27th, 2009 09:50 AM
Output Jack Problem. twangee Tele-Tech 7 December 7th, 2005 02:54 PM
jack/cable problem ruger9 Tele-Tech 2 March 25th, 2005 10:04 AM
Input jack problem ? Baard Amp Central Station 5 May 30th, 2003 01:17 PM
