Guitarfetish.com has steel blocks for your MIM and import trems
Was just looking on the guitarfetish.com website and under tremolo's you can order a full size steel block for your MIM and Asian import strats! Jay says the blocks trem arm are sized for the Fender standard trems so you must purchase a new trem arm too.
I've ordered mine, UPS says it will be here Monday!! http://store.guitarfetish.com/sosttrblfima.html **One thing I just thought of. By looking at the picture, the block looks a little "longer" than the small zinc sized one that come on the Squire Affinity and Bullets. I'm not sure if the block will fit the smaller thickness of the guitar or not. If anyone knows, pass the info along here.** Thanks, Jeremy |
Hi, I'm a newbie here. First post/reply. I suspect you will either have to leave the back cover off or shave about 3/16 off the block. I was offered a standard block trem and after some measurments that was my determination. It looked like that would have left enough depth for Fender bullet or ball ends. Turned it down as the screw holes didn't match either. It's a project guitar but not quite that involved. Good luck with that.
I have been considering upgrading my (MIM) Standard Strat trem for some time. I recently blocked it for tuning stability (I go back and forth from standard to open G a lot, and I don't use the whammy). Will an upgrade make any difference now (with it blocked)?
Save The Hymnals! |
----------- Mine came yesterday and I tried it in an Affinity. It protrudes about 1/8".
_________________________________ "Hey! Are you a chicken or a pig?" --- Robert Newcombe "..... make mistakes, please...." p.103 |
#6 (permalink) | |
#7 (permalink) | |
Jeremy |
#8 (permalink) | |
You can also block it in the cavity to only dive so it won't go out of tune if you break a string. But that is a different thread. ;) |
I have 2 Squier Strats.
Vintage Vibe 50s and a Deluxe. The block fits neither as the hole for the trem bar is off center from the trem bar hole on the bridge plate. It is a very nice block, just doesn't fit what I want it to fit! I got a friend who has a Mexican Strat and I'll probably put it on his when I change his pickups out for him in August. Looking at the way it's layed out, it'll probably be a perfect fit. I would imagine that it would fit the CIJs and MIJs pretty well also. But for me, no go! Now, if I could just find a bridge plate that matches...
Gene "Dauntless" Flannery "If the only tool you have is a hammer, you tend to view every problem as a nail." -Maslow- |
#15 (permalink) | |
Auto mechanic could work too.
... Please do not insinuate anything sexual from that. |
#16 (permalink) | |
It wasn't noticed because it was added to the original.
#17 (permalink) | |
Jeremy |
#18 (permalink) |
Well I don't know how deep the holes are and how close the string ends are to the back edge of the block. My USA Fender Trem, well the block for example is such that if I used bullets or def-tone string the bullet end is flush with the back of the block. So the ends would just stick out if the block was machined shorter. I guess drilling them
a touch deeper would take care of that. But don't forget to get the machine shop to do it while it is there if you go that route. Just set up the guitar as I said in my first post. It is simple, reversible, and would put the block inside the desired amount. KISS I say. You may even have enough range to lower the saddles with out shimming the neck after you raise the bridge the 1/8" Use the "Ron Kirn" Tubing method if a 6 screw, or just raise the posts if of the 2 post ilk. Playing with the action higher builds character anyway... |
#19 (permalink) |
Update on my post from last week......
I've been playing my Affinty with the "oversized" steel block for a couple of days and decided to leave it in without modifying the length. I really like the added sustain and zingy harmonics. I recommend finding a way to work around the 1/8 inch problem. I may end up modding the back cover to provide the clearance for the block while hiding the springs and claw. On the other hand, I don't notice the block's movement when I work the vibrato. Bottomline....whether I do the mod or not, that block is staying right there.
#20 (permalink) |
There were a couple of threads where Ronkirn showed the use of silicone spacers for the trem screws. He advocated this to help improve tuning stability. I know one of them was "The Dalmore" build thread.
You can also try searching for "silicone" or "silicone spacers" Based on the instructions he gave there and in a couple of other spots, I'm pretty sure this would get you the 1/8" clearance. He said that length was about 3/16-1/4". Then you compress them by about 50% when screwing down the trem. I recently made this change. but, I haven't had time to judge the results. It's really quick and easy to do. It only took me about 5 minutes and didn't bother taking off the strings. You can get the silicone tubing at a model shop. It's used for model airplane fuel line. Just a suggestion... |
#21 (permalink) |
I installed one of these on my MIM strat today. Sounds pretty nice...definite improvement over the crappy thin block I had in mine before. My bridge was actually one of the import trems that this block "doesn't" fit. It fits fine but the hole for the trem arm doesn't line up with the one on the bridge. I never use the trem anyway, I use 5 springs and that fixes the bridge in position pretty well.
#22 (permalink) | |
Practice make permanent!!!!....Perfect practice makes perfect!!! Chris B. Current Band www.productoffaith.net Last band as a bass player www.neonjones.com |
#24 (permalink) |
I sent GFS an e-mail asking about the block fit on the MIM - here's the response:
Just look at the trem top plate - If the hole for the arm sits just BEHIND the three screws that hold the plate to the block- it won't work- if it sits just IN FRONT of the three screws it will fit I have a mid 90s MIM, and the hole for the arm sits behind the three screws. |
