Old March 1st, 2011, 09:25 AM   #21 (permalink)
PapaBeef's Avatar
Wow. Great timing.
I see the OP is from a year ago. But I am currently working on a strat project using low output lipstick tube PUPs & wanted to do something different than standard Strat setup on it.
This is perfect, I think.
I'll give it a try when I get the PUPs & see how it works out.
Thanks.
What I mean is, sometimes I just don't know what I mean. Ya know what I mean?
PapaBeef is offline   Reply With Quote
Old October 16th, 2011, 11:33 PM   #22 (permalink)
Hi there.
Anyone tried this wiring?
http://img.photobucket.com/albums/v1...tratbucker.jpg
I've tried this and others series/parallel with push-pull schematics without success. In any of them, only the middle pickup is working (the only one grounded on the pot). Some idea of what's wrong? Thanks.
leorock is offline   Reply With Quote
Old October 18th, 2011, 12:15 AM   #23 (permalink)
Originally Posted by leorock View Post
Hi there.
It looks like it should work to me. It is a neat way of getting the series sounds using a standard 5-way switch. Are you sure the wire running from the lower left of the push-pull pot to ground is connected properly? I don't know how expensive multi-meters are in Brazil, but they are handy for troubleshooting these kinds of problems. A cheap one will be fine, just make sure it has a continuity checking function with an audible beep.
jeggles is offline   Reply With Quote
Old October 18th, 2011, 10:21 PM   #24 (permalink)
Yeah, the lower left slug of push-pull pot wasn't grounded properly. Thank you!!!
Now i'm trying to include the tone pots - one for neck and middle and another for bridge pickup. If I connect them from the right side of the switch (like a stock wiring), it doesn't work. Any tip?
Old October 19th, 2011, 01:14 AM   #25 (permalink)
Just move the wires going to the tone controls to where the +ve pickup leads connect.
Old October 24th, 2011, 11:38 AM   #26 (permalink)
Chromastercaster or Fat-O-Caster V.0-V.3 or Memphis:
Hey Eddie, how are you ?
I can’t decide which of the switches to get from your website. They all sound cool.
I’m a rock/blues guy, which is the switch for me. My Strat is three single coils.
I tried your 5 tone Tele mod and it came out all right and I did the Strat in series mod on my Strat too.
Now I want to mod my other Strat and the Chromacaster and FAT-O-Caster switches seemed very interesting to me but there is the Chromacaster and FAT-O-Caster V.0 - v.3 then theres the Memphis.
Still confused as to which one to do on my Strats. I have two Strats/3 single coils. My Strat that have the in-series mod I want to mod again because in-series mod looses the tone pot. So I am thinking of updating two Strats now.
Any suggestions ?
Thanks.
telebunny is offline   Reply With Quote
Old October 24th, 2011, 12:28 PM   #27 (permalink)
Deaf Eddie's Avatar
Sorry, I'm not registered as a vendor on the TDPRI and it's against forum rules to "self-promote"... You'll have to start a thread and ask if there are any FAT-O users here.
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
Old October 24th, 2011, 12:54 PM   #28 (permalink)
Originally Posted by Deaf Eddie View Post
The B-Bender scheme:
Don't forget about the ground issues mentioned above.
Y'know, it's worth a mention that Fender gets pretty close to these schemes on the Strats with the S1, so it's not like this is earth-shaking new stuff.
Would there be anyway to make the the (n+b)*m just plain ol neck*bridge in series when the p/p is pulled up. This is a great wiring scheme all in all. I'm just curious.
Thanks for the great info all together
DropKick74 is offline   Reply With Quote
Old October 24th, 2011, 01:15 PM   #29 (permalink)
Deaf Eddie's Avatar
Nope.
Old December 22nd, 2011, 08:53 AM   #30 (permalink)
But this way I can't get independent tone controls (I like one for bridge and other for middle and neck). There's a way to do it? If I solder together +ve neck and middle leads the 5-way switch won't work properly.
Old December 22nd, 2011, 02:44 PM   #31 (permalink)
Deaf Eddie's Avatar
No.
Old December 23rd, 2011, 01:10 AM   #32 (permalink)
You can have bridge tone and middle tone controls or bridge tone and neck tone controls - you have to choose.
Old December 23rd, 2011, 10:10 AM   #33 (permalink)
sjtalon's Avatar
u da man !!
Now to really be the Whacko, draw one up with your Fat-O-Caster switch for some of dat out of phase (crap)
Old December 26th, 2011, 05:25 PM   #34 (permalink)
I'm thinking to have a master tone instead and use the other pot as a blender. I've found some blender wirings and tried to wire neck and bridge +ve but it's not working. Any thoughts?
Old December 26th, 2011, 11:27 PM   #35 (permalink)
Deaf Eddie's Avatar
Typically, blender mods and series mods don't mix well.
Old December 27th, 2011, 10:05 PM   #36 (permalink)
The Robbie Robertson Strat does this as well.
If you look close, there are three single coils - not a sc and a humbucker.
noah330 is offline   Reply With Quote
Old January 9th, 2012, 10:17 AM   #37 (permalink)
Need help understanding this wiring
This drawing is from the link in post #22 above. This is the wiring I want to do.
I'm confused about the drawing in general and was hoping someone could explain it to me. I could just try to follow it but I'd like to understand it.
Are the terminals of the 5 way switch like this?:
N___C
M___N
B___M
C___B
It looks to me like the negative of the Neck is always connected to everything and the Bridge negative is always connected to the middle positive. Basically, I don't get it.
samato is offline   Reply With Quote
Old January 9th, 2012, 11:43 AM   #38 (permalink)
Nobody's looking at my post.
I know it's an old thread so I need to be patient!
Old January 11th, 2012, 08:23 AM   #39 (permalink)
N___C
M___N
B___M
C___B
The way this diagram is drawn, both common lugs must be at the bottom of the 5 way switch otherwise it won't work.
Old January 11th, 2012, 09:46 AM   #40 (permalink)
Ah, so that's not really how it is on mine but as long as I wire it that way it will work I suppose. Thanks!
