The Jimmicaster build
I don't normallly troll around the Stratocaster side of this as I usually do Teles, but I got the itch to build a Olympic White on white Stratocaster like Jimmi played.
![]() So I saw this in a catalog... ![]() and thought, why not I have built a couple of Teles, how hard could it be? Well I will tell ya, the Teles are easier to build by far... so start like Leo did, build a Tele first before you start on the Strat.
So many guitars... so little time. Last edited by Preacher : July 3rd, 2008 at 01:03 PM. |
So after a little searching on the net I finally found a Strat drawing file, printed me off a copy
![]() and went to making a jig (sorry Ron, I like to make my own... I am too cheap to buy them!!
So many guitars... so little time. |
Eden necks are drilled for Modern tuners, but I got a sweet deal on some Vintage Pings, so we had to buy some bushings from GFS.
![]() Headstock looked good though...
So we attached the drawing to a piece of MDF to make our jig.
Now I am not a purist by any stretch of the imagination, so I thought one day I might want a SSH, so I made the bridge pup cavity flexible. I am also going to set up a reverse slanted bridge pup, so this will allow a standard set up, a reverse slant and a bucker if I wanted... options!! ![]() I drilled all the starting holes, so off to the band saw for some cutting!
sidetracked, well actually...
![]() The daughter wants a guitar... so we were shopping for parts and she decides she wants one. So I spy this on the wall, don't need the neck, I already have one but I have another Tele body in the works that needs a neck and I start thinking which is a dangerous thing... ![]() ![]() That neck for a tele will definately need to change... So we spent about two months on the Tele, while the Start sat... But the daughter was happy, find the Gumdrop Tele and you can see that saga...
#10 (permalink) | |
not too sure about the pups, they look to new to be in that guitar and the soldering looks too much like someone like me added them. They have a certain vintage look to them...
![]() Still have not ran the Ohms, but I do not think they are overwound or hot.
I do not want to be confused with Buckocaster as a master builder so I won't give you step by step pictures as I am too lazy for that and it slows you down.
So we routed the body... ![]() And the back... what a pain...my jig bit the dust for the back... so I blocked out the space on the back with wood strips (should have bought those jigs from Ron!!) good thing it is getting painted. And I did do it with a router, as hard as it is to believe, next time I think I will use the chainsaw!!! ![]()
#14 (permalink) |
So after a little work I installed the tuners, man I love those vintage looking Pings and the bushings and did a logo... for the headstock logo police read it carefully, and yes it has fooled at least a dozen people at this point.
![]() Oh and I cut my own Corian nut, used some needle files to the slots and it turned out pretty good for my first one...
So after some sanding we fit it all together to see how it fits...
![]() ![]() It is a little rough and I need to adjust the neck angle somewhat, but I am happy. So happy I played it for about a month like that but did not unveil it to the public.
#16 (permalink) |
Wow that last pic the flash was bad but you get the picture albeit a bad one...
here is a little better shot of the front. ![]() Now we have a problem. As I mentioned this body is poplar, but the grain looks pretty good, too good to get painted I start thinking. So maybe a burst as the back has more green mineral streaks than the front. Maybe a Cherry burst, hmmmmm... <slaps himself in the face> snap out of it, we started to do a Jimmistrat and we will stay with the plan!!! So the tear down begins!!!
#17 (permalink) |
So after about a month and a half of...<in my best Pat Morita Karate Kid>
with 150 grit, 200 grit, and 400 grit sand the body up, sand the body down sand body side to side, sand body circle up, sand body circle down... Primer on,,, with 200 grit, and 400 grit sand the body up, sand the body down sand body side to side, sand body circle up, sand body circle down... We were ready to apply paint. Krylon Antique White I do believe, close enough to Artic or Olympic or Lace and so we spray and spray and spray. And then we spray on Clear, spray on clear, spray on clear... And then we... with 400 grit, 800 grit, and 1000 grit sand the body up, sand the body down sand body side to side, sand body circle up, sand body circle down... And then with the polish we... polish the body up, polish the body down polish body side to side, polish body circle up, polish body circle down... And we end up with.... The JimmiCaster... ![]() ![]()
#18 (permalink) |
How did I do?
the original... ![]() the replica... ![]() Of course I would have to learn to play left handed to look like Jimmi, well not look like him as I am caucasin, but play like him, well I can't play like him either, so well, when I play it righty, it looks like his guitar playing lefty... well you know what I am talking about.
#21 (permalink) | |
Oh well, live and learn.
